Elsmar Cove Quality DiscussionsDisplaying Multiple Graphs in the Same Plot with MinitabThe Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > > > >
Forum Username
Wooden Line
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links Elsmar Cove visitors will find useful in the quest for knowledge and support:
Jennifer Kirley's
Conway Business Services
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Ajit Basrur
Claritas Consulting, LLC
International Standards Bodies - World Wide Standards Bodies
AIAG - Automotive Industry Action Group
International Organization for Standardization - ISO Standards and Information
Quality Digest
Some Related Topic Tags
minitab (statistical analysis software), statistical analysis and studies, i-mr chart, control charts (general)
Reply
  Post Number #1
Old 3rd November 2011, 10:31 AM
angr76
Please Help! Displaying Multiple Graphs in the Same Plot with Minitab
I have two subgroups of data in Minitab 16. I'd like to plot the data in a control chart type, I-MR, and then have both graphs for the two subgroups in the same plot. They share the same X values, so I just want to overlay them. How do I do this?
Grateful for all suggestions!
Sponsored Links
  Post Number #2
Old 3rd November 2011, 01:43 PM
Miner's Avatar
Look! Re: Displaying Multiple Graphs in the Same Plot with Minitab
I have not found a way to do this in the Imr chart menu. You could manually create this in the Scatterplot menu, but it would be tedious.
  Post Number #3
Old 4th November 2011, 03:35 AM
angr76
Thanks for the reply. I thought it'd be tricky and appreciate that I wasn't too far off in my thoughts.
  Post Number #4
Old 4th November 2011, 07:38 AM
Allattar
Its not impossible and you have varying ways of doing this.
Easy methods,
create both charts call up the layout tool from the editor menu and put them on the same page. It does not overlay but you can display them side by side or one above the other.
They are I charts, so we can use a Time series. Go to the time series plot, choose multiple, enter both columns. Job done
The data must be in seperate columns to display correctly.
You can add reference lines to put the control limits on, if by some lucky chance they share the same values for UCL and LCL.
Complex method.
This wont work for I-MR only I charts. The following only works for graphs that can update, but you can use if for anything.
Create both I charts.
Select one chart and edit the background and data colour to be none. For easy aligning of the charts delete the control limits lables and centre line labels.
Select the chart that you have not fixed the background as none. Go to editor and copy command language.
Open up notepad and paste this into notepad
Select the second chart, the one with the background and data region set to none. Go to Editor and copy command language.
Paste this under the commands for the first chart.
At the top of the notepad file before the graph commands type LAYOUT, at the end after all commands type ENDLAYOUT.
Copy all the text and in Minitab press CTRL+L to call up the command line editor. Paste the text in and run the commands
The graphs will be overlaid. But they probably dont line up very nicely.
You can add a DATA subcommand to specify data region positions within each set of commands for a chart.
For example
Data 0.1615 0.9531 0.1797 0.9115;
added amongst the graph commands specifies the size and location of the data region. You can fix this to the same value for both charts to ensure the data regions are the same.
You probabaly want to remove the Y axis labels as well on each chart to tidy it up.
Its possible to then save these commands in a macro for future use as well.
Personally I would run the time series plot unless it was really essential to use the I chart.
Thank You to Allattar for your informative Post and/or Attachment!
  Post Number #5
Old 12th November 2011, 04:25 AM
fjexpo
I prefer put background as "none" (for any graph and send to Power Point / Word. There you can move, fix, etc. Previously you can set Y axis to be fixed manually, not automatically in order to control and fix the Y scale.
Best regards,
Javier
In Reply to Parent Post by Allattar View Post
Easy methods,
Complex method.
For example
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Emoticons are On
[IMG] code is On
Similar Discussion Threads
Customizing the order in which the graphs are printed in Minitab question tbrunink Software Quality Assurance 1 16th September 2011 02:52 PM
Refreshing Graphs and Minitab Templates pjkbd Using Minitab Software 5 2nd September 2011 04:21 AM
Weibull Plot With Minitab QE Using Minitab Software 1 2nd November 2009 05:11 AM
Displaying Date and Day in Minitab Michaelk Using Minitab Software 3 23rd December 2007 12:05 PM
How do I get 4 Graphs per Page? Multiple Capability Histograms that span 5 pages Coolboy55 Using Minitab Software 3 24th August 2007 12:36 PM
The time now is 03:32 PM. All times are GMT -4.
Misc. Internal Links
NOTE: This forum uses "Cookies"
The Elsmar Cove is currently owned by the Marc Smith Retirement Trust and operated by Law-Nutz Wyoming©2018
