The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > Inspection, Prints (Drawings), Testing, Sampling and Related Topics > AQL - Acceptable Quality Level
Forum Username
Wooden Line
AQL Formula in Excel - Calculating Sample Size based on an AQL Chart
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Related Topic Tags
aql (acceptable quality level), microsoft excel .xls .xlsx spreadsheet, receiving inspection, sample size, samples and sampling plans, incoming inspection (also see receiving inspection)
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
  Post Number #1
Old 18th January 2012, 03:48 PM
IvorFreyrsson
Please Help! AQL Formula in Excel - Calculating Sample Size based on an AQL Chart
Hi everyone!
This is my first time posting here. I've gotten a lot of great answers from these forums for my job, and since I cannot find an answer after two hours of searching, I figured it was time to make a profile, and get to asking.
I work in Quality Control, specifically Incoming Inspections. I also handle the management of our calibration system.
With that bit of background (it may help) I am posing a question to the larger body of learned minds.
I'm trying to make a formula that will calculate my sample size based off of an AQL standards chart. Our acceptance # is zero, but that won't play a part in my question.
In Excel, let's say I have six cells - A1:A3 and B1:B3
A1:A3 are only text; "AQL Level" (A1), "# of Samples" (A2) and "# Inspected" (A3)
In the other three cells: I have a drop-down in B1, giving the AQL number.
In B2 would go my total number of parts, i.e 450.
In B3, I'd like to develop a formula that will give me the proper # of parts to inspect, based off cells A1 and A2. I am stumped, as I'm not that great with Excel.
I think I'm in the right forum. If not, would you kindly point my noob self in the right direction?
Sponsored Links
  Post Number #2
Old 18th January 2012, 04:36 PM
Tim Folkerts's Avatar
Tim Folkerts
Re: AQL Formula in Excel
There are a couple possibilities I can think of, depending on whether you want to look up an answer or to calculate an answer.
To l
ook up an answer. you would have to create some sort of lookup table and basically input the key tables from the standards into your spreadsheet. Then have the spreadsheet look up the answer in the table.
Using the actual Z1.4 tables, actually all you have to do is look up your AQL and find the sampling plan with Ac = 0. The lot size will not matter, since you are forcing the table to select Ac = 0.
To calculate an answer, I created a spreadsheet a few years back that helps determine sample sizes for statistically valid sampling plans.
Sampling Spreadsheet to help determine the Sample Size for Sampling Plans
The spreadsheet is a little more involved that you were thinking. It has places to input AQL, RQL, alpha and beta. Then you can adjust the sample size to find acceptable sampling plans. All of these factors play a role in the statistical calculations. (Note that the lot size does NOT matter to these calculations -- there is more about this in the original thread).
You could also change this process around a bit. You could first set the AQL and alpha and adjust the sample size until Ac = 0. Then you would play around with RQL and beta to make the plan work. For example, you might set beta = 0.1 and then see what RQL that corresponds to.
Thank You to Tim Folkerts for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 18th January 2012, 05:05 PM
NumberCruncher
Re: AQL Formula in Excel - Calculating Sample Size based on an AQL Chart
Hi IvorFreyrsson
Assuming you want to look up the values, you will need to provide a bit more information. Quite simply, there are different possibilities for lookup tables depending on what you want to look up. If you have a single table containing your lookup values, this is simple to do.
If you have several different tables, the lookup will be possible, but more involved.
Can you post the spreadsheet that you already have with some skeleton tables? (This is because I am unfamiliar with incoming inspection sampling, and I can't visualise too clearly what you are trying to look up). You don't need to include the actual "number to be inspected" data, as I suspect this would constitute some form of copyright breach. But if you include just the things you are trying to look up, ie "AQL Level" (A1), "# of Samples" (A2), I should be able to help.
NC
Thank You to NumberCruncher for your informative Post and/or Attachment!
