Go Back   The Elsmar Cove Forum > Information Resources - Papers - Articles - Etc. > Definitions, Acronyms, Abbreviations and Interpretations
Elsmar Cove Forum Visitor Notices
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 4.00 average. Display Modes
Old 25th July 2002, 01:09 PM
Rosana Rosana is offline
Involved - Posts
Registration Date: Apr 2002
Karma Power: 32
Rosana has less than 100 Karma points so far.
Red Face Preventive vs. Predictive Maintenance - What is the difference? TS 16949 - 7.5.1.4.
what is the difference between Preventive and Predictive maintenance?
can someone explain this to me with an example?
Thank you
Rosana
Sponsored Links
Old 25th July 2002, 03:04 PM
Sporty's Avatar
Sporty Sporty is offline
Involved - Posts
Registration Date: Jun 2001
Karma Power: 38
Sporty is appreciated, and has over 100 Karma points.Sporty is appreciated, and has over 100 Karma points.
Default
Per ISO/TS16949,
Predictive Maintenance: activities based on process data aimed at the avoidance of maintenance problems by prediction of likely failure modes to prevent disruption of production.
Preventive Maintenance: action taken to avoid causes of equipment failure and unplanned interruptions to production.
Predictive would be looking at data and trying to predict what might go wrong, like a weld tip that fails at approximately 500 welds.....you would put in a program to replace weld tips at 450 welds.....
Preventive is a program, whether monthly, daily, yearly.....where you perform maintenance to keep your equipment running smoothly.....change oil, clean, etc....
I hope this helps.
Thanks to Sporty for your informative Post and/or Attachment!
Sponsored Links
Old 25th July 2002, 03:17 PM
Involved - Posts
Karma Power: 32
Default
Thank you for your help
Rosana
Old 25th July 2002, 03:28 PM
paulnguyen paulnguyen is offline
E-Mails Invalid or Rejected
Registration Date: Jul 2002
Karma Power: 0
paulnguyen has less than 100 Karma points so far.
Default
Hi Rosana,
IMO, both preventive and predictive maintenance are activities that involve inspection, repair if necessary, of a given subject.
The differences are how often and the sourced data that conclude the activity.
Predictive maintenance is resulted in known failure facts or historical failure data. From those data, we have known that the subject IS going to fail. and the frequency is set from there.
Preventive maintenance is regular frequency inspection activity set by recommendation, experience or common practice.
Example of this is the case of our car. Changing oil every 6 months and replacing tires every 80,000 Km are cases of predictive maintenace because we know that if we don't do that the car will give us trouble.
Checking the oil level every month (some cases, daily) to see if there is any leak, visual inspection on tires every morning to see if there is any nail, etc. is the case of preventive maintenance. Again, the frequency is based on each individual car condition, road condition in the driving area.
That was my thought, see if anybody has other opinions? or better way to explain it.
Paul N.
Thanks to paulnguyen for your informative Post and/or Attachment!
Old 25th July 2002, 03:38 PM
Dean P. Dean P. is offline
Involved - Posts
Registration Date: Jan 2002
Karma Power: 35
Dean P. is appreciated, and has over 100 Karma points.Dean P. is appreciated, and has over 100 Karma points.
Default
Paul,
I see it a little differently than you. Say you have a piece of equipment with a gearbox. You change the gearbox oil every 6 months to keep the oil fresh. This is preventive maintenance.
You also analyze the gearbox oil for the presence of metal each time you change it. You know that when you metal content reaches a certain point, it is time to replace the gears. This is predictive maintenance. Basically, predictive maintenance is something you can track on an X-Y graph, and look for a trend when there is a known point of failure.
In your car example, you rotate the tires every 10K as a preventive measure. You inspect and record the tread depth, and once you reach a certain limit, you replace the tires (this is predictive). Based on the data, you can predict the date of failure, and thus do your preventive maintenance before you get there. Does this make sense?
DP
An optimist believes we live in the best of all worlds.
A pessimist fears this is true.
Thanks to Dean P. for your informative Post and/or Attachment!
Old 25th July 2002, 04:34 PM
Karma Power: 0
Default
Hi Dean,
I've received your point about the analysis, study, trend to predict failure for the predictive maintenance activity.
It is still a little cloudy for me regarding the changing oil every 6 months to keep it fresh. From what source of data that the frequency of 6 month arises? Is the gear box still functioning normally if I don't (or I forget to) change it until 12 months later?
If there is a study on the oil vicosity and conclude that it needs to be changed on the gearbox at a given interval, wouldn't you consider it a predictive maintenance?
Or, maybe we are talking about 2 different cases. If there is a prediction based on study, historical data, that is predictive mainternance.
Regards,
Paul N.
Old 26th July 2002, 08:56 AM
Involved - Posts
Karma Power: 35
Default
That's how I see it, Paul. Preventive is something you do because you know that if you neglect it, things will go wrong (ie. changing your oil, greasing equipment). However, predictive is based on actual data, and can predict the exact point of failure, which allows you to plan you activites to avoid any downtime.
The 6 months timeframe is usually a 'best practice' as provided by the OEM, and may be based on data, however we are not collecting the data so it is a preventive maintenance that we do. If we sampled our oil and had it tested for viscosity, etc., and saw a trend in the data, then we could predict when we need to change the oil - predictive maint.
Either way you look at it, I think it is one of the areas that everyone has trouble with during an audit (at least we always did!). Good luck.
DP
Old 26th July 2002, 09:28 AM
Karma Power: 0
Default
Thanks, Dean.
Paul N.
Reply
Bookmarks
Tags
predictive maintenance, preventive maintenance, ts 16949
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to interpret TS Clause 7.5.1.4 Preventive and Predictive Maintenance? deminika ISO/TS 16949 - International Automotive Quality Systems Standard 8 24th October 2008 01:28 PM
Predictive maintenance vs Preventive maintenance Michiel ISO/TS 16949 - International Automotive Quality Systems Standard 3 13th February 2007 11:04 AM
Preventive Maintenance vs. Predictive Maintenance - Distinction between darkafar Definitions, Acronyms, Abbreviations and Interpretations 20 22nd November 2006 01:21 PM
Predictive vs. Preventive Maintenance - TS 16949 Clause 7.5.1 - Definitions of Stevenli Definitions, Acronyms, Abbreviations and Interpretations 32 15th September 2005 09:54 PM
QS-9000 Clause 4.9.g.1 - Preventive Maintenance - Tool Wear Predictive Maintenance Frank45 QS-9000 - American Automotive Manufacturers Standard 1 23rd September 1999 12:00 PM
The time now is 10:29 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
