The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > National and International Business System Standards > Quality Management Systems Standards > ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions
Forum Username
Wooden Line
ISO 9001 CMM Room Temperature Requirements
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Related Topic Tags
cmm (coordinate measuring machine), laboratory environmental conditions
Reply
  Post Number #1
Old 14th January 2011, 10:57 AM
ssccarpiello
Please Help! ISO 9001 CMM Room Temperature Requirements
Greetings All,
I am new to ELSMAR.com, I need a quick answer to this question... Where does it state in ISO requirements about monitoring and recording temperature and humidity for CMM/Inspection labs?
Regards,
Scott
Sponsored Links
  Post Number #2
Old 14th January 2011, 11:08 AM
howste's Avatar
howste
Re: ISO CMM Room Temperature Requirements
Hi Ssccarpiello, welcome to the cove.
If we assume you're talking about ISO 9001, it doesn't directly. BUT it certainly could be required based on this requirement:
In Reply to Parent Post by ISO 9001:2008
6.4 Work environment
The organization shall determine and manage the work environment needed to achieve conformity to product requirements.
NOTE The term “work environment” relates to those conditions under which work is performed including physical, environmental and other factors (such as noise, temperature, humidity, lighting or weather).
Sponsored Links
  Post Number #3
Old 14th January 2011, 11:40 AM
Golfman25
Scott, it doesn't. It will depend upon your requirements per 6.4. Don't add monitoring unless you really need it. Good luck.
  Post Number #4
Old 14th January 2011, 11:54 AM
ssccarpiello
Thanks for the prompt replies!!!!
It's not something we are looking to add to our requirements, one of our suppliers whom we just did an audit of has there CMM calibrated at 68 per OEM specs, if that machine needs to calibrated at that specific temperature wouldn't the accuracy of that machine be based on that temperature? and if so, would all this fall under 6.4?
  Post Number #5
Old 14th January 2011, 12:28 PM
howste's Avatar
howste
Yes, it would. In cases where measuring equipment is being used at significantly different temperatures than at calibration, correction factors should be applied. Also, the temperature of the part itself should be considered. Often, especially for close-tolerance parts, it's appropriate to allow "soak time" to allow the part to stabilize at temperature before measuring.
The AS9100 standard (ISO 9001 with additional requirements for aviation, space, and defense) clarifies with this additional requirement:
In Reply to Parent Post by AS9100 Rev C
The organization shall ensure that environmental conditions are suitable for the calibration, inspection, measurement and testing being carried out.
The Medical Device QMS standard ISO 13485 (also based on ISO 9001) clarifies with these requirements:
In Reply to Parent Post by ISO 13485
If work environment conditions can have an adverse effect on product quality, the organization shall establish documented requirements for the work environment conditions and documented procedures or work instructions to monitor and control these work environment conditions
Of course these aren't specific requirements of ISO 9001, but should be considered for guidance.
Thanks to howste for your informative Post and/or Attachment!
  Post Number #6
Old 14th January 2011, 12:42 PM
ssccarpiello
Howste,
Thanks for the information, It was very helpful in what I was trying to figure out. Should be good to go now...
Regards,
Scott
  Post Number #7
Old 18th January 2011, 12:50 AM
qualitymanager
Re: ISO 9001 CMM Room Temperature Requirements
Depends on which "ISO" standard you were auditing against.
The ISO/IEC 17025:2005 standard (for testing and calibration labs) has specific requirements for environmental conditions (see clauses 5.3 and 5.10.3.1).
If your company is ISO/TS 16949 certified, then (I believe) a lab supplying results to you has to be accredited to 17025.
Reply
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
NADCAP AC7108 - Tank Ambient Room Temperature Requirements robanbieber AS9100, Nadcap and related Aerospace Standards and Requirements 2 1st May 2015 09:16 AM
Limit for Temperature & RH in Pharma Clean Room raghu_1968 Qualification and Validation (including 21 CFR Part 11) 8 9th March 2010 07:37 AM
Mass vs. Temperature vs. Time - Determining Time in a Temperature Controlled Room djaphro Manufacturing and Related Processes 5 26th March 2008 06:41 PM
Controlling Temperature and Humidity in the CMM Room and does anyone use Artifacts? Jcowan - 2010 Inspection, Prints (Drawings), Testing, Sampling and Related Topics 8 29th February 2008 03:30 PM
Quantum Wires - Room temperature superconductors Marc After Work and Weekend Discussion Topics 0 17th April 2005 04:40 PM
The time now is 09:02 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
