The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Aerospace and Aviation Standards and Requirements > AS9100, Nadcap and related Aerospace Standards and Requirements
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
as9100 - aerospace quality management systems, certificate of conformance (c of c), nadcap ac7108, nadcap (nat'l aerospace & defense contractors accred. pgm)
Reply
Old 30th June 2011, 05:30 PM
ExpertResource ExpertResource is offline
Involved in Discussions
Registration Date: Dec 2006
Karma Power: 27
ExpertResource has less than 100 Karma points so far.
Nadcap parts: Cert. of Conformance (more than just the spec.)
I would like your opinion if you are a Quality Professional (ex: quality engineer, quality manager, lead auditor, registrar, and specially a Nadcap certified company).
Recently, one of our clients was critisized because the Certificate of Conformance issued with their processed parts (chemical processing) referenced more than just "meeting the manufacturing specification" stated on the purchase order.
The COC stated conformance to the (1) manufacturing specification, AND (2) AS9100 and Nadcap Chemical Processing requirements and (3) other customer specific requirement which were part of (3a) the P.O. and (3b) their supplier approval with that customer.
I consider that all of these (1 through 3b) are important as they all effect the expectations and contractual obligations between the supplier and the customer. The manufacturing spec and all other contractual obligations together govern the quality control.
Should a COC be specific only the the manufacturing specifiction as referenced in the P.O., or is it not also important to state conformance to all of the other customer specific requirements (such as other customer specific requirements beyond the spec., AS9100, Nadcap, etc.)? Feel free to elaborate. Thank you! David
Sponsored Links
Old 4th July 2011, 04:05 PM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,941
Karma Power: 1428
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Re: Nadcap parts: Cert. of Conformance (more than just the spec.)
In Reply to Parent Post by ExpertResource View Post
Should a COC be specific only the the manufacturing specification as referenced in the P.O., or is it not also important to state conformance to all of the other customer specific requirements (such as other customer specific requirements beyond the spec., AS9100, Nadcap, etc.)? Feel free to elaborate. Thank you! David
Can someone with this expertise help David?
Thank you very much!!
Stijloor.
Sponsored Links
Old 5th July 2011, 01:30 PM
SvanRaay SvanRaay is offline
Registration Date: May 2010
Karma Power: 15
SvanRaay has less than 100 Karma points so far.
I have worked at chemical processing houses most of my life.....but dont let that trick you into thinking I know what I am doing.
Without actually seeing the CofC you mentioned to review the verbiage, I would say they are going a bit overboard. They should be certifying the work done and anything spelled out by the PO or the plating specification (first article requirement, source inspection, actual thickness range, embrittlement relief times and temps), but the quality system definately does not need to be there.
the reference to Nadcap and AS9100 should be more of an advertisement on their certs (proudly proclaiming that the facility meets the requirements of these fine groups) but not necessarily certifying the parts to those requirements.
Thanks to SvanRaay for your informative Post and/or Attachment!
Old 6th July 2011, 01:27 AM
Karma Power: 27
SvanRaay,
Thank you for your reply!
Dave
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Optical Gaging Systems - Shadows, debris, etc. cause parts to measure out of spec fabiolag Measurement Uncertainty (MU) 7 8th January 2012 08:01 PM
NADCAP: The NEW Watchdog - Has anyone felt the wrath of NADCAP yet? Johnny Bollocks AS9100, Nadcap and related Aerospace Standards and Requirements 111 1st June 2011 02:23 PM
NADCAP Plater Lost its Accreditation - NADCAP bites us again silentrunning AS9100, Nadcap and related Aerospace Standards and Requirements 16 15th February 2011 06:11 PM
Nadcap - Any experience with young (inexperienced) Nadcap auditors? sorin Various Other Specifications, Standards, and related Requirements 4 30th October 2009 03:46 PM
Anyone know the GM Spec (i.e. GMP.PP.004) for the Delco Electronics Spec - M 9586-1 Frossinator Customer and Company Specific Requirements 7 5th December 2005 06:50 PM
The time now is 04:14 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, West Chester, Ohio 45069-1929
513 341-6272
