Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Nonconformance and Corrective Action
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 20th June 2002, 06:52 AM
sneekparty sneekparty is offline
Registration Date: Jun 2002
Karma Power: 31
sneekparty has less than 100 Karma points so far.
Question Preventive and Corrective Procedures - Separate Procedures? Special Procedures?
Hello Everybody,
I wondered if anyone knows if you need to make a documented procedure for preventive and corrective actions or that describing it in the procedures for non-conformities and complaint handling is sufficient?
Hope any can help me, thanks again....
Martin van Zanten
Sponsored Links
Old 20th June 2002, 06:58 AM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Default
Sneek
These items do not have to be seperate documented procedures, you could roll them into one, but be sure that you have properly addressed the differences.
Sponsored Links
Old 20th June 2002, 07:46 AM
Karma Power: 31
Default Thanks, but....
Thanks,
But I still am worried about one thing. You said that I could roll them in to one, but that's just the problem I have described them in different procedures. An example is that I described in the non-conformities procedure that there have to be made corrective and preventive (if necessary) actions if there is a non-conformity.
Also an auditor I know said that we should have seperate procedures concerning preventive and corrective actions and that we then could refer to them in our flowchart for non-conforming products and complaints handling.
What's your opinion?
Thanks again,
Martin van Zanten
Old 20th June 2002, 08:13 AM
Courtesy Access
Karma Power: 80
Default
Well this is just an opinion, as it that of your auditor, however we currently have seperate documents.
The reason for this is that although all these processes have some interaction they do not all necessarily follow each other.
For example although an instance of non-conforming product may trigger a corrective action it also might not. If the root cause investigation identifies a special cause of the non-conformance corrective action might be appropriate. If however the root cause is considered common cause then you might not take corrective action on that instant, but put the data forward into your overall analysis process from which systemic corrective actions might be initiated.
Preventive action should perhaps almost definately be a seperate document as it is by nature not triggered by instances of non-conformance, but is a more analytical approach to never doing things wrong in the first place.
Old 20th June 2002, 08:50 AM
Russ's Avatar
Russ Russ is offline
Registration Date: Apr 2001
Karma Power: 42
Russ is appreciated, and has over 100 Karma points.Russ is appreciated, and has over 100 Karma points.
Send a message via AIM to Russ
Default
We also use seperate procedures for corrective & preventive action. I find it's better that way. Though the processes are similiar, keeping them seperate helps draw the line between corrective action and what can be preventive action. It took a long time to get it through everyones heads that if it's happened you can't use preventive action for things in the future, or similiar products. That's corrective action impact. Preventive action is tough but can be done after the mindset is established.
Old 20th June 2002, 09:48 AM
Karma Power: 31
Question Just one more question!
Thanks everybody for the quick response,
I think it's quite clear for me know. The best solution is that I make a preventive action procedure and describe the CA's in the different procedures were it is concerned.
Just one question: Does anyone have an example for me? If you don't want to post it on this thread just email me at info@sneekparty.com
Thanks again guys...I hope I can be of some help in the near future for you...
Martin van Zanten
P.S. Jim: Your Dutch is pretty good en Dank je wel...
Old 20th June 2002, 09:56 AM
gpainter gpainter is offline
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.
Default
Party, depending on the knowledge of your program you may want to have seperate procedures for CA and PA. This may help to distinguish between the two.
Old 22nd June 2002, 02:00 PM
anil2187 anil2187 is offline
E-Mails Invalid or Rejected
Registration Date: Mar 2002
Karma Power: 0
anil2187 has less than 100 Karma points so far.
Default
The triggering point to initiate Corrective action could therefore includeReactive elements)
Customer complaints
Non conformity reports
Internal Audit reports
other relevant analysis of Data(8.4)
Can we say that these inputs can never trigger a preventive action and therefore triggering points for
preventive actions should be entirely different such as : (Pro-active elements)
outputs from design review
Review of customer needs and expectations
lessons learned from past
Proa-actively fixed Quality objectives with smart targets
Management Reviews
Customer perception survey results
FMEA analysis
This means the procedure for 8.5.2 Corrective action and that for Preventive action 8.5.3
have to be entirely different in its approach.
As per clause 8.5.2 Organisation shall take action to eliminate the cause of nonconformities in order to prevent recurrence.
Can we not say in a generic sense that the cause of any non conformity be due to any one of the following case:
Ambiguity in System
Lack of system
Lack of effective processes
Weakness in the interaction of Processes
Lack of Training
Lack of Motivation
Sheer indiscipline
In such cases taking action to eliminate causes indicated above(generic in nature) as a corrective action is the
expectation of the standard as per 8.5.2.
Anilkumar.s
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
CAPA (Corrective Action Preventive Action) Procedures Separate or Combined RJFisher Nonconformance and Corrective Action 6 12th August 2009 04:02 AM
Example Corrective and Preventive Action procedures needed qualeety Nonconformance and Corrective Action 11 17th June 2009 09:07 PM
Are two separate procedures required for Corrective action and preventive actions abhinav_sj Documentation Control Systems, Procedures, Forms and Templates 38 23rd April 2009 12:18 AM
Combined Corrective and Preventive Action Procedures? lego55 Documentation Control Systems, Procedures, Forms and Templates 19 7th March 2009 02:13 AM
Corrective vs. Preventive Systems and Procedures - Separate Procedures? Marc Nonconformance and Corrective Action 12 17th July 2006 11:50 PM
The time now is 06:50 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
