Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
2nd December 2011, 05:16 PM
Involved in Discussions
Registration Date: Apr 2009
Thanks Given to Others: 333
Karma Power: 41 Karma: 30
Document Control ECO (Engineering Change Order) or QMS?
Hi all
While going deeper into the document control and products
I´m facing doubts as to what is the best way.
Under QMS 9000 2008
It is included the Control of documents, which I think in general covers the basics for any company.
But recently I found it may be useful to adopt ECO, which is
I think slightly different than how QMS considers the documents control.
I work in an engineering company producing equipment (pumps. heat recuperators, vessels, etc) and I think that in my opinion may fit the ECO
concept.
When specifically is better to adopt ECO´s? and when to
use control covered by QMS?
If choosing ECO´s, I may be running both concepts.?
When certifying to ISO, is there a disadvantage?
Thanks for your clarification
2nd December 2011, 05:21 PM
Registration Date: Feb 2005
Thanks Given to Others: 4,010
Karma Power: 774
Re: Document control ECO or QMS?
QMS 9000 2008 is?
I've used a version of an ECO to do document control/changes very effectively. One issue is that an ECO may have too many fields to be filled, so it's often better to use a specific document change note, which looks much like an ECO
'Cause you know sometimes words have two meanings.....
Thanks to AndyN for your informative Post and/or Attachment!
2nd December 2011, 06:29 PM
Thanks Andyn
So, you use both, and which for what kind of documents?
When you say, lot of fields to be filled, yuo mean to use an alternate ECO form or
to use other more simple control form , like that used under QMS?
Thansk
2nd December 2011, 09:43 PM
Karma Power: 774
Re: Document Control ECO (Engineering Change Order) or QMS?
ECO is used to make changes to Engineering/Design specs (it often has many 'boxes' on the form for things not affected by a simple document change, like what to do with the 'previous rev. parts' in stock etc, before the next rev is cut into Production)
A simpl(er) version can be used for QMS changes. I used both side by side. One for Engineering, one for QMS.
2nd December 2011, 10:25 PM
Thanks Andyn
How do you manage these 2 points:
I plan to use only one form called ECO
on the upper half page, the requester describes the change
and in the lower part of the same form the Enginneering rejects or accepts the change describing affected documents, this because, for my records
Ok I´ll have my list of ECO´s, which ones were rejected and which do not.
Dont´want to use two forms ECR and ECO because I think for the registering is tedious and time consuming.
suppose I receive an ECR, then if accepted , I have to raise an ECO with another number, then when I need to check the status, I have to go to see ECR´s and ECO´s
What is the purpose to use both ECR and ECO?
Then othe point, at what step of the ECO The closeout takes place?
is it used to close ECO´s?, because I´ve seen some forms which don´t
mention the closeout.
3rd December 2011, 08:05 AM
Registration Date: Jan 2004
Thanks Given to Others: 2,985
Karma Power: 613
In Reply to Parent Post by QAMTY
Thanks Andyn
Your points about managing two numbering and tracking systems are valid and well made. If you can make your ECO form straightforward and easy to use, I see no reason why it can't be used for both engineering drawings and process documents.
"If you only have a hammer, you tend to see every problem as a nail." Abraham Maslow
Thanks to Jennifer Kirley for your informative Post and/or Attachment!
3rd December 2011, 01:31 PM
Quality Manager
Registration Date: Sep 2003
Thanks Given to Others: 452
Karma Power: 1122
FWIW:
I used a single form for all document changes - any possible impact of the change was covered. If it didn't apply, the box was left unchecked. If it did apply, there was space for a description of the impact. All was done in the name of Configuration Management.
Thank You to Wes Bucey for your informative Post and/or Attachment!
3rd December 2011, 06:31 PM
Thanks Wes
Well I have one for QMS documents and plan to use other
pro Engineering changes because I think there are a lot issues
around this area.
By using a simple ECO form trying to have control over
the request and in the same form including the revision the solution
and implementation, closing out the ECO when changes are done, but still
in doubt when the closeout have to be applied
When changes are done or when the changes resulted successful
Forum Posting Settings
