Go Back   The Elsmar Cove Forum > Information Resources - Papers - Articles - Etc. > Definitions, Acronyms, Abbreviations and Interpretations
Elsmar Cove Forum Visitor Notices
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 18th August 2002, 07:39 AM
felixgh felixgh is offline
Registration Date: Apr 2001
Karma Power: 36
felixgh has less than 100 Karma points so far.
Let Me Help You Process Capacity and Over Adjustment - Definitions
Hi!
I need some good definitions for "process capacity" and "overadjustment".
Thank you in advance.
FG
Sponsored Links
Old 18th August 2002, 12:06 PM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Default
Felix
I have not heard the term 'process capacity', do you mean 'process capability' ?
'Overadjustment' could be defined as adjusting a process to correct an 'out of specification' reading such that the process is then 'out of specification' at the other end of the specification range. i.e. if I am turning down a diameter on a shaft, and I monitor my process my measuring the shaft od I might measure 9.5mm against a spec of 10mm +/- 0.1mm and therefore adjust my machine offsets such that the next piece produced is 10.5mm - again out of spec.
This can occur more subtely where a decision is taken to adjust a process based on a process reading that is actually indicative of the capability of the process, and doesnt actually require the process to be adjusted. Correct use of run charts should eliminate such problems.
Sponsored Links
Old 18th August 2002, 03:32 PM
Karma Power: 36
Default
M Greenaway,
Thanks for your reply. You are right, I mean 'process capability'.
¿Any definition?...
Felix
Old 18th August 2002, 04:14 PM
Atul Khandekar's Avatar
Atul Khandekar Atul Khandekar is offline
Forum Administrator
Registration Date: Mar 2000
Thanks Given to Others: 83
Karma Power: 90
Atul Khandekar has disabled his/her Karma.
Send a message via Skype™ to Atul Khandekar
Default
Process Capability: Definition and more:
http://www.symphonytech.com/articles...capability.htm
You are never given a wish without also being given the power to make it true. You may have to work for it, however. ~Richard Bach
Old 19th August 2002, 05:14 AM
Courtesy Access
Karma Power: 80
Default
Jim
Yes, this statement is so wooly I am sure it will be poorly implemented. I think it should be a statistical measure of process capability - this is what I believe is key to the 'process approach' loosely defined in ISO9001, i.e. not drawing pretty pictures of process models, but understanding process performance, variation and causes of variation, and utilising statistical methods for this.
Just my opinion though......
Old 19th August 2002, 10:15 AM
db's Avatar
db db is offline
Where's the shall?
Registration Date: Jul 2001
Thanks Given to Others: 208
Karma Power: 129
db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.db is appreciated, and has over 1700 Karma points.
Default Process Capability
When in 8..2.3, ISO 9001 talks about demonstrating "the ability of the processes to achieve planned results" is it talking, do you think, of process capability as commonly understood?
Living in the shadow of the B3, this has always seemed to mean CpK and such. However, not all processes are suitable for this type of study. TS, goes as far as calling them “process studies” (8.2.3.1) which supports CpKs. On an ISO system, as you say Jim we need to think beyond process capability studies. The key, IMNSHO is to determine if your processes meet plans. Also, don’t just think production…consider all your processes that can affect customer satisfaction.
Dave B (the other Dave)
Old 19th August 2002, 10:20 AM
Courtesy Access
Karma Power: 80
Default
db
What sorts of processes would not be suitable for such a study ??
Old 19th August 2002, 10:55 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
MG,
Processes that require only visual inspection as a means of acceptance.
Sam Goody
Reply
Bookmarks
Tags
capacity analysis, definition, process capacity
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Pre-Control Chart to guide in-process inspection / adjustment decisions Don Watt Inspection and Test, Sampling and Related Topics 43 28th November 2008 01:45 PM
Capacity Utilization - How to do a capacity utilization project Andy_80 Six Sigma 2 4th June 2007 06:24 PM
Availability - Measurability - Manufacturing Process Capability - Definitions xxxmanxxx Definitions, Acronyms, Abbreviations and Interpretations 1 6th March 2006 11:25 PM
Process Capability (Cp and Cpk) - Definitions Marc Definitions, Acronyms, Abbreviations and Interpretations 0 25th July 2005 03:01 AM
Parallel Process - I found two Definitions - Which is correct? MarkJoel Definitions, Acronyms, Abbreviations and Interpretations 6 24th November 2004 10:08 AM
The time now is 12:41 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
