Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
6th July 2012, 12:37 PM
Shy Poster (1 to 5 Posts)
Registration Date: Jul 2012
Karma Power: 4 Karma: 10
PPAP Sample Requirement - Using Product which has been Re-Worked
When submitting product sample to customer for PPAP is there a requirement which prevents using product which has been re-worked to achieve dimensional and profile compliance? Currently have some aluminum flat bar that is out of flatness tolerance. It can be reworked to achieve tolerance etc., but would samples be permissible for a PPAP?
Thanks,
Alextusions
6th July 2012, 01:09 PM
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,780
Karma Power: 1445
Re: PPAP Sample Requirement
In Reply to Parent Post by ALExtrusions
Thanks,
Alextusions
Welcome to the Cove.
PPAP samples are presumed to be from the "significant production run" and be representative of the regular production process. It's not clear whether the material you refer to is raw stock or post-production. If you add a flatten-if-necessary operation to your routing and APQP documents, use of the material would be permissible.
We aim to please. You aim too, please.
Thanks to Jim Wynne for your informative Post and/or Attachment!
6th July 2012, 02:06 PM
Q. A. Manager
Registration Date: Apr 2007
Thanks Given to Others: 405
Karma Power: 75
Re: PPAP Sample Requirement - Using Product which has been Re-Worked
In section 3, heading 3.1 - Customer Notification, Examples of Changes Requiring Notification it states "Use of other construction or material than was used in the previously approved part or product." If you are not going to use the same lot of material for production that you used for your PPAP, you have to notify your customer of the change.
Doug
W4JDZ
6th July 2012, 02:40 PM
Karma Power: 1445
In Reply to Parent Post by silentrunning
The OP is referring to PPAP samples.
6th July 2012, 03:03 PM
Q. A. Manager
Karma Power: 75
In Reply to Parent Post by Jim Wynne
Jim, don't the PPAP samples (ours was always 300) have to be of the same material as the future production run? I may have been misinformed on this?
Doug
W4JDZ
6th July 2012, 03:16 PM
Karma Power: 1445
The bit you quoted from the PPAP manual refers to parts made after PPAP approval. The OP has apparently not submitted his PPAP yet, because he's asking about whether or not he should submit PPAP samples that have been reworked.
The PPAP "significant production run" default quantity is 300 pieces, but the sample quantity (samples submitted to the customer along with the PPAP documentation) is usually less than that.
6th July 2012, 03:28 PM
Q. A. Manager
Karma Power: 75
Thanks for the clarification Jim.
Doug
W4JDZ
Forum Posting Settings
