Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
18th October 2011, 10:33 AM
Getting Involved (6 to 9 Posts)
Registration Date: Sep 2011
Karma Power: 7 Karma: 10
Standard regarding the wear of Thread and Plug Gages.
HELLO,
I need very quick help..
Is there a standard regarding the wear of buffer sizes and threaded calibers?
Reason: Typo
18th October 2011, 10:46 AM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,442
Karma Power: 400
What do you mean by Buffer Sizes?
One Test is Worth 1000 Expert Opinions - The plural of anecdote is not data - Correlation does not imply Causation
18th October 2011, 10:57 AM
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,778
Karma Power: 1444
In Reply to Parent Post by ferkoattila
HELLO,
In Reply to Parent Post by Marc
And threaded calipers?
We aim to please. You aim too, please.
18th October 2011, 12:25 PM
Buffer size is the gray and the threaded is the green in the image below.
18th October 2011, 02:31 PM
Involved in Discussions
Registration Date: Jul 2011
Thanks Given to Others: 3
Karma Power: 10 Karma: 50
The "threaded calipers" would bre referred to as a thread plug gauge, and the buffers would be called a plug or pin gauge. Either one can be checked with a suffucuently accurate micrometer or CMM. They should go on a calibration schedule like anything else. Their wear rate will depend on how and how often they are used. As to how much wear is too much, the thread plug gauges will have a standard (2B is a common one I remember from automotive for something like what you have pictured, but you can look it up) and the pin gauges will depend entirely on what the tolerance of the part being evaluated is.
Thanks to bbarbee for your informative Post and/or Attachment!
19th October 2011, 02:02 AM
Re: Standard regarding the wear of Thread and Plug Gages.
In Reply to Parent Post by bbarbee
So ther is no standard for the pin or plug gauge reflective to the wear of the gauge?????
19th October 2011, 06:57 AM
Karma Power: 1444
If pin gages are worn to the point where their precision is no longer acceptable in the application, they should be replaced. The practical tolerance limits for pin gages are dependent on application so there is no general standard.
17th November 2011, 09:24 AM
Hello all,
Another question regarding for the calibration for pin gauges.
If i order a pin gauge and i recive calib. certificate, after is expire the certificate,
then I just make regular checks on them, and are not certified, it may be that the ISO 9001 auditor to disagree and ask my certificate, or is ok if I just record and regularly check whidout certificate. (definatly the gauges are used in production).
Forum Posting Settings
