Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 10013 - Quality Management System (QMS) Manuals
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 12th June 2002, 08:48 AM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Default Process Measurement
I'm sure you guys can help my understanding on process measurement.
As we know the standard asks us to define our process, their sequence and interaction. It also asks us to measure the performance of our processes. Do we only measure the processes we define in our Quality Manual ?
For example we may define a process as 'manufacturing' but this process is made up of many seperate sub-process, some of which may not even inter-relate. Do we measure the performance of each sub-process, or just the main process defined in the Quality Manual ?
Sponsored Links
Old 12th June 2002, 10:02 AM
E Wall's Avatar
E Wall E Wall is offline
Just Me!
Registration Date: Jun 2001
Thanks Given to Others: 67
Karma Power: 63
E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.E Wall is appreciated, and has over 900 Karma points.
Default RE: Measurement
The measurement is how well you are meeting your goals and objectives set for the specific process (and how they support the overall goals/objectives of the QMS). There are going to be many different levels, to what degree you define them is up to you. The quality manual should identify all key processes used in the management system. Personally we're not listing all the sub-processes in the quality manual. We are putting together the key process outlines in which they refer to activities (which in some cases are sub-processes), but the objectives, goals and measureables are defined for the key process. In our case the process custodian has discretion of how to tract sub-process information so long as they can report on the key process measurables. If during review mgmt decides not enough information is being provided, they would get involved and may direct some sub-process metrics specifically.
Using your example of the manufacturing process -
QMS - Objective & Goal: Scrap Reduction (50% less than previous year avg)
Manufacturing processes -
Objective & Goal - 50% reduction in scrap CPU vs Forecast
Recently someone provided a good guideline for evaluating both process effectiveness and efficiency. I don't have time to search for it now, but will try later if it isn't already refered to by that time.
Catcha Later - Eileen
Sponsored Links
Old 12th June 2002, 10:17 AM
gpainter gpainter is offline
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.
Default
What do you want to do?
Old 12th June 2002, 10:28 AM
HFowler's Avatar
HFowler HFowler is offline
Involved - Posts
Registration Date: Aug 2001
Karma Power: 36
HFowler has less than 100 Karma points so far.
Martin,
IMHO if a process is critical to quality, then it makes sense to monitor and measure it. The standard allows flexibility in determining which processes to measure. Like gpainter says, "what do YOU want to do"? What will benefit your business?
Best Regards,
Hank
Insanity - believing results can be changed without changing the processes that create them.
Old 12th June 2002, 10:39 AM
Courtesy Access
Karma Power: 80
Default
Well I am kind of coming from the auditing angle again. If I walk into an area to audit and cannot see that the process has a direct measurment or monitoring going on is it non-compliant, or is it OK so long as there is a higher up measuring/monitoring going on ?
Old 12th June 2002, 12:53 PM
E Wall's Avatar
Just Me!
Karma Power: 63
Default Audit Angle...
Cannot measure compliance if there have not been requirements made. It is possible for a sub-process to be go/no-go or visually measured and that is all. If the manufacturing process in question is a sub-process it should be identified as such in the Key mfg process. There should (IMO) have been a determination of what is to be measured and how it supports the objectives & goals of the master (key) process. You'll probably need to be interviewing the process manager not an operator to get this level of detail. The real answer really depends on the specific situation.
Possible questions for the operators:
Who is/are your customer(s)?
- whether internal or external not only for the product but for information as well
What objectives and goals are expected for the product/service?
- even if not documented personnel should be aware of them
How is this measured and communicated?
- I would follow this up with whomever the information is reported to in order to see how it is used.
Old 13th June 2002, 04:53 AM
Chris May's Avatar
Chris May Chris May is offline
Registration Date: Mar 2002
Karma Power: 33
Chris May has less than 100 Karma points so far.
Default How well are you doing?
We have key processes and then sub processes that are defined by the nature of our business (Electronics Manufacturing). The key process monitoring is referred to in our QMS and the sub process monitoring refered to in our work instructions.
As mentioned, some of these are critical to quality and if not performed correctly, can cause major issues later in the internal customer chain.
We measure and monitor nearly all of the sub processes anyway, because, the earlier we catch a problem, the cheaper it is.
By measuring process parameters, the operators or process owners can honestly answer the question "How well are you doing ??
Now you have defined your processes:
What is the impact of not measuring a certain process ??
What are the defect opportunities for each process or sub-process??
As I said before, earlier is cheaper
Regards,
Chris May
Chris May's Avatar
Karma Power: 33
Regards,
Chris May
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Control of Outsourced Processes (not properly described in the quality manual) Edugar ISO 13485 - Medical Devices - Quality Management Systems 16 21st November 2009 05:15 PM
How do I show the Interaction of Processes in the Quality Manual referring to 4.1(b)? rickmel ISO 10013 - Quality Management System (QMS) Manuals 46 13th October 2009 06:52 PM
Core Processes - Are Core Processes really needed in the quality manual Intesar ISO 10013 - Quality Management System (QMS) Manuals 2 22nd December 2008 06:18 PM
Outsourced Processes - Not all identified in the Quality Manual fuji033 ISO 13485 - Medical Devices - Quality Management Systems 6 11th January 2007 02:29 PM
Processes in Design & Development - Have you Defined Manufacturing Process Designs? Roger Eastin Design and Development - Process and Product 11 28th October 2003 10:16 AM
The time now is 07:46 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
