Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th April 2002, 01:31 PM
Navin R Navin R is offline
Registration Date: Apr 2002
Karma Power: 31
Navin R has less than 100 Karma points so far.
Default Dimensional Inspection
Hello All,
I'm considering starting a business performing dimensional inspections, primarily with a CMM. At this point there is nothing physical, just an idea (small oak from an acorn, I hope).
I understand the equipment I need and how to operate it, but on the issue of certifications (ISO which?), I am clueless. I don't intend on preforming calibrations, I just want to provide inspection data. My target customers would be automotive suppliers and those who supply them (job shops, fixture builders, etc.), and possibly medical suppliers (absolutely no clue as to their requirements, but there are alot of them in my area). Let me add, that this is what I am doing already (contract CMM inspection), but now I want to be the boss. I believe that I won't have any problem making an ISO 9001:2000 compliant quality system, and would plan on becoming registered as $$ permits. Do I need or want to be ISO 17025 certified? After getting the equipment, I would be on a shoestring budget until business builds, so I would hate to waste time and money on cetifications that I wouldn't need. Do I need any certifications? My current employer is recently ISO 9001:2000, but it never seemed to matter when we weren't.
Thanks for any help or input!
Sponsored Links
Old 19th April 2002, 09:58 AM
Ryan Wilde's Avatar
Ryan Wilde Ryan Wilde is offline
Registration Date: Feb 2001
Karma Power: 41
Ryan Wilde is appreciated, and has over 100 Karma points.Ryan Wilde is appreciated, and has over 100 Karma points.
Default
Navin,
If you want to do business as an ouside testing service with any automotive suppliers that are QS9000 registered, you will have to be Accredited to ISO 17025, or at a minimum, the equivalency caveat that AIAG has built in. The bottom line is that you will have to have a ISO 17025 system in place that will be scrutinized by someone.
As far as medical suppliers go, all I've dealt with want you to be ISO 9000 registered, although if you are accredited to ISO 17025 you are, by default, compliant with ISO 9001:1994, but not the new ISO 9000:2000 version.
Taken from the introduction of ISO 17025:
<i>The growth in use of quality systems generally has increased the need to ensure that laboratories which form part of larger organizations or offer other services can operate to a quality system that is seen as compliant with ISO 9001 or 9002 as well as with this International Standard. Care has been taken, therefore, to incorporate all those requirements of ISO 9001 and ISO 9002 that are relevant to the scope of testing and calibration services that are covered by the laboratory's quality system.
Testing and calibration laboratories that comply with this International Standard will therefore also operate in accordance with ISO 9001 or ISO 9002.
Certification against ISO 9001 and ISO 9002 does not of itself demonstrate the competence of the laboratory to produce technically valid data and results. </i>
So, your non-automotive customers may fight against being Accredited to ISO 17025 without ISO 9000 registration, and it is up to you to either educate them or give in and be registered to ISO 9000 and accredited to ISO 17025.
Ryan
Sponsored Links
Old 20th April 2002, 09:35 PM
metrologyguy metrologyguy is offline
Registration Date: Mar 2001
Karma Power: 36
metrologyguy has less than 100 Karma points so far.
Thumbs up
I agree with Ryan, you should persue accreditation to ISO 17025, and I would further suggest going with A2LA.
As part of your start up research, I would do a search at www.a2la.org to see if there is a lot of compitition in your local area. If there is none, you will have a nice nitch in the market.
I would also recommend specializing on something you are good at inspecting and get known for it, e.g. forgings, stampings, complex parts, close tolerance work, big stuff or real small stuff.
Start learning uncertainty budgets for CMM's if you have not done so allready, this is usually a time consuming effort until you get the logic down.
On the business side of things you may need to line up a good CPA and start getting advise from local business owners about all the other stuff you will need to know. When I started my lab 15 years ago I knew it would take a lot of time and effort but it took a lot more than I thought it would.
If you do things well and all goes well it is a nice business.
Good luck!!
Old 22nd April 2002, 02:36 PM
Karma Power: 31
Default
After reading the responses, I realize I will definitely need the ISO 17025 certification. I could probably find work without certification, but it wouldn't be much of an inspection facility.
What is a CMM uncertainty budgets? Are you refering to maintenance and repair, or the quantity of CMM work ($$)? Thanks
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Measurement Uncertainty (MU) in Dimensional Inspection in a QC Laboratory qamer Measurement Uncertainty (MU) 2 14th June 2007 01:53 PM
Layout and Dimensional Inspection Training Satellite Training - Internal, External and Distance Learning 0 4th April 2007 09:35 AM
General convention used for dimensional inspection - 4x Accuracy? Teeker Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 1 9th September 2005 09:10 PM
Just accredited!!! CMM dimensional inspection laboratory jonny O ISO 17025 - Calibration, Measurement Gages and Test Laboratories 8 15th June 2005 11:07 PM
Looking for Dimensional Inspection Service e006823 Service Industry Specific Topics 15 8th June 2004 11:46 AM
The time now is 06:36 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
