The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > National and International Business Standards and Requirements > Food and Drug related Topics > Qualification and Validation (including 21 CFR Part 11)
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
centrifuges, iso 15189 (medical laboratory qms requirements), measurement uncertainty (mu), qms (quality management system), refrigerators, scales and balances, uncertainty (aka mu - related to calibration), calibration (general topics)
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
Old 21st November 2011, 03:44 AM
Kelukelu Kelukelu is offline
Shy Poster (1 to 5 Posts)
Registration Date: Nov 2011
Thanks Given to Others: 3
Karma Power: 7
Kelukelu has less than 100 Karma points so far.
Send a message via ICQ to Kelukelu
Please Help! ISO 15189, QA & how to calibration for Balance, refrigerator and centrifuge?
I have some problems, because I'm going to write for WI.
1.Is it any international standard calibration procedure for Balance, refrigerator ,centrifuge and others?
2. Can I test equipment using the development method that by myself ? (just simple measuring, not like use the hysteresis check, precision, accuracy...etc)
3. Is it correct for the uncertainty formula ?
Uncertainty and standard deviation:
*Uwr =Maximum standard deviation of reading x coverage factor ( 95% confidence)
*Ubr=Instrument uncertainty x coverage factor ( 95% confidence)
*Uc = √Uwr^2 + Ubr^2
e.g.
The acceptance criteria:
speed +-10% of the display
4. What is the role of QA ? Is QA double check the equipment or just verification for the test procedure to match the document (WI).
Or can it the test request one technician only , not need other technician to verification?
The more details for procedure (reference others company) and calculation as below
Balance :
Full calibration : off-centre loading, hysteresis check, precision and accuracy ( Departure from Nominal value).
Half year: precision.
daily: scale value check
each weighing : zero check
Temperature controlled enclosure
- nine point test for two years,
- centre point test for six month
Centrifuge:
Take 10 more reading.
Thank you very much.
Sponsored Links
Old 22nd November 2011, 03:16 AM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,970
Karma Power: 1437
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Re: ISO 15189, QA & how to calibration for Balance, refrigerator and centrifuge?
In Reply to Parent Post by Kelukelu View Post
e.g.
Balance :
Centrifuge:
A quick bump.
Can someone help?
Thanks!!
Stijloor.
Sponsored Links
Old 5th December 2011, 08:00 PM
v9991 v9991 is offline
Appreciated Information Resource
Registration Date: Jan 2009
Thanks Given to Others: 93
Karma Power: 82
v9991 is appreciated, and has over 1300 Karma points.v9991 is appreciated, and has over 1300 Karma points.v9991 is appreciated, and has over 1300 Karma points.v9991 is appreciated, and has over 1300 Karma points.v9991 is appreciated, and has over 1300 Karma points.v9991 is appreciated, and has over 1300 Karma points.v9991 is appreciated, and has over 1300 Karma points.v9991 is appreciated, and has over 1300 Karma points.v9991 is appreciated, and has over 1300 Karma points.v9991 is appreciated, and has over 1300 Karma points.
Lurker Re: ISO 15189, QA & how to calibration for Balance, refrigerator and centrifuge?
for balance at-least there are couple of references...
apart from pharmacopoeia...
http://ts.nist.gov/WeightsAndMeasure...Procedures.cfm
http://www.epa.gov/pesticides/method...s/QC-05-03.pdf
http://www.epa.state.il.us/water/wat...r-temp-sop.pdf
http://gmponblog.vinvarun.biz/2008/0...-balances.html
http://www.research.usf.edu/cm/SOP's...oring_7_08.pdf
(not all of them are traceable!!!)
for refrigerator... apart from simple verification of temperature against set value(acceptance criteria depends on the purpose/usage of refrigerator); a study of annual(periodic) mapping(with load and without load) of temperature zones using a data logger (multiple probes) is recommended.
for centrifuge, again is specific approach, (is it Temp. controlled, pre-programmable..etc.,) depending on features, it will bring in simple set-value verification of temperature and timer; to an extreme of plc controls qualification.
2.Can I test equipment using the development method that by myself ? (just simple measuring, not like use the hysteresis check, precision, accuracy...etc)
not sure whether u want to avoid hysteresis or else do you want to develop some inhouse method; in either case they have to be justified to specific equipment and application/usage of it.
as per performing calibration using that inhouse method, traceability of standards have to be maintained.
4.What is the role of QA ? Is QA double check the equipment or just verification for the test procedure to match the document (WI).
i believe QA role in routine activities is that of verification and ensuring compliance to procedure; the activity of double check(/verification) could be employed through a accountable/second person from same function. (if QA becomes part of this step, then periodic audit/review would have to be assigned to independent person!!! right?)
about repeat/redundant testing, is not a good idea, (it may also mean that defining a procedure for scenario of handling failures in either of the proposed duplicate testing etc., instead it would be good idea to make the initialtesting itself pretty robust-sensitive-depth)
unless you have specific scenario... (dynamic environment, sensitivity, instrument performance etc)
Balance :
Centrifuge:
its desirable to have justification&relevance to your operations-purpose of use of equipment;
note : above comments based on general pharma/QA experience. hope they are relevant to iso as well.
