The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - General Metrology, Measurement Device, Calibration and Test Laboratories > Calibration Frequency (Interval)
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
scales and balances, weight (general term), calibration (general topics)
Reply
Old 29th October 2010, 07:51 AM
momatwork momatwork is offline
Shy Poster (1 to 5 Posts)
Registration Date: Oct 2010
Karma Power: 11
momatwork has less than 100 Karma points so far.
Question Calibrating a Weight Scale in a Laboratory
As a part of preparing in-house media in microbiology lab we use a weight scale. It is calibrated but we need to buy a balance to chek it every day. Is one calibratated balance enough? We use it for weighing 0.30 grams to 55 grams.
Sponsored Links
Old 29th October 2010, 08:00 AM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,947
Karma Power: 1429
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Re: Calibrating weight scale in a laboratory.
I started a new thread for you and moved it to the Calibration forum.
Hopefully, you'll get more responses.
Stijloor, Forum Moderator.
Sponsored Links
Old 29th October 2010, 08:41 AM
tomvehoski tomvehoski is offline
Courtesy Access
Registration Date: May 2001
Karma Power: 149
tomvehoski is appreciated, and has over 1700 Karma points.
tomvehoski is appreciated, and has over 1700 Karma points.tomvehoski is appreciated, and has over 1700 Karma points.tomvehoski is appreciated, and has over 1700 Karma points.tomvehoski is appreciated, and has over 1700 Karma points.tomvehoski is appreciated, and has over 1700 Karma points.tomvehoski is appreciated, and has over 1700 Karma points.tomvehoski is appreciated, and has over 1700 Karma points.tomvehoski is appreciated, and has over 1700 Karma points.
I would think your easiest solution would be to get a set of certified weight standards to cover the range of your scale. Looks like you can get them online for a few hundred dollars or less (but I don't know the range/precision you require). You could also contract with a calibration supplier to come in and calibrate it for you at periodic intervals.
Thanks to tomvehoski for your informative Post and/or Attachment!
Old 29th October 2010, 09:07 AM
BradM's Avatar
BradM BradM is offline
Forum Administrator
Registration Date: Sep 2006
Thanks Given to Others: 1,303
Karma Power: 400
BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
In Reply to Parent Post by momatwork View Post
Hi there!! Welcome to the Cove!
I'm a little confused by some of your wording. When you say:
It is calibrated but we need to buy a balance to check it every day.
Do you mean weights instead of balance?
Tom's right, you can buy a set of weights to cover your range. I would get a set up to 100 grams. That way, you always have choices. If you just get one weight, and it gives you suspect readings, you are not sure if it's the balance or the weight. Sometimes weights get junk and all on them and get off a bit.
Now, 75 years later in an abundant society where people have laptops, cell phones, iPods and minds like empty rooms, I still plod along with books. ”
—Harper Lee
Thanks to BradM for your informative Post and/or Attachment!
Old 29th October 2010, 02:18 PM
DsqrdDGD909's Avatar
DsqrdDGD909 DsqrdDGD909 is offline
Involved in Discussions
Registration Date: Jul 2006
Thanks Given to Others: 94
Karma Power: 45
DsqrdDGD909 is appreciated, and has over 300 Karma points.DsqrdDGD909 is appreciated, and has over 300 Karma points.DsqrdDGD909 is appreciated, and has over 300 Karma points.DsqrdDGD909 is appreciated, and has over 300 Karma points.
Re: Calibrating a Weight Scale in a Laboratory
What precision do you need? This will guide what class weights you need.
How often will the the scales be calibrated by an outside source?
We used to check our analytical scales at 1%, 25% and 100% of capacity.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Connection of Secondary Circuits to Medical Weight Scale Enclosure itzbobz IEC 60601 - Medical Electrical Equipment Safety Standards Series 2 31st October 2011 12:58 AM
Calibrating a reflectometer - Scale uncertainty with reading? greif Measurement Uncertainty (MU) 1 23rd January 2009 03:26 PM
Weight Check Tolerance of in-line Scale on new pallet conveyor system Swagg - 2009 ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 7 28th February 2007 11:34 AM
Count By Weight Scale - Calibration within specification, but not linear gpainter ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 8 7th February 2007 12:00 PM
Weight class required for scale calibration beekun ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 2 8th February 2006 11:24 AM
The time now is 12:33 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
