Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 10013 - Quality Management System (QMS) Manuals
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 26th August 2002, 05:04 AM
paula
Unregistered Guest
Posts: n/a
Truce Changing revisions number
My dear friends,
I came back after a long time and I have to tell you that I missed you. I also brought a little problem with me. I managed to develop and after the implementation and initial audit, obtain the certificates for a safety management system, very similar to ISO.
.. and I have this problem now. I had the initial revision and I added a new document, in fact a new form. The forms, in this system are controlled documents.
..and I don't know how to proceed now. To give the document the current revision of the documentation, let's say n and in this case, how can anyone tell the difference between the system with or without this later form OR should I give this form a revision n+1 and then what? .. change the whole system revision to n+1 or leave just this document like this.
It is obvious that the documentation procedure has to be modified in order to explain clearly this revision change aspect.
Please help me with an advice.
I am looking forward for your answers.
Have a nice day!!
Paula
Sponsored Links
Old 26th August 2002, 04:29 PM
energy
Unregistered Guest
Posts: n/a
Default Re: Changing revisions number
Paula
Paula,
One has to ask "How did you get to Rev n without a document revision procedure?". Anyway, if you started with "m", just add a last page to the procedure with a Revision block or section showing the latest Rev letter and a brief description of what was changed. I hope this helps, but I'm still not sure if I understood the question. Are you pursuing ISO? If so, there are two mandatory written procedures that you must address. They are Sections 4.2.3 Control of documents and 4.2.4 Control of records. Post again if I didn't get the question.
Sponsored Links
Old 27th August 2002, 06:21 PM
JodiB's Avatar
JodiB JodiB is offline
Still plugging along
Registration Date: Nov 2001
Thanks Given to Others: 4
Karma Power: 44
JodiB has disabled his/her Karma.
Default
[/QUOTE]
I don't understand. The word "system" is what is confusing to me.
Did you add this new form to a written procedure which was already released?
Or do you have a listing of forms listed at the back of your System's manual and your question is related to whether the manual's revision changes because you have added a form to the list?
The form should have it's own revision number. (And I recommend that it is not included within the body of a procedure, but that is only MHO). This revision number is not related to any other documentation at all.
If you changed your procedure so that it now references the use of the new form, the procedure will move to the next revision number. If it was N before, now it is N+1. Keep a history of revision on the back page that explains that it now references a new form, as energy said.
Does this help?
Old 28th August 2002, 12:32 AM
NITIN's Avatar
NITIN NITIN is offline
Involved - Posts
Registration Date: Apr 2002
Karma Power: 31
NITIN has less than 100 Karma points so far.
Default
Ok assume that
Procedure A has an Issue number 1
Form A is added to Procedure A
Then the form will have a issue number 1+revision no.
ie-Issue 1 Rev 1.
The cover page of the manual will similarly be updated to reflect this on the footer as Issue 1 Rev 1.
You might have a documnet change form that tracks these changes on the manual if any.
We must be the world we want to create.
Old 28th August 2002, 05:11 AM
paula
Unregistered Guest
Posts: n/a
Default
Thanks for all the answers so far. My documentation and 'system' are made according to the ISM code, which is very similar to the ISO code, but the idea is related to the safety management. You have to have document control, management review, non-conformities, corrective actions etc. procedures and also other specific procedures. The documentation is split like this: the system manual, procedures manual, forms register (so far everything is the same as in ISO) and another 3 specific manuals. Now, for sure, I have to clarify the documentation control procedure to specify more clearly how you change or add a form or procedure. In fact, this situation, when you add a new document is not treated.
So, to resume, my problem is (and I don't enter in the long details of how we got to the revision 2 - waves of changes that modified the whole documentation, either the format, or the content)that I added a new form. It will be added in the Forms register and recorded there, in the revision list. The form is refered in one of the dedicated manuals, therefore I'll change its revision to 3. My problem is now, what revision I'll use for the form. I am a little confused here.
In fact, can anyone please help me with a model of revision control procedure or instruction?
Thank you again.
What we learn to do, we learn by doing. --Aristotle
Old 28th August 2002, 05:27 AM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Default
Paula
I would give the new form revision 1 as there have been no previous revisions. I would reference the use of this form in my procedure, which would be up-issued to reflect this change. In my opinion that is all you need to do.
Old 28th August 2002, 12:13 PM
JodiB's Avatar
Karma Power: 44
Default
Your form revision number is not related to any other piece of documentation. It only keeps track of how many times the form itself has been revised.
We use 0 for the initial release of a document, including forms. Then 1 for the first revision. This is briefly described in our doc control procedure.
Old 29th August 2002, 05:52 PM
BobD BobD is offline
Registration Date: Jul 2002
Karma Power: 30
BobD has less than 100 Karma points so far.
Default
The way I handle forms is as follows. Every form has its own ID number. Every form also has its own release or revision date. Then in the various procedures, I reference the form number. only. In this way if I have to make future changes to the form, I do not have to go back and change the procedure. Hope this suggestion is of some help.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Quality System Manual Revision Control when the manual has sections assyrian47 Documentation Control Systems, Procedures, Forms and Templates 3 11th February 2009 02:08 PM
Need for revision (minor inconsistencies, missing dates and revision numbers, etc)? blackandwhite Documentation Control Systems, Procedures, Forms and Templates 3 30th September 2008 01:45 AM
Quality Manual Revision - Update - Changing our company name ZamaDan ISO 10013 - Quality Management System (QMS) Manuals 4 17th May 2004 09:24 AM
Quality Manual Change History - Can I eliminate the revision record from the manual? Mark Smith ISO 10013 - Quality Management System (QMS) Manuals 33 22nd March 2004 07:04 AM
Changing the structure or the format of the Quality Manual - Indentions Vash Stampede ISO 10013 - Quality Management System (QMS) Manuals 3 25th October 2002 12:56 AM
The time now is 06:07 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