  Post Number #4
Old 18th January 2012, 07:13 PM
Statistical Steven's Avatar
Statistical Steven
In Reply to Parent Post by IvorFreyrsson View Post
Hi everyone!
Two solutions:
1. Write a macro that can calculate the number_sample in the following formula HYPGEOM.DIST(0,number_sample,b1*b2,b2,"True") solving it for 0.95.
2. Write a macro that can calculate the number_sample in the following formula BINOM.DIST(0,trials,b1,TRUE) solving it for 0.95.
Having said that, you should have a calculation for LQ in addition to AQL. use the same formulas but solve for a probability of 0.10 instead of 0.95.
Does that make sense?
Thank You to Statistical Steven for your informative Post and/or Attachment!
  Post Number #5
Old 19th January 2012, 09:59 AM
IvorFreyrsson
Wow. Thanks guys!
Tim, Your spreadsheet is much more involved than anything we do here. A good tool, but too much for what we need.
NC, I'm including the spreadsheet, and a PDF of the AQL plan we use here. All we'll ever do is use an AQL of 10.0 for standard inspections, 1.0 for tightened (we find more than one defect) inspections, and will default to 100% beyond that. All I'm trying to do is figure out some way to call up the number of samples based on an input of Lot Size.
If I can be pointed in the right direction of just what formulae to use, I can most likely figure out how it's used, and go from there.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
  Post Number #6
Old 19th January 2012, 11:43 AM
NumberCruncher
Hi Ivor
A bit crude but this is what I think you want. You will need to type in the numbers from the aql table yourself (I'm helpful, but not that helpful!)
NC
  Post Number #7
Old 19th January 2012, 01:38 PM
Tim Folkerts
I'm not sure how well you will be able to create a sampling plan based on the criteria you have suggested. You have suggested that you want AQL = 10, and a zero acceptance number (Ac=0). However, as you will find out, these numbers are incompatible with each other in the standards.
I don't have the current Z1.4 handy, but the old MIL-STD 105E should be identical. http://www.everyspec.com/MIL-STD/MIL...TD-105E_11675/
For AQL = 10, there is no Ac=0 plan in the standards. The closest they have for AQL = 10 is Ac=1, Re=2 for a sample size of 5! So no matter what the lot size, you would draw 5 samples and reject only if you found 2 defects. According to the standards, you would have to accept lots where the sample had 1 defect out of 5!
There are a couple ways to try to fix this.
1) Drop the Ac=0 requirement. Then you could keep AQL=10, but the sample size would vary from 5 to 125 depending on the lot size. However, the acceptance number would somewhere between 1 and 21!
2) Choose a more stringent AQL, but keep the Ac=0. For example, you could go for AQL = 6.5 with a sample size of 2. Or you could go for AQL = 1 with a sample size of 13. (Note that now the sample size is determined strictly by AQL and lot size will not matter.)
  Post Number #8
Old 19th January 2012, 02:02 PM
NumberCruncher
Hi Ivor
Another version. A little simpler from the data entry point of view, you just enter the sample size.
Hopefully it will work. Many of my spreadsheets are created in OpenOffice, then converted to Excel, as was this one.
I would recommend protecting all but the data entry cells.
NC
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Calculating Cpk when sample size equals to 1 M.Yung Capability, Accuracy and Stability - Processes, Machines, etc. 12 22nd April 2015 10:12 AM
SPC Newbie looking for Excel Spreadsheet formula for a sample size of 40 components f1guru Capability, Accuracy and Stability - Processes, Machines, etc. 8 18th May 2012 12:46 PM
Sample Size Calculation Formula for Process Capability cpastore Statistical Analysis Tools, Techniques and SPC 25 14th February 2011 01:36 PM
Calculating Sample Size for very low AQL nate_9 AQL - Acceptable Quality Level 13 8th November 2010 01:24 PM
Calculating an AQL given a sample size, accept/reject numbers, and lot size seve00 AQL - Acceptable Quality Level 2 10th April 2009 04:19 PM
The time now is 10:59 AM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
