Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Records and Data - Quality, Legal and Other Evidence
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 15th August 2002, 11:39 AM
dbzman's Avatar
dbzman dbzman is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 1
Karma Power: 37
dbzman has less than 100 Karma points so far.
Unhappy Document vs. Record - What's the Difference under TS 16949?
Under 4.2.3 Control of documents - records are said to be a special type of document.
I'm in the habit of keeping two control listings. One for records and one for document (intructions, SOPs, etc).
Under this definition if a document has data entered on it then it becomes a record.
Would it be better to just have one listing or is there another way to control records? Am I making this too complicated?
Sponsored Links
Old 15th August 2002, 01:51 PM
Ken K's Avatar
Ken K Ken K is offline
Registration Date: Jun 2000
Karma Power: 57
Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.Ken K is appreciated, and has over 500 Karma points.
Default
The way we separate the two is if we update or change a document it would require a revision change because it's controlled.
But, we also use various files and logs which are updated as part of normal operations without necessitating a revision change.
Both are considered part of our quality system.
Sponsored Links
Old 15th August 2002, 03:16 PM
db's Avatar
db db is offline
Where's the shall?
Registration Date: Jul 2001
Thanks Given to Others: 208
Karma Power: 129
db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.
Default Record vs document
Very good Ken! And if we change a record it is called an update, but the revision level doesn't change. Or does it? If I update a record, then the last entry could be considered the rev level, although it would not show on the master list, which gets back to your statement.
Dave B (the other Dave)
Old 15th August 2002, 07:37 PM
Al Dyer
Unregistered Guest
Posts: n/a
Cool
As my mind is, this may sound too simplistic:
If you change the info on a procedure, instruction, or form, there is a need for a revision.
A record is just that, a record. Do we revise records? I would not think so, revising records could lead to what has been going on recently in many corporations, If we don't like the results let's change the records.
If there is a record that is disfavorable it needs to be acted upon with some type of preventive or corrective action.
Just a thought!
ASD...
Old 5th June 2008, 12:19 PM
durnan durnan is offline
Shy Poster (1 to 5 Posts)
Registration Date: Jul 2007
Karma Power: 10
durnan has less than 100 Karma points so far.
Default Re: Document vs. Record - What's the Difference under TS 16949?
Document is the form in a blank state then it changes to a record when it is filled in.
the document would prob be stored on the hard drive on pc then when it is turned into a record prob filed away. Hope this helps.
Old 5th June 2008, 12:30 PM
dbzman's Avatar
Courtesy Access
Karma Power: 37
Hello everyone!
I am coming in on this discussion a little late but it looks like the question is “what is the difference between a document and a record”.
I look at this in a slightly bent way.
The way that I look at records vs. documents is this:
1. If I wanted to see how a job/activity was performed I would look at a record.
2. If I want to look at how a job/activity is to be performed I would look at a document.
Once data is placed on a document it becomes a record.
You would revise a document but not a record. You may update the information on a record (with signatures and dates) but not the revision.
Maybe I just oversimplify but that is my take on the difference.
James M. Warner
"Workaholic"
Old 5th June 2008, 12:40 PM
Helmut Jilling Helmut Jilling is offline
Auditor/Consultant
Registration Date: Aug 2005
Thanks Given to Others: 389
Karma Power: 188
Helmut Jilling is appreciated, and has over 1700 Karma points.
Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.Helmut Jilling is appreciated, and has over 1700 Karma points.
Whatever works best for you. Although, under the general principle of less is better, if you can comfortably do it on 1 log, so much the better. I have seen some companies do that by adding some columns for Retention Times and Storage and Disposal requirements to the right hand side of the log.
The main thing is control the stuff so the information is accurate, and it is available if some needs to read it. If you achieve that aim, you have met the ISO intent pretty well.
Relentlessly Pursue Excellence!
Reply
Bookmarks
Tags
ts 16949
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
The difference between a Document and a Record? David J Quality ISO/TS 16949 - International Automotive Quality Systems Standard 6 11th March 2009 07:53 PM
Difference between Record and Quality Record DAWELAH ISO 9001 - Quality Management Systems Standard 12 16th August 2008 11:11 PM
The Difference between a Document and a Record xiahmi Documentation Control Systems, Procedures, Forms and Templates 5 23rd March 2008 09:52 AM
The Difference between a Document and a Record - Training Plan D.Salman Documentation Control Systems, Procedures, Forms and Templates 11 23rd March 2008 06:53 AM
Document and Record Control - One Procedure or Two? TS 16949 jkittle Documentation Control Systems, Procedures, Forms and Templates 9 17th November 2006 12:57 PM
The time now is 07:55 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
