A Peachfarm Internet Property
The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Common Quality Assurance Processes and Tools > Statistical Analysis Tools, Techniques and SPC
Forum Username
Wooden Line
I-mr VS X-mr Chart - What's their difference?
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Bodies - World Wide Standards Bodies
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related Topic Tags
charts, statistical analysis and studies, i-mr chart, control charts (general)
Reply
  Post Number #1
Old 6th April 2012, 04:28 AM
Sitiz
Question I-mr VS X-mr Chart - What's their difference?
Hi experts,
I have a Q regards to IMR chart. I went around to look in the net and found there are 2 versions of it.
1) IMR only can have individual data which means we will tk the constant which carries n=2 only everytime.
2) IMR can have subgroups. thats the reason we have a constant table for individual with sample size till 10 (the table of constant we I got it from (ASTM publication STP-15D, Manual on the Presentation of Data and Control Chart Analysis, 1976; pp134-136.)
My Q, which is the right one?If the version 2 is right,I wonder how the way to calculate the UCL & LCL and how this will differ with the Xbar R chart or X bar S chart (which we knows carries the subgroup ).Thanks a lot for your explanation.
Sponsored Links
  Post Number #2
Old 6th April 2012, 08:43 AM
Darius's Avatar
Darius
Re: I-mr VS X-mr Chart - What's their difference?
Wrong, are subgroup charts, not IMR (Individual moving range)
There are many different kind of control charts, the individual a point on the chart represent one data point, the subgroups charts one point represent several data points
We are now talking about X-Bar & R Control Charts, if the sample is bigger, X-Bar & S Control Charts.
Wich is better?, it depends on the sample size, and the sample size depends on the process wich is meassured
Thanks to Darius for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 6th April 2012, 10:59 AM
optomist1's Avatar
optomist1
Good Day Sitiz,
Not sure I understand your question, if it is in fact when to use a I/MR chart vs X Bar/R chart; here are some of my notes/guidelines, if you use Minitab, the control charts tutorial is very good at drawing a dinstinction
"When to Use an Individual-X / MR Chart
Individual-X / Moving Range charts are generally used when you can't group measurements into rational subgroups, when it's more convenient to monitor actual observations rather than subgroup averages, or when the process distribution is very skewed or bounded. Each subgroup, consisting of a single observation, represents a "snapshot" of the process at a given point in time. The charts' x-axes are time based, so that the charts show a history of the process. For this reason, you must have data that is time-ordered; that is, entered in the sequence from which it was generated. If this is not the case, then trends or shifts in the process may not be detected, but instead attributed to random (common cause) variation.
Advertised Reason for using Individual charts– Where the cost of inspection is high such as when destructive testing is involved…..Real Reason it is a tool with which to loosen the criteria for assessing stability, particularly if small mean shifts are actually common over time."
And by extension X-bar R charts are "typically" used when:
- X-bar/R-Chart – when subgroup size is between 2 & 10 use X-bar/R-chart
- X-bar/S Chart – when subgroup size is > 10 use X-bar/S-chart
There is a vast pool of academic and professional knowledge here, hopefully others will add to or revise my input.
Hope this helps.....
Regards,
Marty
Thanks to optomist1 for your informative Post and/or Attachment!
  Post Number #4
Old 6th April 2012, 11:10 AM
Miner's Avatar
Look! Re: I-mr VS X-mr Chart - What's their difference?
The confusion may arise from the Moving Range sample size. While the X - chart is always an individual point, the Moving Range may be calculated from 2 successive points, 3 successive points. n successive points.
Thank You to Miner for your informative Post and/or Attachment!
  Post Number #5
Old 6th April 2012, 10:40 PM
Darius's Avatar
Darius
In Reply to Parent Post by Miner View Post
OK, But I don't remember to have seen tables for constants for such charts (moving ranges for more than two data points), can you post the tables or a link to them?
  Post Number #6
Old 7th April 2012, 05:34 AM
BEN6523
In Reply to Parent Post by Darius View Post
Don't have a table I can post but they are in the AIAG SPC manual, 2nd edition (probably other editions too but thats what I have.......)
  Post Number #7
Old 7th April 2012, 09:23 AM
Miner's Avatar
This is a link to an article from George Mason University and table for I-MR constants for moving ranges of varying sizes.
  Post Number #8
Old 8th April 2012, 09:23 PM
Sitiz
Thank you all for your kind reply but I think we still have not come to an conclusion.
Some saying IMR not subgroup chart.
Miner,
The table is the same table I was talking on the ASTM std. But question here is we still use the constant n=2 from the table.So when actually we will use the other sample size from the table for IMR/XMR chart?
Sry guys coz I am still not clear on this.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Main difference between X-bar sigma chart / X-bar range chart ondrisek_SK Statistical Analysis Tools, Techniques and SPC 4 3rd February 2014 12:47 AM
What is the difference between X Bar - R Charts and Average Chart? Muhd Firdaus Statistical Analysis Tools, Techniques and SPC 7 22nd November 2013 09:56 PM
Elephant Chart Nonconformance Tracking .xls Chart - Analysis tool developed for EMS Jen Kirley Quality Tools, Improvement and Analysis 5 15th May 2009 10:04 AM
Six Sigma chart - How do I convert a database into a chart with binomial distribution jsbibra Quality Tools, Improvement and Analysis 1 10th February 2006 09:35 AM
The time now is 02:07 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
