The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Six Sigma
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
conversion factors, ppm (parts per million), zero defects, cpk (related to process capability)
Reply
Old 21st June 2012, 10:32 AM
Lpitt56 Lpitt56 is offline
Registered Visitor
Registration Date: Oct 2005
Thanks Given to Others: 2
Karma Power: 33
Lpitt56 has less than 100 Karma points so far.
Please Help! What is the Cpk for Zero Defects
I monitor my specific processes in PPM. I have a customer that says thats ok but wants to see it converted to Cpk index. I have found several conversion tables that work nicely (simply find the PPM and next column show Cpk). However, I have a few processes that over 3 month (my tracking intervals) have no defects and therefore a PPM of 0.
My conversion charts stops at a Cpk of 2 which is equivilant to .002 PPM. My question.... is it appropriate for me to show a PPM=0 as a Cpk of 2.... or what would the Cpk be fore zero defects?
Thanks!
Sponsored Links
Old 22nd June 2012, 04:20 AM
Stijloor's Avatar
Stijloor Stijloor is offline
Cross Forum Moderator
Registration Date: May 2003
Thanks Given to Others: 2,974
Karma Power: 1438
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.Stijloor is appreciated, and has over 1700 Karma points.
Re: What is the Cpk for Zero Defects
A Quick Bump!
Can someone help?
Thank you very much!!
Sponsored Links
Old 22nd June 2012, 04:27 AM
Barbara B's Avatar
Barbara B Barbara B is offline
Number Cruncher
Registration Date: May 2005
Thanks Given to Others: 95
Karma Power: 79
Barbara B is appreciated, and has over 1700 Karma points.
Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.Barbara B is appreciated, and has over 1700 Karma points.
Let me first say something about Ppk/Cpk to ppm conversion:
You can't convert Ppk/Cpk into ppm and vice versa.
Even if all the assumptions for Ppk/Cpk and ppm calculation are met (stability, normality and so on) you have to make additional assumptions to get a Ppk/Cpk out of a ppm (and the other way round). This has to do with the different formulas for Ppk/Cpk and ppm (see attached pdf).
Without further assumptions only a range for ppm out of Ppk/Cpk (or a range for Ppk/Cpk out of ppm) could be derived, depending on where the out of specification values occur (see attached Excel-sheet).
There are several webpages and other sources which provide a calculator or conversion tables, but these will only work properly under the additional assumption (like one-sided tolerances or a process mean in the middle of the tolerance for two-sided tolerances).
Back to your original question: Without the values itself it gets tricky to convert a ppm rate of 0 into a Ppk/Cpk-value. One solution is to assume that the next product will be out of the specification limit(s) and to calculate the worst-case Ppk/Cpk-value under these conditions.
E.g. if you have 100'000 products tested and all are within the specification limit(s), your ppm is 0. The worst-case assumption is that product #100'001 is outside the specification limit, leading to a maximal ppm rate of
1/100'001 *1'000'000 = 9,9999ppm
and a range for the Ppk/Cpk from 1.42 to 1.47.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
File Type: pdf Why Ppk can't be converted to ppm and vice versa.pdf (278.7 KB, 80 views)
Thanks to Barbara B for your informative Post and/or Attachment!
Old 22nd June 2012, 08:56 AM
howste's Avatar
howste howste is offline
Thaumaturge
Thanks Given to Others: 992
Karma Power: 485
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.howste is appreciated, and has over 1700 Karma points.
I agree with Barbara, that you can't really directly convert PPM into Cpk without using the actual data for the calculation. At best you can come up with an approximate value using Z-value tables.
There's a BIG problem with calculating a Cpk for 0 PPM though: A normal curve has tails that are asymptotic, meaning the tails approach zero but never reach it. Statistically speaking the Cpk value for zero PPM is infinity. I'd like to see the look on your customer's face when you tell them your Cpk = ∞.
Thanks to howste for your informative Post and/or Attachment!
Old 22nd June 2012, 01:03 PM
Bev D's Avatar
Bev D Bev D is offline
Registration Date: Jan 2003
Thanks Given to Others: 1,005
Karma Power: 324
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.Bev D is appreciated, and has over 1700 Karma points.
OK I agree completely Barbara and Howste. Converting a ppm to a Cpk is as ludicrous as converting a Cpk to a ppm. However, at the risk of perpetuating this ill-conceived abomination of statistical alchemy, sometimes it is best to pick your battles with your customers and this battle probably isn't worth it for this guy. His customer is probably happy if he can just check off the old Cpk box and there is a way to do that.
Several approaches can work (although they are all disconnected from reality, they are theoretically OK from a mathematical standpoint.)
Bayesian: This method requires that all units are inspected or tested.
P(d) = [d+1]/[n+2], P9d) is a defect rate adn can then be converted to ppm. d = number of defects and n = sample size; since d=0, the formula becomes P(d) = 1/[n+2].
Exact Upper Confidence Limit: A second method is to use the exact confidence interval for the Binomial distribution for d=0 and your sample size. Calculate the upper confidence limit (you can probably get away with a 95% confidence interval) and then take the defect rate represented by that upper limit, convert to ppm then to Cpk...
the formula in EXCEL is: BETAINV(1-alpha/2,d+1,n-d+1)
for d=0 and alppha = .05, this becomes: BETAINV(.975,1,n+1)
The Rule of 3s: A very simple approach to calculating the Upper Confidence Limit for zero defects in a sample is given by the formula:
p = 3/n for an alpha risk of .05
This formula is derived by solving the Binomial for the probability of seeing zero defects (P(0)=alpha) = (1-p)^n
This approximation works best for n> 20
*reference: “If Nothing Goes Wrong, Is Everything All Right?”, James A. Hanley and Abby Lippman-Hand, The Journal of the American Medical Association, April, 1983, Vol. 249, No. 13, pp1,743-1,745
Statistics without physics is gambling; Physics without statistics is psychics
Thank You to Bev D for your informative Post and/or Attachment!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Cpk < 1.33 - How do I estimate actual defects? Izoyd SPC Monitoring and Statistical Analysis Techniques 7 30th September 2011 05:03 PM
Zero Defects & Taguchi Loss Function - ISO 9000 and the Zero Defects Philosophy Marc Quality Tools, Improvement and Analysis 32 25th April 2004 09:26 AM
Cpk Vs DPM (Defects Per Million {aka PPM}) AllenLee Capability, Accuracy and Stability - Process, Machine, etc. 3 29th December 2001 01:26 PM
SPC (minimizing defects) Vs Poka Yoke (zeroing out defects) Marloun SPC Monitoring and Statistical Analysis Techniques 3 3rd May 2000 06:05 PM
Defects and Systems - Zero Defects and its proponents, Poka Yoke, etc. Don Winton Preventive Action and Continuous Improvement 14 6th March 2000 05:47 PM
The time now is 05:23 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
