23rd July 2002, 05:40 PM
Registration Date: Jul 2002
Karma Power: 30 Karma: 10
When Do I Start FMEA? During project introduction?
Someone has asked me a question, When do i start an FMEA??, i have always gone on the basis when it calls for it during project introduction? maybe i am wrong!!
Many Thanks
Gareth Twena
23rd July 2002, 05:53 PM
Dogs rule
Thanks Given to Others: 15
Karma Power: 69
An FMEA (any level) should be begun as early as possible in the development stage of the product/process/service. When "properly" done, it is typically much cheaper to correct Failure Modes and/or their Causes.
If the FMEA is merely a "dog and pony show" document, it doesn't matter when it is put together.
There is no psychiatrist in the world like a puppy licking your face. - Ben Williams
23rd July 2002, 06:23 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 1,892
Karma Power: 604
See APQP Timeline
There are also some slides in The FMEA Process
24th July 2002, 07:12 AM
RE:
Many thanks. I was correct in what i was saying but it always helps to get a bit more advise.
24th July 2002, 07:53 AM
Send Martini's !!!!!!!
Registration Date: Feb 2002
Karma Power: 42
If you are going to use it as a tool, as intended, as early as possible. If it purely for PPAP compliance and will add no value to your operation, do it the night before the PPAP is due at home (not that I have ever done that.........................).
COMMENTARY: Don't spend hours contemplating whether the Severity is a 6 or a 7, etc., etc....... The big ticket items will rear their ugly head pretty easily. This can be such a good exercise when you don't get too wrapped up in the apparent intimidating format. Rots of ruck !
Operator Error cannot be the Root Cause. Oh, unless you're a Pilot.
24th July 2002, 08:34 AM
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
FMEA is principally a design tool used on both product and/or process design. It should be started as early in the design process as possible but obviously can only commence when you have a design 'proposal'.
