A Peachfarm Internet Property
The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > General Metrology, Measurement Device, Calibration and Test Laboratories > Measurement Uncertainty (MU)
Forum Username
Wooden Line
Oscilloscope Measurement Uncertainties - MU Components for Vertical Deflection
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related Topic Tags
measurement uncertainty (mu), oscilloscopes, calibration (general topics)
Reply
  Post Number #1
Old 17th May 2011, 11:59 PM
EMacP
Please Help! Oscilloscope Measurement Uncertainties - MU Components for Vertical Deflection
Hi All,
Very urgent. Need your response. Currently my MU components for vertical deflection are type a and type b consists of upper and lower cursor, master std. However I think i missed out one more that is the minor division. However, how can i determine the value? Is there a specific formula? Please help me...
Sponsored Links
  Post Number #2
Old 19th May 2011, 06:25 AM
Stijloor's Avatar
Stijloor
Re: Oscilloscope Measurement Uncertainties - MU Components for Vertical Deflection
In Reply to Parent Post by EMacP View Post
Hi All,
Any Calibration/MU experts that can help?
Thank you!!
Stijloor.
Sponsored Links
  Post Number #3
Old 20th May 2011, 03:29 AM
Hershal's Avatar
Hershal
Oscilloscopes have unique uncertainties. Based on the description, I presume you are discussing a digitizer which has some uncertainties the same and some different than analog scopes.
Digitizer: First and most obvious is the trace width. That will affect the measurement just a little, even if you use the cursors. There is also parallax, which in truth is included with the trace width in a digitizer. Trace width is a rectangular distribution.
Calibration of the cursors is a huge help, but you have to take the uncertainty there as a normal distribution.
Applicable to both digital and analog:
Minor division is not a huge influence, but being between minor divisions is as that cannot really be accurately eyeballed. So take the minor division as the value with rectangular distribution, if you experience that.
Also, different input impedance may have an effect. For example, 50 Ohm, 600 Ohm, 1 MOhm.
If you are near the upper end on your bandwidth (BW) then there could be additional losses. For example, if you use a 50 Ohm coax above 400 MHz.
Watch rise time. The formula is .35 over T rise equals BW, or .35 over BW equals T rise. However, the ratio is not always perfect. Check both BW and T rise, then calculate to make sure you get the same results.
Analog: Hard to get any real reading under 2% due to trace, stability, bandwidth, and so forth, so just use an uncertainty value of 0.5% of reading and you should be OK.
Hope this helps.
  Post Number #4
Old 21st May 2011, 11:23 PM
EMacP
Hi Hershal,
I understand your reply. for your information the MU components involving Vertical deflection is as follow:
1. Type A
2. Lower and Upper cursor
3. Lower and Upper Parralax error
4. Specs/Uncertainties of standard use.
5. Vertical resolution ---- this is the one I am stuck with.
I will explain a little further, currently the digital scope is an 8-bit scope. This mean that there is 2^8= 256 steps level for the scope to sample. Let assume I set my scope at 1V/div and I am setting my source for a 6div=6V. My problem now is how to convert this to uncertainty? Any formulae???
So whoever has any idea, please assist me.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Looking for Practical Advice in Managing Measurement Uncertainties Rmack Measurement Uncertainty (MU) 3 15th April 2014 04:25 PM
MU (Measurement Uncertainty) for Oscilloscope Calibration syndrome Measurement Uncertainty (MU) 2 2nd October 2013 03:33 AM
Wavetek 9100 - Measurement Failure in Oscilloscope Section. Need Help & Advice. izmirli Measurement Uncertainty (MU) 5 28th September 2012 04:24 AM
Do we still need to Calculate Measurement Uncertainties (MU)? amanbhai Measurement Uncertainty (MU) 6 3rd August 2007 08:40 AM
Temperature Measurement Uncertainties - Verify a PRT at 0?C specified ?0.02?C celon General Measurement Device and Calibration Topics 4 12th November 2004 01:06 AM
The time now is 04:21 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
