Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > FMEA and Control Plans
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 28th May 2002, 04:06 AM
Andrews Andrews is offline
Involved - Posts
Registration Date: Oct 2001
Karma Power: 39
Andrews has less than 100 Karma points so far.
Question Does the Detection rating have anything to do with Prevention?
If a particular problem of oversize is caused by tool becoming blunt and if periodic tool resharpening is the current prevention control for this particular cause and hourly monitoring is the current detection control for detecting the failure then what is the rating we should give for occurence?Doess the detection rating have anything to do with prevention?
Sponsored Links
Old 28th May 2002, 11:22 AM
Marc's Avatar
Marc Marc is offline
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,895
Karma Power: 605
Yin Yang
If detection is likely, your RPN will drop. Since you pretty well have it pegged to tool wear and are predicting the tool wear, I would expect a low RPN for that line item.
I can't give you an exact number for detection, but I would expect it to be low - 1 or 2 if it's that obvious.
Since it's going to happen, occurance rating would be high - say 9 or 10. The key will be your severity rating and your control.
Sponsored Links
Old 5th July 2002, 03:14 PM
Obi-Wan Obi-Wan is offline
Registration Date: Apr 2002
Karma Power: 31
Obi-Wan has less than 100 Karma points so far.
Default
If oversize (the Failure Mode) is caused by tool wear and periodic tool resharpening is the current
prevention control for the particular cause, then hourly monitoring is the current detection control for the cause. There may be also be controls in place which detect the failure mode (oversize hole). You asked, "what is the rating we should give for occurence?" Base Occurrence on production volumme between tooling checks coupled with how good the checks really are. (I'd wager it is not a 1.)You also asked "Does the detection rating have anything to do with prevention? No, it does not. Prevention controls reduce Occurrence.
Old 5th July 2002, 06:00 PM
Al Dyer
Unregistered Guest
Posts: n/a
Default
Occurance, prevention, and detection have no direct bearing on each other when "initiating" a FMEA.
During the process you might increase detection, big hairy deal, the part is already defective.
Prevention is the sole key in reducing occurance, but at what price??
Does the detection method offset the cost of the prevention method??
I would hazard a guess that prevention would win over detection in any process, therefore the FMEA.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
PFMEA rating - Occurence Rating and Detection Rating - Some clarification Chennaiite FMEA and Control Plans 8 9th September 2009 11:47 AM
FMEA - Prevention vs. Detection ckelloggjr FMEA and Control Plans 6 9th January 2008 07:13 PM
Occurence and Detection ratings - Will poka-yoke Prevention Control affect Detection? brutas FMEA and Control Plans 8 29th November 2006 01:15 PM
FMEA - What is the relationship between Detection and Prevention? QP Newbie question. jay_m FMEA and Control Plans 12 12th July 2006 09:32 AM
PFMEA Controls - Rating Prevention, Detection and Occurrance Jools FMEA and Control Plans 10 17th September 2004 05:49 PM
The time now is 04:48 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
