Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
14th July 2011, 08:32 AM
Getting Involved (6 to 9 Posts)
Registration Date: Dec 2010
Karma Power: 10 Karma: 10
Type 1 Gage R&R - Analyzing Run Chart and I-mR
Hi All, I'm new in this forum (first post actually), even if I read the forum I don't have an answer for this question.
I'm analyzing an appraiser to measure the airtight capability
I measured 20 times the same pumps.
Before starting the test I analyzed the values, not normal distributed.
The Run Chart tells me that there is an oscillation, (p-value 0,048) so I can suppose the process is instable.
The I-mR chart tells me that the process is under control, no problems.
How is it possible? I mean, is it possible a process to be unstable but under statistical control?
Thanks all for your reply
14th July 2011, 08:55 AM
Stop X-bar/R Madness
Registration Date: May 2002
Thanks Given to Others: 1,233
Karma Power: 445
Re: Type 1 R&R - analyzing run chart and I-mR
In Reply to Parent Post by Mr.Agi
For a process to be stable in traditional SPC using Western Electric rules, the data will randomly jump about the mean. So, the calculations may analyze the data and may not detect an actual oscillation, and calculate control limits no problem. In essence, it will appear to be in statistical control.
The issue is that the data does not tell the story, it illustrates the story. Or, in other words, it supports the theory not generates the theory. So, the question is: what is the theory? Should there be oscillation? Can it be explained? Is it truly oscillation, or some kind of measurement error? Bottom line, what are the variations of the process?
If we didn't care, we wouldn't share. That's why we're there.
14th July 2011, 12:38 PM
Registration Date: Jan 2003
Thanks Given to Others: 993
Karma Power: 320
Re: Type 1 Gage R&R - Analyzing Run Chart and I-mR
can you post your data?
Statistics without physics is gambling; Physics without statistics is psychics
Thanks to Bev D for your informative Post and/or Attachment!
15th July 2011, 06:38 AM
Thank you for your reply.
Here attached an excel file with data
15th July 2011, 09:16 AM
Karma Power: 445
Here are some charts to look at.
18th July 2011, 06:52 AM
I use software MINITAB to perform my analysis. The software gives me also a P-Value, so that I can accept or refuse an hypotesis. In the Oscillation case the P-Value is 0,048, so very close to 0,05. Maybe a lack of experience is the problem, the data actually seem random distributed. Thanks
18th July 2011, 09:59 AM
Karma Power: 445
Be careful with the 0.05 conclusion.
18th July 2011, 12:37 PM
Karma Power: 320
what is mbar?
Forum Posting Settings
