The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Medical Devices, Medical Information Technology, Medical Software and Health Informatics > Medical Device Related Standards > IEC 60601 - Medical Electrical Equipment Safety Standards Series
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
touch current test, medical devices (general), iec 60601 - medical electrical equipment
Reply
Old 25th November 2010, 12:22 PM
WillPaul WillPaul is offline
Shy Poster (1 to 5 Posts)
Registration Date: Nov 2010
Karma Power: 11
WillPaul has less than 100 Karma points so far.
Please Help! 'Touch Current' test - Seeking clarity about clause 8.7.4.6
Hi All,
I really hope that someone can help me. I can see that someone has posted a very similar question to this before, however I didn't fully understand the response.
To simplify the problem, lets say that I have battery which is to be fitted to a medical power tool before every operation, like a DIY drill. At the moment the two contacts can be touch simultaneously, therefore failing the 'touch current' test - 8.7.4.6:
"Internally powered me equipment is to be investigated for touch current but only between parts of the enclosure, not between the enclosure and earth unless 8.7.4.6.c) applies".
How do I get around this problem, or am I misreading the standards?
Thanks in advance for all the help
Will
Sponsored Links
Old 25th November 2010, 02:33 PM
20110131 20110131 is offline
E-Mail Address Appears to be Invalid
Registration Date: Aug 2010
Location: About 10% over the hill, and taking in the quiet of a palm shaded beach view
Thanks Given to Others: 86
Karma Power: 0
20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.20110131 is appreciated, and has over 1700 Karma points.
Re: 'Touch Current' test - Seeking clarity about clause 8.7.4.6
60601-1:2005 3rd edition sub-clause 8.7.4.6, or 2nd edition, sub-clause 19.4g Subject matter being: "enclosure leakage"
The leakage is defined as:
Enclosure Leakage Current: Current flowing from the enclosure or from parts accessible through an external conductive connection to another part of the enclosure.
Referenced @
http://www.conformity.com/artman/publish/printer_176.shtmlp
Your device is battery powered. I would advise against some-how applying mains potential to either battery terminal, with or without a battery inserted. You are attempting to determin the maximum flow of current, from live part(s) within device to the surface of you properly insulated, (likely plastic), device.
approach to understand the test: You are trying to determine the maximum leakage current, which could flow through the enclosure. The enclosure likely is a high resistance, (likely plastic, and over 10Giga-ohm surface resistance, at any points), cover. The very high resistance of the cover dictates the maximum possible leakage current. The directions indicate that this can be tested from any and all conductive contact points within the device. It is likely that testing from the battery +/- terminals would work well. With a Giga-Ohm meter you could measure the resistance and calculate the maximum leakage current. Example: [Max possible applied voltage]/[measured Giga-ohms]=[Max leakage current]
Max possible applied voltage = As described in parts of the standard, would be AC mains, (110VAC/220VAC)(Alternately DCV=ACV-peak value, being 166/311VDC)
Max leakage current = Regulatory requirements. If 10uA, then a surface resistance of [311/0.00001 ohms] or 31.1Mega-Ohms must be met. Over 1oGohms is likely, unless you have a metal case with poor isolation.
The resistance example is a method of understanding the current flow situation only
I hope this helps, and does not confuse you more
Sponsored Links
Old 25th November 2010, 04:29 PM
Karma Power: 11
Thanks for the reply.
As far as I am aware 60601 does not classify the touch current as the current between live and the enclosure, it just states that between two points of an enclosure (for internally powered devices), in which case this could be between a DC 1.2v battery and its enclosure or either end of an AA battery, that the touch current can not be exceeded. How is it the case, how are batteries used?
If I am missing a trick here, please can you direct me to the clause/statement that either exempts dc tool/floating voltages/internally powered devices etc, or just explains how to get around this problem.
Many thanks,
Will
Old 25th November 2010, 05:13 PM
Karma Power: 0
You said it best! The standard seems to almost assume Mains voltage is an input, and comments how the device should handle it as being a maximum imput. The battery terminals would have to be an excluded. I did not see 8.7.4.6c I am sure this is covered in the "c" part.
The resistance comment was a way of describing the test DC impedence using I=V/R or R=V/I, and so on.
The testing can be interesting at times. The wrong probe or wrong voltage in the wrong place can be explosive.
Old 2nd January 2011, 08:43 AM
Peter Selvey Peter Selvey is offline
Appreciated Information Resource
Registration Date: Oct 2009
Thanks Given to Others: 35
Karma Power: 86
Peter Selvey is appreciated, and has over 1700 Karma points.
Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.Peter Selvey is appreciated, and has over 1700 Karma points.
Sorry for slow reply here:
Both the 2nd and 3rd edition have "get out of jail for free" cards for this case.
In the 2nd edition it is under Clause 16 e) 5).
In the 3rd edition it is under Clause 8.4.2 c).
Batteries are one of the specific examples called out.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Current Products on the Market and IEC 60601 3rd Edition Safety Re-Test Requirements MBTEX IEC 60601 - Medical Electrical Equipment Safety Standards Series 12 19th September 2011 05:21 AM
Are Adapter Plugs Tested for Touch Current Eamon IEC 60601 - Medical Electrical Equipment Safety Standards Series 3 5th May 2011 07:46 PM
Zebedee CL-100 Clarity Meter Calibration Procedure needed merrick65 ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 2 31st May 2008 01:38 AM
Seeking CURRENT PPAP Part Submission Warrant dbulak APQP and PPAP 7 20th August 2004 06:04 AM
Calibrating Shore Hardness Rubber Test Blocks - Seeking NAMAS UK Test house Geoff Cotton ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 4 5th December 2003 06:32 AM
The time now is 06:43 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, West Chester, Ohio 45069-1929
513 341-6272
