Go Back   The Elsmar Cove Forum > National and International Business Standards > Various Other Specifications, Standards, and related Requirements
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 4th November 2002, 01:37 PM
Proud Liberal's Avatar
Proud Liberal Proud Liberal is offline
Courtesy Access
Registration Date: Jun 2000
Thanks Given to Others: 4
Karma Power: 41
Proud Liberal has less than 100 Karma points so far.
Truce Flatness / Straightness / Bow specification
I work in a plastic profile extrusion company that routinely deals with part bow. Our customers generally give us a specification for the entire length of the part.
Historically, parts were checked with pin gages being slid under the bow with the part on a surface plate or between two parts placed back to back. Both of these methods were ripe with error due to the "feel" required by the operator.
I designed and built a 12" fixture that is used on a optical comparator that eliminates the "feel" and increases the measurement resolution from .xxx" to .xxxx". The only problem was converting from bow/ft to overall bow specifications. To deal with that, we us a spreadsheet that:
• converts the bow (distance from the 12" cord to the high point of the arc/tangent) into the corresponding radius,
• then caculated the bow in THAT radius with a cord length = part length.
Our customer cites from GEOMETRICS by Lowell Foster the section on composite straightness. The example listed shows a straightness callout of .005" per 1.000" and the composite tolerance of .020" on part with a length of 4.00". Since the part just happens to be 4", their contention is that the .020" tolerance is calculated by multiplying the tolerance per inch by the length divided by per units measure (inches in this case).
I think that the example is an unforturnate carry over from the example in the ANSI DIMENSIONING & TOLERANCING Y14.5M standard where the math just happens to work our that way. But the standard goes further in §6.4.1.4 and explains:
"Caution should be exercised when using unit control without specigyina a maximum limit because of the relatively large throretical variations that may result if left unrestricted. If the unit variation apprears as a "bow" is allowed to continue at the same rate for several units, the overall tolerance variation may result in an unsatisfactory part."
The customer agrees this is an issue but contends that the second callout is unnecessary because of the example in the book. NOTE: see attached file for images from GEOMETRICS and ANSI Y14.5M.
I think that if the example would have been of a 96.850" part with a .002" per foot straightness and .020" overall tolerances, this confusion would have been eliminated since the overall tolerance wasn't .0161" (.002 x [96.850/12]).
I hope this isn't totally confusing.
Now, to my point. Which interpretation is correct? I have no problem either way but need a clarification for internal training purposed.
Sponsored Links
Old 4th November 2002, 01:46 PM
Courtesy Access
Karma Power: 41
Default attachment
here the attachment
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting the post it is in, 3. Use at your Own Risk.
Sponsored Links
Old 5th November 2002, 10:07 AM
Courtesy Access
Karma Power: 41
Default
No takers? Should this have been posted to a different forum? I'm surprised there isn't a metrology/GDT forum?
Or is there a better (highly unlikely) web site to pose this question?
Old 5th November 2002, 10:28 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 90
Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.Sam is appreciated, and has over 900 Karma points.
Default
Zeno,
It sounds as if you are taking a sample length of the customers product and developing your inspection sample. If so, then I would expect that your acceptance criteria would be an equal percentage of the customers' requirement.
But what about that portion of the product you don't check.
That thought woukd work if the results of the "bow" of the product was a perfectly shaped chord each time.
I may be misunderstanding your question, but I would have to err on the part of L. Foster. The diagram you show is discussing virtual condition and its effect on a part; RFS.
Personnally, I would suggest a "go, no-go" fixture that considers the entire length.
Sam Goody
Old 5th November 2002, 02:29 PM
Courtesy Access
Karma Power: 41
Default
Sam said:
Zeno,
— This is the point on which we disagree. The relationship, IMHO, is not linear (see ANSI example) and therefore not an equal percentage. —
— For our process, this is a valid assumption.—
— Unfortunately, the example is of a feature of size. I would point to the clarification example from Y15.5M. —
— That is the bone of contention. What is the tolerance for the entire length? —
Another question, is there an ANSI forum that could make a ruling?
Old 5th November 2002, 04:59 PM
Sam's Avatar
Sam Sam is offline
Karma Power: 90
Default
Zeno,
Try the attached GD&T forum.
http://www.datum-inspection.com - Link was: /forum_frm.htm
Sam Goody
Old 5th November 2002, 05:00 PM
Sam's Avatar
Sam Sam is offline
Karma Power: 90
Default
Let us know what kind of response you get.
Sam Goody
Old 13th November 2002, 12:37 PM
Ravi Khare's Avatar
Ravi Khare Ravi Khare is offline
Involved - Posts
Registration Date: Dec 2001
Karma Power: 35
Ravi Khare has less than 100 Karma points so far.
Default
Let me try and answer this.
I agree with Zeno on the fact that the total tolerance should not be extrapolated by multiplying the straightness tolerance by number of segments by which the part is longer.
Straightness per unit length and straightness across the entire length are two independent requirements which should be governed by the application the part is used for. As a matter of fact, the second callout in the frame is specifically meant to emphasize this. In case the total straightness was a result of a straight tolerance stackup of each of the running segments alitgned next to each other, the second callout would not have been necessary.
When the first callout specifies a 0.005" straightness in 1.000", it may not mean that you have to start from the begining, and measure each of the neatly divided running segments for a conformance of the 0.005" straightness. You would start anywhere within the length of the part and measure along 1.000" from there, and still should conform to a straightness of 0.005".
However Zeno, you point out that your process ensures that a perfect bow is produced, which means that the radius is uniform acorss the length of the part. In this case I would agree with your customer that the second callout is not necessary. In this case, you could go either way. You can measure a segment and extrapolate the way you have shown in the figure, or measure the virtual condition on the entire part as Sam suggested. It would amount to the same thing.
In this assumption, you will have to be careful that other cylindricity issues ( taper and roundness) don't confuse the determination of the axis and its straightness.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
How to Measure Straightness of Small Bars or Tubes (Long Length) pigeon Reliability Analysis - Predictions, Testing and Standards 19 13th May 2009 03:38 PM
Measuring Variation in Straightness of Barstock Chadbourne31 Manufacturing and Related Processes 3 2nd September 2008 03:13 PM
Dimensions and Tolerance Callout - Straightness of shaft - Concentricity Boscoeee Manufacturing and Related Processes 1 27th May 2008 05:37 PM
Bow Specification For Wood gpainter Various Other Specifications, Standards, and related Requirements 12 9th November 2007 04:53 PM
Gaping holes beginning to appear in the bow of Battleship ISO lean_machine ISO 9001 - Quality Management Systems Standard 2 13th November 2002 10:22 AM
The time now is 10:51 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
