The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 17025 - General Metrology, Measurement Device, Calibration and Test Laboratories > Calibration Frequency (Interval)
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
gage blocks, rod standards (calibration), calibration (general topics), calibration standards and classes
Reply
Old 23rd August 2011, 11:16 AM
aliasJohnQ aliasJohnQ is offline
On Holiday
Registration Date: Jul 2009
Karma Power: 0
aliasJohnQ has less than 100 Karma points so far.
Question Calibration Standards - Rod Standards vs. Gage Blocks
If a company just has rod standards which is used for large micrometers, can that be used for other things during the calibration process?
Or does gage blocks take the cake?
Sponsored Links
Old 23rd August 2011, 12:59 PM
Jennifer Kirley's Avatar
Jennifer Kirley Jennifer Kirley is offline
Registration Date: Jan 2004
Thanks Given to Others: 2,982
Karma Power: 612
Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.Jennifer Kirley is appreciated, and has over 1700 Karma points.
Re: Calibration standards
Long Island Indicator Service has posted a calibration instruction that contains good information about what to use for calibrations of micrometers, etc., and how to go about it. I am not affiliated with Long Island Indicator.
The first issue with using rods is their traceability to NIST. Is that established?
The second issue is sensitivity. Are they calibrated with a 10:1 resolution or better? That is a general "rule of thumb" when using transfer standards to do an accuracy check.
The third issue is the recommendation to check calibration over a measurement range. This can be done by wringing gage blocks together - can you do that with your rods?
These three considerations are in general why I do not personally recommend calibrating with a rod, though a pin such as Deltronic may be part of the process IF it's kept quite safe from wear and damage.
How big are we talking about? I used to wring together gage blocks to calibrate 12 inch micrometers.
"If you only have a hammer, you tend to see every problem as a nail." Abraham Maslow
Sponsored Links
Old 23rd August 2011, 05:35 PM
Hershal's Avatar
Hershal Hershal is offline
Metrologist-Auditor
Registration Date: Mar 2004
Thanks Given to Others: 1
Karma Power: 265
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.Hershal is appreciated, and has over 1700 Karma points.
Re: Calibration Standards - Rod Standards vs. Gage Blocks
First question is: Used on what? If they are for large mics which is normal for end standards, there are few other things that have similar requirements such as calipers and so forth.
Second question: What is the uncertainty of the cal of the end standards? That will help determine if you can use them for anything else.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Gage Block Calibration Frequency Requirements velazedv Calibration Frequency (Interval) 20 16th January 2013 07:25 AM
Standards for Dimensions and Surface Finish on a Rod jmiller Definitions, Acronyms, Abbreviations and Interpretations 11 1st October 2011 10:43 AM
Primary vs. Secondary Standards - Are secondary standards acceptable for calibration? Gerald631 ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 9 2nd January 2011 03:17 PM
Gage Block In-House Calibration - Blocks lost and users keep exchanging blocks mhirand20 ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 2 17th November 2008 12:44 AM
Gage Calibration - Using a CMM and Gage Blocks for In-House Calibration Glen Hendricks ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions 1 29th June 2005 12:02 PM
The time now is 09:08 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
