Go Back   The Elsmar Cove Forum > National and International Business Standards > Customer and Company Specific Requirements
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 3rd May 2002, 12:52 PM
Jim Green Jim Green is offline
Involved in Discussions
Registration Date: Nov 2001
Thanks Given to Others: 1
Karma Power: 33
Jim Green has less than 100 Karma points so far.
Truce Run At Rate
We are a Steel Coil Processing facility. We take large coils and trim the mill edge off of the sides. So a coil 36" inchs wide weighing 30,000 lbs. may be trimmed to 35.5 inches wide.
This is my question. How do you do a Run-at-Rate on this process? I am not familar with that term.
Sponsored Links
Old 3rd May 2002, 01:19 PM
JRKH's Avatar
JRKH JRKH is offline
Involved - Posts
Registration Date: Apr 2001
Thanks Given to Others: 56
Karma Power: 95
JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.JRKH is appreciated, and has over 1700 Karma points.
Default
Not familiar with the term either. Can you elaborate a bit on where you heard it? And in what context?
James
Low tech is better than no tech.
The only constant is those who declare, "Things around here will never change!!"
Sponsored Links
Old 3rd May 2002, 02:08 PM
Al Dyer
Unregistered Guest
Posts: n/a
Default
Run at Rate is GM procedure GP-12, which is basically a production part run-off of XXX amount of parts that must have increased inspection requirements met before the sign-off.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 3rd May 2002, 02:27 PM
Karma Power: 33
Default
It is part of our process to do 100% inspection of every coil that is slit. That is where I get confused with PPAP. It seems that PPAP is structured for multiple pieces. Where sampling is involved. We have a big steel coil. That is inspected from lead to tail. We don't take sample measurements of coils, we measure every coil that goes through the line. I don't know how this Run-at-rate can apply??? Need guidance.
Old 3rd May 2002, 04:21 PM
Fran Fran is offline
Registration Date: Apr 2002
Karma Power: 31
Fran has less than 100 Karma points so far.
Default
Ford also has now "Run @ Rate" as a requirement for approving PPAP. It is a production trial. The purpose is to prove that your process produces parts with the quality required at the cycle time established. Usually, a small quantity of parts (in your case maybe only one coil) is produced with serial means, controls, operators, etc. at the cycle time foreseen. All controls included in the control plan are made. If everything is OK you can present the PPAP file to your customer with the results.
Basically, they want to avoid that you submit PPAP with parts made of prototype tooling or with any other condition that is not representative of series production.
Old 3rd May 2002, 05:42 PM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
DC-Ford-GM have their own totally different versions of run@rate.
Makes it tough when you do business with each OEM.
Sam Goody
Old 3rd May 2002, 05:47 PM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Read This! Will this help?
Look at :http://Elsmar.com/pdf_files/GM-ts16949.doc
which says:
Run at Rate (GP-9), (GM1960)
- Required for all new parts; physical verification that the production process is capable of producing quality products at quoted rates.
This is what I found elsewhere:
RUN @ RATE (GP-9)
DEFINITION: Physical verification that the production process is capable of producing quality products at quoted production rates.
PURPOSE: To reduce risk of failure during start up and acceleration by performing a production Run @ Rate beforehand.
SCOPE: All new part numbers require a Run @ Rate, unless exempted by the Supplier Quality and Purchasing Directors of the procuring division
PROCESS:
* Conduct risk assessment.
* Determine type of Run @ Rate required:
- Supplier monitored
- Customer monitored
* Notify supplier to schedule the Run @ Rate.
* Complete Run @ Rate.
* Follow up and make required improvements.
Note: GP-9 (GM -1960) last revision date is 2/95.
Old 3rd May 2002, 06:32 PM
Al Dyer
Unregistered Guest
Posts: n/a
Default
Atul.
I surely respect your opinion and posts, but early production contaiment for GM is GP-12, GP - 9 refers to GP-12:
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Negative coil set - Steel coil industry - Definition needed dbulak Definitions, Acronyms, Abbreviations and Interpretations 2 11th December 2008 12:43 PM
FORD Run at Rate (Run@Rate) Procedure oq_bru Customer and Company Specific Requirements 11 21st October 2007 05:38 AM
Coil Steel defects - Camber, coil break, crossbow, etc. - Industry standards? Jonell Various Other Specifications, Standards, and related Requirements 1 8th September 2004 06:42 AM
PPAP and Run @ Rate - We have a run at rate coming up soon for a visiting customer rotwang APQP and PPAP 1 12th October 2000 02:05 AM
QSR 3rd Edition, section II Run at Rate (run@rate) - What do they want? Richard Fillbach QS-9000 - American Automotive Manufacturers Standard 3 28th October 1998 12:41 AM
The time now is 10:05 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
