Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Supplier Quality Assurance and other Supplier Issues
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 2nd April 2002, 03:32 PM
max146 max146 is offline
Registration Date: Apr 2002
Karma Power: 32
max146 has less than 100 Karma points so far.
Read This! Supplier Quality
During a recent audit, the auditor asked us to produce records that show that our suppliers (all are QS-9000) are having their material independently tested periodically to verify their finding when they issue us a Certificate of Conformance or a COA. None of suppliers have an accredited lab to include us. Anyone have any suggestions or interpretations of this in the standard?
Sponsored Links
Old 2nd April 2002, 03:57 PM
Randy Stewart's Avatar
Randy Stewart Randy Stewart is offline
VINI, VIDI, DORMIVI
Registration Date: Feb 2002
Thanks Given to Others: 20
Karma Power: 84
Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.Randy Stewart is appreciated, and has over 1300 Karma points.
Lightbulb
Let me ask a couple questions first.
Was this raw material or parts?
If it was 4.10.6 it is out of your control. You could, however, send the samples out on your own.
The company has to exercise some type of control over its suppliers even if they are QS. The amount of control is established, documented and verified. If you are receiving parts and the supplier is mfg them to spec, you recieve a cert per lot, etc. what else can you do. I don't believe you have to prove that they are using a lab etc..
If it is a production part you are required to perform the annual part lay out which includes the material spec.
Welcome to the cove.
"What this country needs is more unemployed politicians." Edward Langley
Sponsored Links
Old 3rd April 2002, 12:30 PM
Karma Power: 32
Yin Yang Supplier Quality
The material in question is raw material, metal strip, copper/brassd and aluminum. We receive certificates of conformance verifying the material from the supplier. We also maintain a spec sheet for each category of raw mateial. This spec is dictated by our customer. Quality verifies the COC to the spec and if it meets spec releases the material for production. If not then, our nonconforming process kicks in and the material is placed on hold. That is when we send out samples. The supplier will send out samples if they suspect a problem. However we are not informed unless they believe that we may have received some of the material. We have sent material out to be tested, however this is not done on a routine basis.
Old 3rd April 2002, 02:59 PM
db's Avatar
db db is offline
Where's the shall?
Registration Date: Jul 2001
Thanks Given to Others: 208
Karma Power: 129
db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.
Default Independent certifications
Max,
Exactly what "shall" is in question? 4.10.2.4? 4.6?
4.10.6 refers to "Supplier laboratory requirements" -- That would be you.
Does the material work? Based on your second post, I would say you have a system that works for you.
I'm not certain that QS has been violated. I would need to have the auditor (or you) quote the "shall" that is being referenced.
Dave B (the other Dave)
Old 3rd April 2002, 05:26 PM
Neil Neil is offline
Involved in Discussions
Registration Date: Mar 2001
Karma Power: 39
Neil is appreciated, and has over 100 Karma points.Neil is appreciated, and has over 100 Karma points.
Default Incoming Product Quality 4.10.4.2
I strongly suspect that the auditor was referring to 4.10.2.4 and if I recall correctly that section changed in QS-9000 from the second to third revision. As of the third revision the bullet allowing Certificates of Conformance as the only incoming supplier quality system control was removed. It has to be supplemented by one of the remaining four bullets. The auditor has probably decided that you are relying heavily upon the supplier certs and as an obvious follow-up has asked for independent confirmation of their validity. I'm sure it is not applicable in this case but the auditor, like me, as probably seen some examples of supplier certs that weren't worth the paper they were written on or worse were completely made up. The path of least resistance is to send a sample out once or twice a year to an accredited lab for confirmation. You might just be surprised by the result. Hope this helps...
Neil
Old 4th April 2002, 03:54 PM
db's Avatar
db db is offline
Where's the shall?
Karma Power: 129
Default 4.10.2.4
Hey Neil, Welcome to the Cove your input is always welcome!
I do believe you might be right. The funny thing is that although we rely heavily on supplier COC, 4.10.2 doesn’t even address them as a possibility. Reading the requirement and using a literalist interpretation, they are not an acceptable method for determining incoming product quality. However, the second bullet does mention sampling based on performance. One could interpret that to say, if it works as we use it, or base on past experiences.
BTW, 16949 does not contain any of this.(at least that I have seen)
Old 4th April 2002, 04:23 PM
Karma Power: 39
Default Acceptability of CoC
Hi Db,
I went into my document archives and pulled out the 2nd edition QS-9000. For a change my memeory was correct. There used to be a 5th bullet to what is now 4.10.2.4 which stated:
Subcontractor warrants or certifications (shall include test results and shall be used in combination with one or more other methods).
So statements of conformance (CofC) from the supplier without actual test data was never acceptable as a stand alone supplier control. Now even Certificates of Analysis which contain actual test or inspection data are not acceptable as well. The sampling based on performance is referring to actual receiving inspection or testing frequency. So it sounds like we are all using the 2nd or 3rd party assessments of subcontractor sites as our main incoming quality control. Frightening isn't it?
So let's give the original auditor his due, he seems to be thinking about the effectiveness of the incoming controls. Periodic independent verification of CRITICAL sunbcontractor certs seems like a prudent thing to do. Let's be honest, we are all trying our best to do the minimal amount of receiving inspection as we can, and why not? Incoming inspection is not a value-added activity.
Old 4th April 2002, 04:32 PM
db's Avatar
db db is offline
Where's the shall?
Karma Power: 129
Default
Thanks for the memory lesson. I threw away my 2nd edition a long time ago. It's funny how I would have sworn that cofc was still there!
But this doesn't detract from my original post. There is no requirment that the vendor's must have material independently tested. The fourth bullet allows for part evaluation and the second allows for receiving inspection. But no where can I find a "shall" that corresponds to the auditor's request.
Now, in defense of the auditor, we do not know the entire conversation. If the auditee is only offering cofc as their "proof" of incoming product quality, then the auditor has a much stronger point. But if the auditee is also offering the second bullet, then the auditor might well be out-of-bounds.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Supplier Quality Manual and Supplier Quality System Audit Format wdavis80 Supplier Quality Assurance and other Supplier Issues 3 24th December 2007 06:42 PM
Track and solve supplier quality problems - How do you address these supplier issues? Jim Wynne Supplier Quality Assurance and other Supplier Issues 9 4th October 2005 11:48 AM
QS-9000 Section 4.10.6 Supplier Laboratory Requirement Michael Busha QS-9000 - American Automotive Manufacturers Standard 4 20th April 2003 01:32 PM
Supplier Quality Assurance Procedures & QS 9000 Kenen Supplier Quality Assurance and other Supplier Issues 8 22nd August 2001 01:09 AM
How JIT (Just In Time) fits in with ISO 9000 and QS-9000 Quality Systems KHAN786 ISO 9001:1994 2 17th March 2000 10:29 PM
The time now is 12:57 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
