What does a Pareto chart tell me that a pie chart doesn't?
Attached is a sample suvey that has been tabulated.Pray tell me what the Pareto is telling me which the pie is not.I see no reason to spend time doing a pareto when I can make the same deductions from a pie chart.
Or am I doing the wrong thing??
Please excuse my ignorance if you find this too dumb.
In principle, the Pie Chart would show you the distribution of data across parameters ( looks like complaints in your case) while Pareto Chart would also find the cumuative distribution. It is a well known theory formulated by Pareto that 80% of the effects are caused by only 20% of the causes, or in such cases 80% of the trouble is caused by 20% of the causes. A Pareto Chart will help you to identify those top 20% of the causes and prioritize the course of action.
I have perhaps reiterated what you already know.
Analyzing your spreadsheet, it looks like there are only 5 categories that share a fair amount of % of complaints each ( between 15 to 25%) giving an appearance that all categories are contributing almost equally to the complaints. In such a case I would try to resolve my survey into more specific and more categories of complaints. Frame more specific questions within each category. This should bring the picture out more clearly. Higher the resolution of the measurement system, more the information you will be able to get.
Hi Ravi,
I am not disputing the law.What I am saying is that to anybody who is aware of the "law' the same deduction can be made by looking at the Pie chart.What additional information does the Pareto Chart give me to help me zero in or prioitise my efforts?Looking at the Pie,I would for example decide to go after the big slices first.Looking at the Pareto,it tells me exactly the same thing.So why all this cumulative percentage conversion,charting plotting etc ?
We must be the world we want to create.
Sure, the pie chart would indeed tell you which slices are big and which are small.
It pays to measure numerically though, rather than describing the slices as merely big or small. The question of how big a slice should be described as big enough for attention becomes subjective. You will have to do a quick mental arithmetic to arrive at the cumulative 80% of the slices.
Once I have the cumulative frequency curve in a Pareto Chart, the method I commonly use is to project the 80% mark from the Y axis to the curve, and drop the intrecept down on the x axis from that point. All bars to the left of this dividing line can be treated as important, since they will be addressing 80% of the effects. Once this is done, I turn my attention to another process where another 80% of pressing matters demand attention.
I find this a very effective way to prioritize.
Let's say the Pareto Chart makes the 80-20 law more 'visible'.
Spot on Ravi. Another consideration is that a Pareto is easier to handle when there are larger numbers of catagories. The more slices you make in a pie, the harder it becomes to read it accurately. Besides there is no real challenge in spelling "pie".
