Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 1st July 2002, 12:48 AM
rikkyyee
Unregistered Guest
Posts: n/a
Please Help! Cpk calculation for short runs - Manufacturing FFC (flexible flat cable)
Anybody can advise
In our production we are manufacturing FFC (flexible flat cable) The product life cycle for a model is very short due a lot that contain 2000-4000pcs can be finished within 1 hour. everyday a prodcution line (total of 4) are schedule to run minimun 5 to 6 models, each model may only run a day only and may need to wait a week or a month later to run again. Hence the production is almost running dilferent model from day to day.
due to customer request only Cpk data the management are also only concern about it.
our current method are randomly select a model/line in a week and get 30 sample/lot to calculate the Cpk data. and we will use it as a reference for that week Cpk reference for all model.
this method not working very well because the Cpk data keep fluctuating from week to week.
pls give some advise
Sponsored Links
Old 1st July 2002, 07:49 AM
Al Dyer
Unregistered Guest
Posts: n/a
Lightbulb
Cpk values will fluctuate no matter the sample size. Try increasing your sample size and see of the fluctuation between the samples is consistant.
I think the main concern would be the trends in the Cpk values. Possibly set a target Cpk and react when the trend indicates you are running close to or below the target.
Also consider the variables when reviewing Cpk:
Time
Shift
Operator
Setup
Maintenance
Material
etc......
Sponsored Links
Old 1st July 2002, 08:13 AM
Dave W Dave W is offline
Registration Date: Aug 2001
Karma Power: 34
Dave W has less than 100 Karma points so far.
Default
Rikkyyee
Al is right,
There are 'confidence limits' for cpk. The larger the number of samples, the more confident you can be that the cpk value is actually correct (as you have captured more variation).
30 is actually quite a small number. For example, to guarantee that your cpk is actually 1.33 or above, you need to have calculated a cpk of 1.62 for your batch of 30. With 100 samples, this number drops to 1.47.
You should not be surprised if your calculated cpk values vary with 30 samples.
The other question is: are you confident that the same process variation affects all of your product groups in the same way?
Dave
Old 14th September 2002, 03:30 PM
Ravi Khare's Avatar
Ravi Khare Ravi Khare is offline
Involved - Posts
Registration Date: Dec 2001
Karma Power: 35
Ravi Khare has less than 100 Karma points so far.
Default
Thomas Pyzdek has described methods of Short Run SPC in his Six Sigma Handbook...just may prove useful.
He advises to focus on the process than the small/ short batch that gets over before you can start looking for samples. The process focus could consolidate together batches of different products passing through the same process.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Cpk Calculation - Tolerance to maintain 1.33 & 1.67 Cpk respectively gianni Capability, Accuracy and Stability - Process, Machine, etc. 20 24th July 2009 11:23 AM
Short Runs and Control Charts trainee SPC Monitoring and Statistical Analysis Techniques 3 6th February 2007 04:53 PM
PAPP on very short runs of very low volumes ( < 50) rrofkar APQP and PPAP 3 16th November 2006 04:19 PM
Precontrol and Process Capability - CNC Lathes that run small batches - Short Runs Steven Sulkin SPC Monitoring and Statistical Analysis Techniques 12 9th December 2002 02:36 PM
Short Run - Low Volume Cpk Calculation tohbin Capability, Accuracy and Stability - Process, Machine, etc. 10 20th February 2002 05:28 PM
The time now is 06:56 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
