Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > Other ISO and International Standards and European Regulations
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 3.00 average. Display Modes
Old 8th May 2002, 09:44 AM
mcarter mcarter is offline
E-Mails Invalid or Rejected
Registration Date: May 2002
Karma Power: 0
mcarter has less than 100 Karma points so far.
Let Me Help You Defining what a Posted Work Instruction is
I have organizational responsibility for Document and Data Control. Our Production Manager wants the authority to "post" information in the production area. He has done so on many occasions. I'm concerned that some of these postings are "work instructions". In fact, the PM agrees that some could be defined as such. Some are even taken directly from documented SOPs! However, they are not "controlled" with revision leves/dates, nor have they been subjected to an "approval" process.
Two questions: 1) How does your organization define a Posted Work Instruction, and 2) Do you interpret the Standard as providing an organization with the discretion and/or lattitude to authorize an individual, such as a Production Manager, to post work instructions as described?
Sponsored Links
Old 8th May 2002, 10:14 AM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Default
There is nothing in the standard to say a PM cant issue documents (the standard is not that specific), but like you say they must be issued under the controlled conditions required by ISO9001. The PM can operate this control himself.
Sponsored Links
Old 8th May 2002, 10:37 AM
Claes Gefvenberg's Avatar
Claes Gefvenberg Claes Gefvenberg is offline
Forum Administrator
Registration Date: May 2000
Thanks Given to Others: 246
Karma Power: 213
Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.Claes Gefvenberg is appreciated, and has over 1700 Karma points.
Lightbulb Yes, they own the written procedures
Absolutley.... Our managers are the owners of the work instructions concerning their departments. As long as they follow our procedure for control of documents, I'm all for it.
/Claes
Hanlon's Razor.
Never attribute to malice that which can be adequately explained by stupidity.
User Groups: Elsmar Cove Cycling Enthusiasts Formula 1 fanatics Photo freaks Readers Corner
Old 8th May 2002, 11:59 AM
barb butrym barb butrym is offline
Courtesy Access
Registration Date: Dec 1998
Karma Power: 63
barb butrym is appreciated, and has over 100 Karma points.barb butrym is appreciated, and has over 100 Karma points.
Default local control
I typically recommend a part of doc control I call "local control' that allows excerpts, blow ups of an area of a drawing or diagram and posted memos, color coded assy stuff, WI or the like...to be controlled by the area supervisor etc..... i usually design a representative stamp or label for it that the controller/issuer fills in...ie the doc # and rev it was taken from ( or correct to, so if a rev changes and the info doesn't a detailed new color coded/blow up example doesn't have to be generated just a new label), who and when issued, exp date if required (not typically...but some times) and so on. detailed WI get a little closer to the normal doc control procedure with revisions. the stamp is designed for each company based on what they do......as is the verbage/rules
Old 9th May 2002, 11:07 AM
Laura-2002's Avatar
Laura-2002 Laura-2002 is offline
Registration Date: Oct 2001
Karma Power: 0
Laura-2002 has less than 100 Karma points so far.
Default
Work instructions are the responsibility of the originator as is the control.
It is up to the originator to ensure their work instructions are controlled in accordance with the data and document control procedure.
Old 9th May 2002, 01:10 PM
Mike S. Mike S. is offline
An Early 'Cover'
Registration Date: Mar 2002
Karma Power: 103
Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.
Default
I agree that a PM or area manager, etc. can post work instructions IF they maintain the required doc. control as per your procedures. This is perhaps the ideal situation as well. However, I have found that, especially in the infancy (maybe through the adolesence!) of a QMS often times these managers will "forget" or not follow the doc. control procedures (maybe they're too busy with the "important stuff"), resulting in the predictable chaos of poor doc. control not to mention audit troubles. They often like the "freedom" /"authority" of doing it but sometimes can't play by the rules.
One option is to train them well in the proper doc. control procedures and tell them they can do it on their own as long as they play by the rules. Then, formally or informally, audit them often until you are confident they pass muster. If they drop the ball, you have two choices: Report them to their superior if you think that'll do any good (in some cultures yes, in others, no). Or, take it from them, forcing them to go through you for issuance/change control etc. More work for you, unfortunatley, but perhaps less than dealing with the chaos when they don't behave. Then, perhaps later, when the QMS is more ingrained and mature (one hopes!) maybe they can take it back and do it right.
Just one of those many cases where sometimes the ideal doesn't work in the real world, unfortunately. JMHO.
Mike S.
Old 9th May 2002, 03:20 PM
choices choices is offline
Karma Power: 33
choices has less than 100 Karma points so far.
Default W/I, Notes etc.
Our policy is:
Anything related to "how you do your job" has to be controlled.
Below is in my W/I.
"Any individual page(s) removed from the document and placed at a site away from the controlled document shall be kept intact and controlled by the process number and revision. The person posting will document page(s) posted and their location on the front page of the controlled document. This will alert Document Control to update/ remove posted copies when changing over documents. The removed copies will be forwarded to the appropriate Engineer and the Engineer will update posted copy as deemed necessary and annotate on coversheet."
Michelle<who is the doc tech.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Work Standard / Work Instruction Template Example wanted P.Natarajan FMEA and Control Plans 3 3rd September 2009 05:54 PM
One Work Instruction or Multiple Work Instructions (WI's) necessary Jmcdonald870 ISO 10013 - Quality Management System (QMS) Manuals 13 24th April 2009 08:50 AM
Humorous work instruction - Relief Station Work Instruction Crusader Funny Stuff - Jokes and Humour 6 28th October 2008 05:53 PM
What are Work Instructions for? Company Owner doesn't like Work Instruction beaser3 Documentation Control Systems, Procedures, Forms and Templates 7 4th December 2007 05:18 PM
Work Instruction - TS 16949 - Is work instruction for packing and delivery mandatory sathis ISO/TS 16949 - International Automotive Quality Systems Standard 6 31st August 2005 02:24 AM
The time now is 02:03 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
