The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis > Quality Assurance and Compliance Software Tools / Solutions > Using Minitab Software
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
data analysis, minitab (statistical analysis software)
Reply
Old 7th June 2011, 01:57 PM
enjoyneer enjoyneer is offline
Shy Poster (1 to 5 Posts)
Registration Date: Jun 2011
Karma Power: 8
enjoyneer has less than 100 Karma points so far.
Please Help! Intreprating a Data Set with Minitab - Help wanted
hi ...below some data is given please help me in interpreting......
no of cases analysed are 14.....
Regression Analysis: RI versus Fe(T), %FeO, ...
The regression equation is
RI = 350 - 3.91 Fe(T) - 2.18 %FeO - 4.63 %MgO - 307 %K2O - 172 %P
+ 4.24 Basicity - 0.910 MPS
Predictor Coef SE coef T P VIF
Constant 349.87 45.35 7.72 0.000
Fe(T) -3.9053 0.5386 -7.25 0.000 3.181
%FeO -2.1818 0.4434 -4.92 0.003 2.334
%MgO -4.626 1.791 -2.58 0.042 2.459
%K2O -306.91 49.69 -6.18 0.001 4.061
%P -172.18 67.17 -2.56 0.043 4.728
Basicity 4.240 3.127 1.36 0.224 4.300
MPS -0.9102 0.3350 -2.72 0.035 1.268
S = 0.802628 R-Sq = 97.5% R-Sq(adj) = 94.5%
PRESS = 17.8900 R-Sq(pred) = 88.30%
Analysis of Variance
Source DF SS MS F P
Regression 7 149.020 21.289 33.05 0.000
Residual Error 6 3.865 0.644
Total 13 152.886
There are no replicates.
Minitab cannot do the lack of fit test based on pure error.
Source DF Seq SS
Fe(T) 1 9.016
%FeO 1 30.366
%MgO 1 0.612
%K2O 1 71.800
%P 1 31.370
Basicity 1 1.100
MPS 1 4.756
Unusual Observations
Obs Fe(T) RI Fit SE Fit Residual St Resid
4 56.3 45.620 44.627 0.639 0.993 2.05R
R denotes an observation with a large standardized residual.
please also tell me the correct approach if you have any...........
Sponsored Links
Old 7th June 2011, 06:45 PM
Barbara B's Avatar
Barbara B Barbara B is offline
Number Cruncher
Registration Date: May 2005
Thanks Given to Others: 95
Karma Power: 79
Barbara B is appreciated, and has over 1700 Karma points.
Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.
Re: Intreprating a Data Set with Minitab - Help wanted
enjoyneer,
could you please share the data with us, not only the results? It will be far more easier to evaluate your approach and/or to develop other ideas for the analysis.
Thanks in advance,
Barbara
Thanks to Barbara B for your informative Post and/or Attachment!
Sponsored Links
Old 8th June 2011, 01:36 AM
steelejc15425 steelejc15425 is offline
Getting Involved (6 to 9 Posts)
Registration Date: May 2010
Thanks Given to Others: 8
Karma Power: 13
steelejc15425 has less than 100 Karma points so far.
Hi Enjoyneer,
I think Barbara's right that we need more information about your data set. From the representation of your predictors, %FeO, %MgO, etc., it looks like you may have a restricted range of potential values that you could use for predicting values of your response. Rather than Regression, Minitab might provide better tools if we define a custom mixtures design for you to analyze your data with.
With that said, I think that the first things to look at in the output you provide is the unusual observation. If it is important to describe or predict the data at the values for the predictors from observation 4, then we should really be worried about using the model that's been calculated.
You should also use Minitab to produce residual plots that might reveal problems with the model. If you used Stat > Regression > Regression to produce this output, then you can make residual plots by clicking the Graphs button and turning on the 4-in-1 plot. Patterns, outliers, or a curved normal probability plot could mean that the model doesn't describe the data well.
I'm assuming that you're including all of the predictors in your data. If you want to predict new observations, you might want to consider some subsets of these variables to see if you can get close to or better fit statistics (R^2, Press, S, etc.).
I think it would also be worth looking at the magnitude of the coefficients while you do this. These are essentially slopes--if the predictor variable increases by 1, the coefficient is the change the model predicts in the response. The size of the %K2O coefficient compared to FeO and MgO makes me wonder if perhaps only some of your predictors are have practical considerations. However, this depends on whether the units of the predictors are comparable, which would be easier to consider if, as Barbara suggests, we had the chance to see your data.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Attribute Data Gage R&R - Managing Data Sets - Minitab Hami812 Using Minitab Software 2 21st June 2011 10:08 PM
Test for Equal Variances - Two factor data set - Minitab N_Marine Using Minitab Software 3 29th September 2010 09:55 PM
Calculate Z-Score for Non-Normal Data - I have two set of data utkarshdoshi SPC Monitoring and Statistical Analysis Techniques 9 17th October 2009 07:36 AM
Gage R&R on Attribute Data Using Minitab 14 - Data from Automated Test Systems jatabe Quality Tools, Improvement and Analysis 2 12th December 2007 07:01 PM
Fitting an Equation to a set of data? Does minitab have the capability? JtHall Using Minitab Software 4 19th June 2006 01:15 PM
The time now is 10:19 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
