Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
9th March 2011, 05:16 AM
Shy Poster (1 to 5 Posts)
Registration Date: Mar 2011
Karma Power: 9 Karma: 15
DFMEA Detection Ranking in AIAG FMEA Manual 4th Ed. - Explanation wanted
Can someone explain the detection ranking in the new version of DFMEA i.e version 4.
what is the difference between testing for failure and degradation testing.
9th March 2011, 06:03 AM
Registration Date: Mar 2007
Karma Power: 26 Karma: 15
Re: Required Explaination on detection ranking in DFMEA
In Reply to Parent Post by manishpawar
Hello, I'm not familiar with the particular s/w package that you are using, however I have plenty of FMEA experience and the concepts are all the same.
Here's a simple explanation of the difference:
Testing for failure = When I turn the switch to the "on" position does the green light come on and does the wheel start spinning as it is supposed to. In other words challenging the device to confirm that it operates per specification as advertised to your customers.
Degradation testing = challenging the product to determine its reasonable life expectancy. An example, drug companies have to challenge their product to determine its expiry date, meaning the earliest date on which the product might no longer meet specification.
Hope this helps.
Larry
9th March 2011, 06:38 AM
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,947
Karma Power: 1429
In Reply to Parent Post by Larry Preuett
Larry,
The OP is referring to the AIAG FMEA 4th Ed. manual, not a software package.
The detection ranking table that he is mentioning is located on page 54.
Stijloor.
9th March 2011, 06:41 AM
Karma Power: 1429
Re: Need explanation on detection ranking in DFMEA 4th Ed.
What is the difference between testing for failure and degradation testing.
Testing for failure can be a destructive test on a part, sub system or system.
Degradation testing can be an accelerated salt-spray test to verify corrosion resistance.
Stijloor.
10th March 2011, 03:09 AM
Re: DFMEA Detection Ranking in AIAG FMEA Manual 4th Ed. - Explanation wanted
thanks larry for caring to answer,
but as stijloor says its not a software package,i am refering to the AIAG FMEA manual.
As u said stijloor the exercise of DFMEA is conducted for a automobile scissor jack.
can u explain it respect to a scissor jack,
the function is to lift the vehicle of a specified load to a specified height, with a max speciifed torque.
The jack is subjected to a test for a certain cycles (10000 cycles)for lifting and descent.
what can degradation test and testing for failure be in this case.
10th March 2011, 09:59 AM
Registration Date: Jan 2005
Thanks Given to Others: 1,779
Karma Power: 1445
In general, failure applies to primary function and degradation applies to diminished functionality. In other words, your scissor jack might fail completely, meaning it's no long capable of performing its primary function, or its function might diminish with continual use such that it will still perform its primary function but not as well as when new.
We aim to please. You aim too, please.
Thanks to Jim Wynne for your informative Post and/or Attachment!
11th March 2011, 02:08 AM
thanks jim
i will try to buildup the concept on yours and stijloor's inputs.
Will summarize it and post it the earliest.
Forum Posting Settings
