Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 24th September 2002, 10:33 AM
Xman's Avatar
Xman Xman is offline
Registration Date: Nov 2001
Karma Power: 33
Xman has less than 100 Karma points so far.
Quid Pro Quo Need help / feedback on Xbar/R charts and Cpk/Ppk applicability - Assemblies
I am conducting SPC studies (using Xbar/R charts) on a grinding process, using variable data from three characteristics:
(1) assembly thickness after grind
(2) parallelism of surface to backing plate after grind
(3) flatness of surface after grind
To make charting easier, I am coding the data...in other words 0.001" will be 1, 0.010" will be 10, 0.007" will be 7, etc...
I am also setting the nominal as zero (0), and then will chart the difference from actual target. For example, if a part thickness target is 0.650", and the measurement taken is 0.652", then I record "2"...if a measurement is 0.647", then I record "3". What this does is it allows me to use one standard set of charts, regardless of the actual part thickness.
That's just a little background on what I am doing...now on to the question.
Ok, for THICKNESS, the specification is bi-lateral, however, for PARALLELISM and FLATNESS, the specifications are uni-lateral. Thickness is typically 0.650" +/- 0.005" (ie: in my case, 0 +/- 5). Parallelism and flatness are typically 0 + 0.010" max (ie: in my case, 0 + 10 max).
Ok, for calculating Cpk and Ppk, the formulae are as follows:
(I know that there is no PPU or PPL, I just used those terms for the sake of this question...)
That being said, I realize that these formulae work fine for my thickness studies, since they are bi-lateral, but what about for the uni-lateral tolerances (parallelism and flatness)??
For parallelism and flatness couldn't I just say that Cpk = CPU and Ppk = PPU (since there is no lower specification)?
Does anyone have any ideas on a better way to monitor these two uni-lateral characteristics (are Xbar/R charts even appropriate for these)???
(I need a vacation!)
Any fact facing us is not as important as our attitude toward it, for that determines our success or failure.
Norman Vincent Peale
Sponsored Links
Old 24th September 2002, 11:07 AM
Craig H. Craig H. is online now
Been around a while
Registration Date: Jan 2002
Thanks Given to Others: 283
Karma Power: 171
Craig H. is appreciated, and has over 1700 Karma points.
Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.Craig H. is appreciated, and has over 1700 Karma points.
Default
Good morning, Xman.
Yes, this is what you should do.
The use of xbar should take care of any "normalcy" issues, and the use of the USL is entirely appropriate - the farther you are from the upper spec, (i.e. closer to zero) the better, right?
Just curious, but how did you determine your subgroup (n) size?
Sponsored Links
Old 24th September 2002, 11:31 AM
Xman's Avatar
Karma Power: 33
Default
Yes, that's correct. The ground surface, ideally, would be perfectly flat/parallel (ie: 0), however since we all know that's virtually impossible, I have a tolerance of a maximum of +0.010" deviation from 0. So, the closer to 0, the better.
Just curious, but how did you determine your subgroup (n) size?[
I am using charts with 25 subgroups of 4 (for a total of 100 readings.) I chose 4 because it is the best "fit" for 100 readings, as well as the fact that our grinder runs 4 jigs/fixtures, so I can also track the variation from jig to jig by watching the charts as well.
Thanks for your reply!
Old 24th September 2002, 11:37 AM
Ravi Khare's Avatar
Ravi Khare Ravi Khare is offline
Involved - Posts
Registration Date: Dec 2001
Karma Power: 35
Ravi Khare has less than 100 Karma points so far.
Default
As Craig rightly pointed out, X-bar should take care of Normalcy issues. X-bar R Charts would give you a good indication of the stability of the process.
Your evaluation of Cpk = Cpk(U) and Ppk = Ppk(U) is also would give you the right picture of the Process Capability. Cp and Pp are undefined in such cases.
Since you have parameters of parallelism and flatness that have one sided specification, the approach you need to take for an out of control situation will difer slightly from that for parameters with two sided specs.
If you find that you have an out of control situation that takes the X-bar below the lower control limit, your process has drifted lower, but actually improved. You should then investigate what you have done right ( assignable cause of the right kind) to get this out of control. If you are able to replicate the assignable cause setting, and maintain the out of control below LCL, you could consider reapplying the Control Limits based on the new improved process study data. You could then maintain the process stable with reference to the new limits.
-Ravi
Old 24th September 2002, 12:15 PM
Xman's Avatar
Karma Power: 33
Default
With the parallelism and flatness characteristics, since there is no lower spec, wouldn't it make sense to say that there should also be no lower control limit (in other words the LCL should be 0), like the R chart (since range can only be =/< 0 as well)?
For example, one set of data I analyzed for flatness gave me a LCL of -0.12. However, since I have no negative (-) readings, and can have no readings less than 0, shouldn't the LCL be 0?
Old 24th September 2002, 12:19 PM
Been around a while
Karma Power: 171
Default
Well said Ravi! A much more complete answer than mine. However, one warning.
I got in hot water with a VP recently for pointing out that a chart drifted "out of control" when the process improved. He waited until we were alone in his office to point out to me that we were in better control now than we were a month ago. He was more than a little unhappy.
The lesson: be careful when talking to "non-practioners"!!!
Old 24th September 2002, 02:12 PM
Ravi Khare's Avatar
Involved - Posts
Karma Power: 35
Default
The lower control limit is only meant to draw the line beyond which you know that the drift is significant. That way you will be able to differentiate random variations from assignable cause ones. The lower control limit is going to tell you when there is going to be a 'significant' (real) process drift towards improvement.
As for Craig's comments, I wholeheartedly agree with you Craig... We all have gone through this sometime or the other I guess. I have spent hours trying to argue with smug people who look at Control Charts and be happy that they are producing quality; when the Cpk is all the time flashing the disaster warning!
Old 24th September 2002, 04:55 PM
Darius's Avatar
Darius Darius is offline
Courtesy Access
Registration Date: Mar 2002
Thanks Given to Others: 21
Karma Power: 65
Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.Darius is appreciated, and has over 1300 Karma points.
I Say...
If there is only one spec, I feel that you should try Cpmk or its equivalent using ds_total, as othe other posts said, you could get better Cpmk if the process is farther from the target and the variation is lower, than a process that is closer to the target and with higher variation, with the definition of quality improvement as "reduce variation centered on the target" that doen't make any sense.
look at http://www.scausa.com/capaqa.pdf
Be careful of wich control chart to use, I feel that there could be autocorrelation if this is a continuos process, you may need an X/MR chart.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
File Type: pdf Cpk index - how to calculate for all types of tolerances.pdf (117.4 KB, 392 views)
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Cpk vs Ppk - Which should you use and How to Calculate Cpk and Ppk Nitin Sharma SPC Monitoring and Statistical Analysis Techniques 25 13th October 2008 07:44 PM
Why is Cpk = lower of (USL-Xbar)/3sig & (Xbar-LSL)/3sig ? krishna_sadas Capability, Accuracy and Stability - Process, Machine, etc. 20 3rd July 2008 11:41 PM
Variable sample size - Xbar-s charts - How to select A3 and B4 D.Salman SPC Monitoring and Statistical Analysis Techniques 11 4th June 2008 10:55 AM
Validation of Cpk and Ppk calculations - Sheet to check Cpk and Ppk values Howard Atkins SPC Monitoring and Statistical Analysis Techniques 0 20th February 2006 03:41 AM
Does anyone use Median Charts instead of Xbar & R charts? Leonardo Lopez SPC Monitoring and Statistical Analysis Techniques 3 26th May 2004 03:31 PM
The time now is 02:46 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
