The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > Inspection, Prints (Drawings), Testing, Sampling and Related Topics
Forum Username
Wooden Line
What is an Inspection and Test Plan? Construction Project
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Related Topic Tags
concrete (general), construction (general), inspection methods and plans, testing (general testing topics), test methods and procedures and plans
Reply
  Post Number #1
Old 23rd November 2011, 08:05 AM
kev4791's Avatar
kev4791
Question What is an Inspection and Test Plan? Construction Project
We have been asked by a new client to develop and submit an 'Inspection and Test Plan' for a medium sized construction project involving concrete works and steelwork for a new large shed.
Any clues on how to do this or an example to use as a template to develop from???
Any help gratefully accepted.
Thanks.
Kevin
Sponsored Links
  Post Number #2
Old 23rd November 2011, 08:17 AM
harry
Re: What is an Inspection and Test Plan? Construction Project
Check our post attachments list for samples - inspection & test plan
Thanks to harry for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 23rd November 2011, 10:00 PM
Hershal's Avatar
Hershal
Don't forget to review the Codes in the UK, you don't want to overlook an important test or inspection requirement that may be directed by the Codes.
  Post Number #4
Old 16th September 2012, 12:05 PM
qmsboy
It is not big deal like complex mathematical formulas!First you have to identify the extent of inspection and it's acceptance criteria from the scope of work and client specifications.Acceptance criteria you can find from your client's specifications otherwise specifications may lead to international standards like ASME(American Society of Mechanical Engineers),ASTM(American Society for Testing Materials),AWS(American Welding Society),API(American Petroleum Institute),MSS-SP(Manufacturers standardisation Society), EN(European Norms), AS (Australian Standard), JIS (Japanese Standard) etc.From there you can find acceptance criteria.Make columns on an excel work sheet according to the following order,Serial No.,Description of Activity,Reference documents, Nature of Inspections,acceptance criteria,Responsible person,Verifying documents/QC Record,Scope of inspection points(ie, each parties including contractor,client,third parties involvement like witness,hold,document review or surveillance etc).put that paper infront of client through controlled document transfer through a document controller with reference number.If the client need more stringent criteria then he will make some remark,then you have to incorporate it with next revision.Job done
In Reply to Parent Post by kev4791 View Post
Thanks.
Kevin
  Post Number #5
Old 16th September 2012, 07:15 PM
kgott
Thanks.
Kevin
Kevin; you need to break the job down into its major components and identify where any measuring and testing is going to take place. Two of those parts for you are the concrete and steel work.
The inspect and test parts of contrete is a specification for the conrete and a slump test at the site. The slump test should show no more than about 20 mm for the standard specification for a concrete floor.
With steel you are looking at visual weld inspection, dimensional accuracy specification and measure check (inspection) then there is a coating specification and thickness inspection which is usually 3 micron thickness.
Some of these tests will be a check of the spec for the concrete, weld spec and coating speic followed by a visual inspection.
If you can think of others that a relevant and meaning full so much the better but the above are 90% of you ITP.
  Post Number #6
Old 19th July 2013, 12:19 PM
pauligle
ITP is the document that describes in detail what, by who, when and how something will be inspected or tested on site or off-site.
In some other cases it is called Quality Control Plan or Regime and it’s main purpose is to plan and document the procedure and sequence that will be followed in order to provide objective evidence and results of conformity of the works or materials.
Normally you will see the following in an ITP:
  • the item that will be checked/inspected/tested (e.g.concrete strength)
  • the document that requires this item to be checked (usually it is the contract or similar document-specification)
  • the document that according to, this item will be inspected/tested (usually a standard or a statutory requirement)
  • the kind of inspection that needs to be performed (visual inspection, document approval etc)
  • the frequency that this inspection needs to be performed (e.g. for concrete slump test = once for every track)
  • the objective criteria/tolerance parameters that will determine if the inspection/test for that item has passed or not
  • the kind of document that will be prepared and saved as a record of pass or failure (usually a signed-off form, a testing machine print-out, a photo etc)
  • if this record needs to be a deliverable, meaning that it needs to be kept and handed over to the Client at the end of the Project as part of the As-Built Folders
and finally
  • the responsibilities of every entity (Contractor, QC Engineer, Client’s Representative etc)
So, we are basically talking about a table giving all of the above information.
In my opinion, creating an ITP is not the difficult part...
The most difficult thing is to implement it and striclty follow it.
Thanks to pauligle for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Difference between a Quality Plan and Inspection & Test Plan (ITP) LesPiles ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 4 15th May 2014 09:42 PM
Large Construction Project Quality Plan - ISO 9001-2008 using ISO 10006 mgcm1 ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 18 4th April 2014 01:33 PM
Inspection and Test Plan Contents Quality Lady ISO 9000, ISO 9001, and ISO 9004 Quality Management Systems Standards 7 29th January 2014 12:27 PM
ITP - Inspection and Test Plan Marc Definitions, Acronyms, Abbreviations and Interpretations 3 30th September 2013 06:20 AM
What can go wrong in a Construction Project - NCRs in Construction Industry pauligle Nonconformance and Corrective Action 5 5th July 2013 06:23 PM
The time now is 02:24 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