Last edited by v9991; 5th December 2011 at 08:12 PM. Reason: for got to add note...!
Thank You to v9991 for your informative Post and/or Attachment!
Old 5th December 2011, 09:01 PM
BradM's Avatar
BradM BradM is offline
Forum Administrator
Registration Date: Sep 2006
Thanks Given to Others: 1,309
Karma Power: 400
BradM is appreciated, and has over 1700 Karma points.
BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.BradM is appreciated, and has over 1700 Karma points.
There are several procedures available for each of these instrument groups. For balances, there is Handbook 44. If these balances are used in GLP setting, you will need to address the precision as specified in USP 41. I'm not sure about international standards for refrigerators and centrifuges. Primarily, I think it would depend on the instrument. If the equipment have indicators, they can be verified for accuracy. Otherwise, some level of maintenance/ verification would need to be defined for the equipment.
It depends on the equipment, what you will be using it for, and the level of risk. I would be leery to suggest abbreviated testing, without knowing the equipment history and use.
Well... that's kind of a loaded question also. It would depend on your process and what activities the QA function are engaged in. It really does all depend. There are some technicians performing highly automated work using controlled data capturing system, that may not require any QA intervention. Others might require review. It's really difficult for me to say.
Balance :
Again, it would depend on the risk exposure for the balance and to me, it's history. If it is a new balance with auto-balance/auto-calibration, the level (and frequency) of checks would be far less than the older balance that tends to drift. I like how you have more in-depth verification less frequently. Again, all those intervals really depend on the equipment history and process requirements.
Centrifuge:
For these, I'm really unsure. Your # of test probes seems to suggest a standard size enclosure. The # of probes for a benchtop oven will be different than those required for a large steam sterilizer.
Now, 75 years later in an abundant society where people have laptops, cell phones, iPods and minds like empty rooms, I still plod along with books. ”
—Harper Lee
Thanks to BradM for your informative Post and/or Attachment!
Old 5th December 2011, 09:09 PM
BradM's Avatar
Forum Administrator
Karma Power: 400
It seems to me (I'm really unsure here...) that maybe the attempt is to develop a calibration approach, and apply it to the equipment. That's pretty good for some situations and things.
However, I would think that you should let your process help develop your requirements. Has any of this equipment been qualified as part of a validated process?
For a start, I would develop a master sheet/equipment sheet/ master record/ or whatever terminology or such that you choose. It should list what the equipment is, what it is used for, validated parameters (if they exist), and what the use is of the equipment.
After you gather this information and production and such agree as to it's use, then you can ascertain what level of verification, what test points/tolerances, and what frequency is needed.
Then, you need to keep track as to how the equipment is performing. If the equipment is passing tests with little/ no error (as a % of tolerance), then you might can relax how often you verify it.
My apologies that I have provided generic/evasive responses. I would just hate to suggest something that works well for the process I'm involved with; only for it to be a dismal failure/excessive/ not comprehensive enough for your failure.
If all else fails, an alternative for the balances might be to find a competent lab to calibrate them for a while. They will have the proper training and equipment to check them correctly, and can assist you in developing a trend history on the balances and such.
—Harper Lee
Old 6th December 2011, 01:40 AM
Karma Power: 7
Thank you for your comments! I write these comments for the maintenance of a great help!
In fact, I mentioned to the test methods, reference to an international committee; its such a great organization and a long history.
The committee is too prestigious, to some extent be regarded as a leader, and they took ISO 15189, so I just follow their testing methods rather than established test method by myself.
But the method they used is a bit esoteric,as uncertainty calculation and academic approach, so I hope here looking for some simple and practical way.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Temperature Calibration for a Storage Refrigerator sh.samir ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 5 3rd January 2012 11:49 PM
Health Informatics ISO 11073 - Centrifuge Device Requirements Bassman84 EU Medical Device Regulations 1 7th December 2011 10:48 AM
Sorvall 100S Centrifuge Calibration - SOP (Method and Procedure) Needed MetroBioCen ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 5 27th May 2011 11:43 AM
Operating Range & Calibration for Analytical Balance v9991 ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 3 22nd October 2010 04:01 PM
Centrifuge Calibration using Photo Tachometer - SOP Needed Mohammed Gouda ISO 17025 and related Metrology Topics - Measurement Devices, Calibration and Test Laboratories 8 22nd December 2009 09:05 AM
The time now is 10:48 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
