Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
26th October 2011, 05:17 PM
Shy Poster (1 to 5 Posts)
Registration Date: Oct 2011
Karma Power: 7 Karma: 10
AS9100 8.5.2 g - Flowing Down Corrective Action Requirements to a Supplier
8.5.2 g
Flowing down corrective action requirements to a supplier when it is determined that the supplier is responsible for the nonconformity
Our external auditor has interpreted this clause to mean that every supplier caused rejection, internal and external warrant our company to issue an 8D corrective action to the supplier. Does this sound correct? Others have told me that this only means if we have an end customer rejection we flow the corrective action down to the supplier. If we reject something internally, prior to reaching our customer, and it is a supplier caused issue we have option to issue corrective action.
Any guidance would be appreciated.
26th October 2011, 06:15 PM
Moderator here to help
Registration Date: Jan 2006
Thanks Given to Others: 941
Karma Power: 474
Re: AS9100 8.5.2 g
In Reply to Parent Post by freebird_1974
8.5.2 g
If the supplier was the cause of a rejection that was found before it was sent to the customer, a company should take the necessary and required action. However, I would document somewhere (internal document like a Rejection Report or something similar) what action you took, even if you said "no corrective action is required at this time."
Question: How do you track the rejection rate from the supplier, and when do you determine when a Corrective Action is required? Do you maintain the records of rejection from suppliers and monitor their quality?
Just my thoughts.
"The one thing I want to leave my children is an honorable name." "It is hard to fail, but it is worse never to have tried to succeed." Theodore Roosevelt Chicago, IL, April 10, 1899
Thanks to Coury Ferguson for your informative Post and/or Attachment!
26th October 2011, 07:04 PM
Appreciated Member
Registration Date: Jul 2008
Thanks Given to Others: 619
Karma Power: 53
Re: AS9100 8.5.2 g
AS9100C Section 8.5:
The organization shall take action to eliminate the causes of nonconformities in order to prevent recurrence. Corrective actions shall be appropriate to the effects of the nonconformities encountered. A documented procedure shall be established to define requirements for…
g) flowing down corrective action requirements to a supplier when it is determined that the supplier is
responsible for the nonconformity,
AS9100 requires that a company define the requirements for flowing down to suppliers. It does not mandate or offer guidelines as to when your company “must” flow corrective actions down to suppliers. It says you have to have a defined system that says when, where, what, how, and with whom. Bottom line, you don’t have to issue a CA every time a nonconformance is discovered.
Also, 8D is not mentioned anywhere in AS9100. Did the auditor really say, "Issue an 8D corrective action to the supplier"?
None of the secrets of success will work unless you do. - Fortune Cookie
Reason: Fixed quote
Thanks to Hodgepodge for your informative Post and/or Attachment!
1st November 2011, 05:33 AM
Appreciated Member
Registration Date: Oct 2007
Thanks Given to Others: 131
Karma Power: 79
Re: AS9100 8.5.2 g - Flowing Down Corrective Action Requirements to a Supplier
8.5.2 g
For additional guidance (Clause 8.3)
Supply Chain Management Handbook (9.2.5) as a starting point.
Supply Chain Management Handbook.
Terms and conditions should also be clarified as to what is expected from a supplier (when there are NCR).
To your question - most auditor would interpret that requirement as it is stated - when a customer provides an NCR to you and it was done by the supplier, then they are part of the process to eliminate the NCR.
But more important...
Think about taking your system to the next level and monitor your suppliers even better - this will help you maintain a better grasp of good suppliers.
Reason: Added link.
3rd November 2011, 04:52 PM
Re: AS9100 8.5.2 g
We have a supplier management report card. Our current process if every supplier rejection requires an 8D corrective action.
11th November 2011, 04:11 PM
Thaumaturge
Registration Date: May 2003
Thanks Given to Others: 992
Karma Power: 485
Re: AS9100 8.5.2 g
If your process documentation states that every supplier rejection requires an 8D, then the auditor was correct to issue an NCR if there were cases when a supplier rejection occurred and no 8D was requested. This is coming from your own system and not what AS9100 requires though.
Thanks to howste for your informative Post and/or Attachment!
Forum Posting Settings
