Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
13th February 2012, 10:48 AM
Getting Involved (6 to 9 Posts)
Registration Date: Mar 2011
Karma Power: 9 Karma: 10
Only Commissioning Software? COTS, GAMP Category 3 Software Validation Requirements
was hoping that someone could give me some advice.
i'm currently sitting in for a val manager. I'm going over the program and i see several pieces of software that have been assessed as needing commissioning and uRS's only.
These pieces of software are COTS, GAMP category 3, so while i agree they are simple, I have never had the experience of simply commissioning software. Instead, I've seen very simple IOQs, or even checklists, but they were always qualification.
Even one of the spreadsheets used (simple calculations) are listed as needing commissioning only.
Also, one more question: if the software is an indirect GMP impact, does anything need to be done aside from ensure that it is in the System register for the site?
Thanks so very much in advance!
14th February 2012, 12:04 AM
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,952
Karma Power: 1431
Re: Only Commissioning Software? COTS, GAMP Category 3 Software Validation Requiremen
A Quick Bump!
Can someone help?
Thank you very much!
Stijloor.
14th February 2012, 10:11 PM
Your Elsmar Cove Host
Registration Date: Jan 1996
Thanks Given to Others: 7,457
Karma Power: 400
Another quick "Bump". My Thanks in advance to anyone who can help with this one.
One Test is Worth 1000 Expert Opinions - The plural of anecdote is not data - Correlation does not imply Causation
16th February 2012, 07:00 AM
Addicted to standards
Registration Date: Mar 2006
Thanks Given to Others: 286
Karma Power: 249
I really didn't understand what you want to know.
The second question is clear - and the anser is - if the software is used inside the quality system and impacts the quality/safety o the product, it has to be validated - see for example TIR 36:2007, Validation of Software for Regulated Processes (which is being implemented as an international standard).
But what is the first question? Is it related to a medical device software (hope so because 672304 is only for medical device software, not for GMP software).
I'm a moderator on the medical device forums, so if you need help with something, feel free to ask!
Thanks to Marcelo Antunes for your informative Post and/or Attachment!
27th March 2012, 03:42 AM
Involved in Discussions
Registration Date: Feb 2010
Thanks Given to Others: 8
Karma Power: 16 Karma: 55
I have a related question if someone can help.
IEC 62304 deals with software lifecycle, but is there a standard or process for validating SOUP (Software of Unknown Provenance) for a medical application. The SOUP would be the entire application, and if it helps, it would be a class 1 device.
28th March 2012, 10:20 AM
Registration Date: Jun 2010
Thanks Given to Others: 4
Karma Power: 19
In Reply to Parent Post by DangerousDave
62304 addresses use of SOUP. If your device is Class 1 then it'll be Class A in 62304. This calls for a relatively low level of software process and, specifically, verification against requirement.
I would establish the requirements and then formally test the software. Really no way around that at a product level anyways. You'll need to add the SOUP to your version control system, have discrepancy tracking, release procedures and so on.
At Class A under 62304 that you didn't write the software is almost immaterial.
Thanks to glork98 for your informative Post and/or Attachment!
28th March 2012, 04:18 PM
Appreciated Information Resource
Registration Date: Jun 2011
Thanks Given to Others: 19
Karma Power: 18
I think that using a SOUP doesn't mean that it is systematic to put it in class A. It may still be class B or C.
I agree with the process suggested oby Glork, it is coherent with what is written in the FDA's GPSV, especially the last two paragraphs of §2.3.
Using a SOUP has also impacts on risk analysis, see the guidance about Off the shelf sofware use written by the FDA.
I recommend this minimal analysis: there is surely a list of known bugs in your SOUP, you should analyse the potential hazard link to each known bug in the perspective of your intended use.
By the way, I quote FDA guidances because there is nothing equivalent in CE mark documents.
Hope it helps.
Mitch.
Do what you write, write you do.
Increase your changes to be CE marked!
Thanks to c.mitch for your informative Post and/or Attachment!
1st April 2012, 11:16 PM
Shy Poster (1 to 5 Posts)
Registration Date: Aug 2008
Karma Power: 20 Karma: 20
In Reply to Parent Post by rina120
You may want to refer back to the ISPE GAMP guidances. Possibly, the one for Process Control Systems if these computerized software systems control equipment/utility components. Is there a impact/regulatory assessment documenting the indirect impact decision? Is the software documented as "regulated or unregulated"?
Reason: correcting response
Thank You to meccadon2020 for your informative Post and/or Attachment!
Forum Posting Settings
