Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Inspection and Test, Sampling and Related Topics
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
Old 15th September 2000, 04:52 AM
Don Watt
Unregistered Guest
Posts: n/a
Hehehe... Pre-Control Chart to guide in-process inspection / adjustment decisions
Hi'all,
I've just inherited a new department and in order to try to start to move forward, I'm interested in trying to apply pre-control charting to guide in-process inspection / adjustment decisions.
I think it would suit an application where an operator is running a bank of 5 machines.
I'm told that we tried SPC ("didn't work - batch sizes too small / "Quality" depends on how good the set-up is")There also seems to be a mindset of if it's in tolerance it must be OK (reduction in variation is not viewed as continuous improvement - unfortunately)
Current inspection ssems to be a "finger in the air job" i.e. no data to support when to inspect / when to adjust.
To get to the point, does anybody know of a sampling plan to use a starting point, rather than trying to invent my own.
Cheers,
Don
Sponsored Links
Old 15th September 2000, 10:19 AM
Rick Goodson's Avatar
Rick Goodson Rick Goodson is offline
Registration Date: Aug 2000
Karma Power: 42
Rick Goodson has less than 100 Karma points so far.
Don,
There are pre-control plans available but I would caution you that they all start with a caveat that the process first has to be in statistical control before you use the pre-control techniques. If you have not been able to implement SPC successfully it will be difficult to move to pre-control. A Cpk greater than 2.0 is not unusual as a minimum pre-control requirement.
Most plans are based on three zones. The green zone is 50% of tolerance and centered around the nominal dimension, the yellow zone adds another 25%, the balance is the red zone. There is a text, 'Modern Methods for Control and Involvement', ISBN 0-471-87696-X, with a brief discription of the technique or you might try papers by Dorian Shainin (1965) or N. R. Brown (1966). I also highly recommend you look at 'Statistical Quality Control' by Grant and Leavenworth, ISBN 0-07-024162-7. The authors present a number of reason why you should not use pre-control and in fact go so far as to state "The best advice we can give is to recommend almost any technique discussed in this book in preference to precontrol. The pattern of variation is a characteristic of the process and should never be confused with design tolerances."
Sponsored Links
Old 15th September 2000, 04:31 PM
Don Watt
Unregistered Guest
Posts: n/a
BIG Smile
Hi Rick,
Many thanks for the information, I'll certainly be having a look at the Grant & Leavenworth book.
I was under the impression that pre-control may be ok with Cp between 1 & 1.33 (the limited studies that I've done so far indicate that we have this basic capability)
If Cp of 2 or greater is required, I need to think again :-<
Old 10th October 2000, 12:42 PM
Jan Ketelaar
Unregistered Guest
Posts: n/a
BIG Smile
Hi Don,
I know what you are looking at. I also had the beauty of walking into a new department and it is still difficult to teach an old dog new tricks. I do work with a cp of 1-1.33 and it works okay. Soon I will start to introduce a system simular as the 50% / 25% zone. Only, I will use 1, 2 and 3 sigma. 2 Sigma being a yellow zone. If I have not been killed by then I will post the results....
Old 7th December 2001, 10:09 AM
Jim Jakosh Jim Jakosh is offline
Registration Date: Nov 2001
Karma Power: 33
Jim Jakosh has less than 100 Karma points so far.
Question Pre Control Charts
What conditions have to to be in place to define "when" you can use a pre-control chart on an ongoing process?
Jim Jakosh_ Grand Rapids, Mi
Old 7th December 2001, 11:39 AM
Al Dyer
Unregistered Guest
Posts: n/a
Default
Jim,
Can I assume that your currect process is in control?
Ifso, what would be the need or benefit of adding a pre-control chart?
Maybe some more details will help us!
Old 23rd December 2001, 04:51 AM
Ravi Khare's Avatar
Ravi Khare Ravi Khare is offline
Involved - Posts
Registration Date: Dec 2001
Karma Power: 35
Ravi Khare has less than 100 Karma points so far.
Cool
PreControl will work well only when you already have a good Process Capability. To qualify a process, you will need five points in a row in the Green zone ( middle 50% of specs) on the precontrol chart. This would happen only if you have a good process capability with the process centered.
A precontrol chart would monitor whether your process maintains the low variation and holds on to the centre as you sample out of it.
Old 23rd August 2002, 11:58 AM
gpainter gpainter is offline
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.
Default PRE-Control
I had seen a short article on this and was wondering if anyone could point me in a direction for some good resources on this? Thanks in advance!!
Reply
Bookmarks
Tags
in-process inspection, inspection, pre-control chart
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Minitab Pareto Chart Text Adjustment Michaelk Using Minitab Software 10 5th August 2008 09:42 AM
New(?) kind of control Chart? Pre-Control Chart António Vieira SPC Monitoring and Statistical Analysis Techniques 13 9th March 2007 07:05 AM
Defining Pre-Control Zones - Statistical Process Control (SPC) llemouse SPC Monitoring and Statistical Analysis Techniques 1 15th March 2004 03:08 AM
Pre-Control Chart - Limits are set at 2/3 of the specification Fluidfont SPC Monitoring and Statistical Analysis Techniques 6 13th November 2003 12:06 PM
Customer Audit of Guide 25 Calibration - Full pre and post adjustment data? Marc ISO 17025 - Calibration, Measurement Gages and Test Laboratories 1 5th November 1999 08:52 PM
The time now is 09:42 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
