Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Quality Tools, Improvement and Analysis
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 22nd October 2002, 12:05 AM
Luis Serrano Luis Serrano is offline
Shy Poster (1 to 5 Posts)
Registration Date: Oct 2002
Karma Power: 29
Luis Serrano has less than 100 Karma points so far.
Lightbulb DOE Integrated Methodology
It is well known that today we have three options to use "DOE phylosophies":
Traditional DOE
Taguchi Methods
Shainin Techniques
And there are tremendous disscussions about which is best!
but what happen if we combine the best of them in an integrated methodology?
For example:
1. Definition of the problem (Pareto Chart, Brainstorming, etc)
2. Use the quality loss function to determine the non-quality cost.
3. Apply Multi-vari Charts to define type of variation in the problem
4. Perform a Orthogonal Array to find the most important factors
5. With the 2 or 3 most important factors found, validate the solution using DOE Traditional
6. Then we use again Quality Loss function to measure the solution or improvement.
in other words...
1. Pareto Charts, Brainstorming, Ishikawa fishbone diagram
2. Taguchi. Quality Loss Function
3. Shainin. Multi-Vari Charts
4. Taguchi. Orthogonal Arrays
5. DOE 2 or 3 Full Factorial to Validate the solution
6. Taguchi. Quality Loss Function.
In your opinion this methodology will work?
which are the advantages or disadvantages in the methodology, considering time, cost, efforts involved?
Ideas, suggestions, comments, are welcome!
thanks for your help!
Sponsored Links
Old 24th October 2002, 02:38 PM
Ravi Khare's Avatar
Ravi Khare Ravi Khare is offline
Involved - Posts
Registration Date: Dec 2001
Karma Power: 35
Ravi Khare has less than 100 Karma points so far.
Default
The methodology certainly works well. I do it all the time. Rather than belonging to any specific school of thought, and spending valuable time defending it (and slandering others), I prefer to play for all the teams.
As you rightly pointed out, whichever technique is best to address a problem has to be used to our best advantage. After all Taguchi, Shainin and Sir Ronald Fisher (traditional DOE) have given us so much! All the knowledge that comes is welcome! Doesn't matter where it comes from.
Sponsored Links
Old 3rd November 2002, 07:06 AM
Ravi Khare's Avatar
Involved - Posts
Karma Power: 35
Default
Does anyone share this sentiment?
Old 4th November 2002, 09:32 AM
Geoff Cotton's Avatar
Geoff Cotton Geoff Cotton is offline
Courtesy Access
Registration Date: Jun 2000
Thanks Given to Others: 4
Karma Power: 42
Geoff Cotton has less than 100 Karma points so far.
Default
I share the sentiment above. Horses for courses I say.
However, isn’t step “5. DOE 2 or 3 Full Factorial to Validate the solution” encompassed within the Taguchi DoE confirmation run in step 4?
Regards
Geoff
The light at the end of the tunnel is an oncoming train - Murphy's Law
Old 4th November 2002, 11:37 AM
Ravi Khare's Avatar
Involved - Posts
Karma Power: 35
Default
Please do correct me if I am wrong...
I believe that a Full Factorial experiment will look at all the interactions, whereas the Taguchi philosophy does not take cognizence of interactions (by confounding interactions by more factors).
Does a confirmation run avoid confounding?
I would use the following good things of Taguchi methods.
1. Concurrent statistic of S/N ratio to make a trade off evaluation between being closer to the target and having a high variance.
2. Use of orthogonal arrays for conducting initial screening experiments.
3. Parameter Design, and the use of design and noise arrays to evaluate which levels of the factors are robust to tolerance level variations. I would do this with caution, and only when necessary, since the number of runs can be very large.
4. Tolerance design using sensitivity analysis. I find this method of Taguchi very similar to the classical ANOVA.
Old 5th November 2002, 12:50 AM
Karma Power: 29
My point of view about Geoff post:
It can be!
But if you do not perform Taguchi DOE confirmation run, Traditional DOE helps you test all possible combinations of factors and levels, allowing for the systematic separation and quantification of all main effects, as well as all interaction effects.
We can use DOE full factorials according Shainin: Full factorials are ideal for quantifying interaction effects.
Many people think Taguchi orthogonal arrays are weak for finding interaction effects.
In Step 3 using Multivari charts help us to reduce a large number of unmanageable possible causes or factors of variation to a much smaller family of factors containing the main effects.
After that, using orthogonal arrays we reduce even more the unmanageable possible causes (usually L4, L8 or L12 are enough)
Old 26th October 2009, 07:33 AM
kaikai kaikai is offline
Registration Date: May 2009
Karma Power: 3
kaikai has less than 100 Karma points so far.
Default Re: DOE Integrated Methodology - Traditional DOE vs. Taguchi Methods vs. Shainin Tech
Nowadays, the idea of robust design is widely spread and many method including Taguchi-method is proposed.
Taguchi-method is constantly evolving in its own.
Supersaturated Designs is evolving at a rapid pace.
We should know the variety of the methodorogy of DOE and conduct the proper DOE as the situation demands.
Old 26th October 2009, 12:35 PM
Karma Power: 29
I agreed with that. We should not think DOE methodologies are aginst each other. You can conduct The DOE as the situation demands.
If you integrate DOE methodologies, you can simplyfy the time consuming calculations too. As happened to me when I work in the 'fields'. Even more, you can explain easily others what is it all about and achieve the goal.
Think about that. The advantages of an integrated (simplified) methodology that can be easily understood and without complicated calculations.
With that, DOE will gather more people involved and interested to aply DOE as problem solver, as improvement tool, as robust design tool too.
Luis Serrano
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Shainin DOE - Paired Comparison? Background of this theory? Binomial distribution? Stevenli Six Sigma 13 13th July 2009 05:46 PM
Shainin and DOE (Design of Experiments) Information Chua Kwan Teng Misc. Quality Assurance and Business Systems Related Topics 2 6th August 2006 07:30 PM
Questions about Taguchi style Designed Experiments (DOE) Dominic Quality Tools, Improvement and Analysis 6 14th December 2004 09:06 PM
DOE - Design of Experiments - Shainin Andrews Design and Development - Process and Product 7 10th October 2003 11:44 AM
Shainin vs. Fisher vs. Taguchi DOE Andrews Quality Tools, Improvement and Analysis 9 26th August 2003 12:10 PM
The time now is 01:31 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
