Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
13th December 2011, 11:38 AM
A Sea of Statistics
Registration Date: Jan 2011
Thanks Given to Others: 180
Karma Power: 41
Contour vs. Profile - Is there a connection between "Contour" & "Profile"?
Hi To All,
While studying 14.5M, and reviewing some sample drawings (no longer at my disposal) I have noticed the use of "Contour", I have searched 14.5M and various websites for a definition of "Contour" no luck.
Is there a connection between "Contour" & "Profile"? If so, what is it and is there an official definition (other than Webster's) of "Contour"?
Thank you for your assistance...
Regards,
Marty
13th December 2011, 04:35 PM
per ASME Y14.5M-1994
Registration Date: Feb 2005
Thanks Given to Others: 5
Karma Power: 102
Re: Contour vs. Profile - Is there a connection between "Contour" & "Profile"?
I have heard contour used as a description for a surface you apply a profile tolerance to.
eg: 'The contour of the curve is in the math data'.
Thanks to True Position for your informative Post and/or Attachment!
13th December 2011, 04:41 PM
A Sea of Statistics
Karma Power: 41
Hi True Position,
Thank you for the response, so could you think of an instance where "Contour" would be used on a y14.5M part drawing, or in conjunction with a profile control?
Regards,
Marty
13th December 2011, 05:49 PM
Appreciated Information Resource
Registration Date: Aug 2007
Thanks Given to Others: 35
Karma Power: 72
Marty:
No, contour would not be used on a drawing. Profile of a Line or Surface would be used. The definition for contour is in Websters rather than ASME Y14.5-2009.
Dave DeLong
Thank You to David DeLong for your informative Post and/or Attachment!
13th December 2011, 06:02 PM
Appreciated Member
Registration Date: Jul 2008
Thanks Given to Others: 619
Karma Power: 53
I've never seen "Contour" on a blueprint but the word is used in the programming and set up of our CNC machines. It seems like machining vernacular.
None of the secrets of success will work unless you do. - Fortune Cookie
Thanks to Hodgepodge for your informative Post and/or Attachment!
14th December 2011, 12:16 PM
A Sea of Statistics
Karma Power: 41
In Reply to Parent Post by David DeLong
Marty:
David and HodgePodge,
Thank you both for your timely response, I value your learned insight. Here is what is really strange (eventhough I am still a GD&T in training), I recently had an interview (Q.E.) with a large multi-national Aerospace firm, during the interview (three on one of course) I was given a "typical drawing" supposedly/assuming per Y14.5M, and it appeared to be a engine seal or flange part. Mind you it wasn't a test, but rather meant to show the type of "typical drawings" we would be working with. While reviewing the three page drawing, the use of the word "Contour" popped off the page, it, as I recall "Contour" was used as part of a FCF applied to 5-6 surfaces. Of course my comment was "this is not per Y14.5M, is the intent to use a Profile of Surface call out...", no response.
It has bugged me for tha last two weeks....I am thinking may be this is an company specific use of "Contour"...if so this seems to miss the whole point of Y14.5M....a common language used to generate and communication part function/use and its drawing(s)....kind of frustrating.
Your thoughts??
Regards,
Marty
14th December 2011, 12:46 PM
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,781
Karma Power: 1445
In Reply to Parent Post by optomist1
Your thoughts??
Regards,
Marty
In another thread I think I remarked that you'd need to get used to this sort of thing. There are precious few drawings loose in the world that incorporate GD&T 100% correctly. You'll also find a sort of double-whammy--GD&T used incorrectly when it's not even necessary or helpful to use GD&T.
We aim to please. You aim too, please.
Thank You to Jim Wynne for your informative Post and/or Attachment!
14th December 2011, 01:07 PM
Karma Power: 72
Marty:
It sounds like company jargon to me but it still means profile of a line or, probably, surface.
Dave DeLong
Forum Posting Settings
