Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
2nd February 2011, 09:47 AM
Shy Poster (1 to 5 Posts)
Registration Date: Feb 2011
Thanks Given to Others: 2
Karma Power: 10 Karma: 10
Complying with AS9102 when the supplier is using 3D Model Based Definition (3D MBD)
Does anyone know how to apply and conform with AS9102 when the supplier is using 3D MBD and defining/tracking production efforts in an electronic system? The current situation is that we are having to access multiple "points" in the MES, production planning and extract/print portions that are applicable to a paticular detail part. This process must be repeated for every part of the production planning where the part is modified and the multiple extract, print, compile process must be conducted for ever detail part.
In the past, this info was captured in a traveling QA form, so the current process (multiple extracts) is not that different, it's just that we haven't been able to realize any benefits from having MBD or electronic instructions. Has there been any industry research done on how this is handled. Any pointers or recommendations would be much appreciated.
3rd February 2011, 05:47 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,446
Karma Power: 400
Re: Complying with AS9102 when the supplier is using 3D Model Based Definition (3D MB
Any ideas on this folks? My Thanks in advance!
One Test is Worth 1000 Expert Opinions - The plural of anecdote is not data - Correlation does not imply Causation
Thanks to Marc for your informative Post and/or Attachment!
3rd February 2011, 10:22 AM
$ Contributor
Registration Date: May 2004
Thanks Given to Others: 108
Karma Power: 101
The requirement to complete an AS9102 is contractual and not required by any specification. AS9102 first article inspections are performed on completed product that will be shipped to the customer. The inspections required are to show compliance to contract, drawing and supplied technical specification of you customer. You should only be pulling information 3D MDB for requirements that cannot be directly measured or verified by the person performing the FAI.
AS9102 contains specific requirements for the FAI process and without complete knowledge of your product only general information can be supplied.
Thank You to Jeff Frost for your informative Post and/or Attachment!
5th February 2011, 09:03 AM
Thanks for your reply Jeff. What about if this is what the customer is requesting. Is there any easy way to to access multiple "points" in the MES, production planning and extract/print portions that are applicable to a paticular detail part. With this method it is easy to miss something. Are there any places to research on what other suppliers may do in similar situations that could be helpful. I have searched out on the net and have found nothing beyond the standard and requirements.
5th February 2011, 11:02 PM
$ Contributor
Karma Power: 101
Within you system you will need to indicate that an AS9102 is contractually required. You are required to bubble the actual customer documents (PO, drawing, specifications) and pull from you system the needed information to complete the FAI plus supporting certifications, test reports etc. It probably would be best if you talked with your IT person to see how you could do this.
I take it you have a copy of AS9102 and have reviewed the entire requirements front to back and then looked at your system to insert the FAI before shipment of product.
7th April 2011, 08:18 AM
Registration Date: Nov 2010
Karma Power: 11 Karma: 10
AS9102 was devloped for blueprint definition part's. I am personally having issues with applying a spec that relates to BP's to MBD's. The blocks that come into question are 5-8 on Form 1. I know there is some debate of what actually controls the part. And we are contractually bound to use this form.
Does anybody have a suggestion on these?
Forum Posting Settings
