Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 29th July 2002, 06:19 AM
rikkyyee
Unregistered Guest
Posts: n/a
Please Help! Cp, Cpk calculation for np chart - No USL or LSL - SMT Production
Hi all
Recently i am working in the smt production line which use np
chart to monitor the defect level. but i was requested to help
determine the Cp and Cpk for the process.
if i am not wrong for x-bar,R chart the formular are:
Cp = (USL-LSL)/(6 x sigma)
Cpk = min ((USL-mean),(mean-LSL)) / (3 x sigma)
but for the SMT production line there do not have any USL or LSL
so how we calculate the Cp and Cpk...??
pls advise. thank you
Sponsored Links
Old 29th July 2002, 10:47 AM
Rick Goodson's Avatar
Rick Goodson Rick Goodson is offline
Registration Date: Aug 2000
Karma Power: 42
Rick Goodson has less than 100 Karma points so far.
Default
rikkyyee,
Showing formula is always difficult never the less, the formula for the upper and lower control limits on an np chart is:
UCL = np-bar + 3*[square root of (np-bar*(1-p-bar)]
LCL = np-bar - 3*[square root of (np-bar*(1-p-bar)]
If after charting with the control limits all points are in control then the Cpk is equal to the process average.
A good reference for control charts is the Statistical Process Control (SPC) Reference Manual from the Automotive Industry Action Group (AIAG). The web site is http://www.aiag.org The cost of the manual is $30.00 for non members.
Rick Goodson
Sponsored Links
Old 29th July 2002, 01:48 PM
Al Dyer
Unregistered Guest
Posts: n/a
Question
I'm confused (as usual),
How can you determine a real Cpk without using spec limits? Given that is possible to be within control limits but still out of spec limits.
Cpk measures the centering of the process within spec limits, Cp measures the amount of process being used.
Could you put an arbitrary USL and LSL on an Np chart then use those to estimate capability?
Old 29th July 2002, 02:08 PM
Dave Strouse's Avatar
Dave Strouse Dave Strouse is offline
Involved - Posts
Registration Date: Oct 2001
Karma Power: 46
Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.Dave Strouse is appreciated, and has over 500 Karma points.
Default
rickyyee-
If you want a capability index, Cp or Cpk you must be given a specification. Otherwise, the question is capability to produce WHAT?
For attribute data, it is sometimes usefull to find the average ppm defective as per Rick's suggestion. The process should be in statistical control as he indicated and also you ought to examine the distribution by a histogram.
Given statistical control and that the distribution is relatively normal, you can convert the ppm defective into a equivalent sigma or "Z" value. This is the numerator of your formulas you want to use. Divide this by 6 for an estimate of Cp or 3 for Cpk. See "Advanced Topics in Statistical Process Control" Wheeler pages 191 to 196 for more on this.
However, would it not be easier to just report and compare the average per cent defective or ppm from the control chart? Why do you need or want a Cp value at all?
Old 29th July 2002, 02:38 PM
Al Dyer
Unregistered Guest
Posts: n/a
Default
I seem to remember that somewhere in the PDF files is a form that correlates PPM with capability. If I knew where I would post it, but try the search engine.
Anybody else with a better memory?
Old 29th July 2002, 04:14 PM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
Default
Al
In my opinion, as Donald Wheeler said (in advanced topics on SPC), the correlation between PPM and capability is a nonsense, because the distribution of the data must be a gausian ones ("normal"), even when the process is a stable ones. Wheeler recomend to count the point outside of the specification limits and show them as as %, insteed of going from capability to ppm with such tables.
But the problem still is after all "THERE ARE NO SPECIFICATION LIMITS" , so there could not be any ppm to correlate.
The recomendation is to fix the "Specification Limits" (could be yours, inside of the company, if the customer doesn´t have one).
Another way (there are some people that don't like capability index), is to chart it as a box plot to see the behabiur of the process tru the time.
I don't like it , but there is the table (page 14)
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Old 30th July 2002, 10:07 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
For attribute data;
capability % = 100(1 - (F + 0.7/N)) ,
Where F is the number of failures,
N is the sample size.
Juran Quality Control Handbook 4th edition
Sam Goody
Old 30th July 2002, 01:47 PM
Involved - Posts
Karma Power: 46
Default
Sam-
Maybe it's the limitations of the software in reproducing formulas, but the formula as given makes no sense.
It gives for a sample of 1 and 1 failure, a % capability of -70. For a sample of 100 and 50 failures the % capability is -4900.7. What could these mean?
I don't have a copy of Juran's 4th edition, but the 5th has nothing like this that I could find.
Is it maybe a transcription error?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Computing six sigma when the USL & LSL are varying patkim Six Sigma 16 8th June 2009 08:09 PM
Double-sided (USL, LSL) Variables sampling plan Z1.9 - Use in Excel spreadsheet? tdickson Inspection and Test, Sampling and Related Topics 2 7th June 2009 12:08 PM
Why is Cpk = lower of (USL-Xbar)/3sig & (Xbar-LSL)/3sig ? krishna_sadas Capability, Accuracy and Stability - Process, Machine, etc. 20 3rd July 2008 11:41 PM
What does the P/t ratio (Precision/Tolerance) =RR/(USL-LSL) say about my gage study? rderoeck Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 6 13th October 2005 03:08 PM
What does TCI mean? Test Capability Index = USL-LSL/6*sigma of the test only pfumvue Gage R&R (GR&R) and MSA (Measurement Systems Analysis) 4 23rd March 2005 02:43 PM
The time now is 01:26 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
