Elsmar Cove Forum Sidebar
Monitor the Elsmar Forum
| Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Groups
Sponsor Links
Sponsored Links
Courtesy Quick Links
Atul's Symphony Technologies
Quality Digest Portal
17th July 2012, 05:46 AM
Shy Poster (1 to 5 Posts)
Registration Date: Jan 2011
Karma Power: 10 Karma: 10
Boundary of Clause 8.3 - Control of Nonconforming Product
Is this right that this clause is for products manufacture/produced in the company and purchased products both? Somebody told me that any violation of rules/policies/SOPs non conformance also covers that for example if someone in the organization not following leave procedure then this clause will be applied. Please suggest.
17th July 2012, 07:20 AM
Cross Forum Moderator
Registration Date: Mar 2008
Thanks Given to Others: 1,209
Karma Power: 431
Re: Boundary of 8.3 clause - Control of nonconforming product
In Reply to Parent Post by nabilpk
Good one this ...
This will not even come under the 8.2.3, however when you read the NOTE under the 8.2.3, you can consider how correction / corrective action can be taken up for your situation.
Best Regards...
Somashekar BV, INDIA
17th July 2012, 08:50 AM
On Holiday
Registration Date: Jan 2012
Thanks Given to Others: 3
Karma Power: 0 Karma: 35
Yes, 8.3 also applies to purchased product. 7.4.1 and 7.4.3 require purchased product to be verified to meet purchasing requirements before use. If product is found not to meet requirements, it is treated as nonconforming product.
However, failure to follow a procedure itself is not nonconforming product. It is a nonconformity, however, treated according to 8.5.2--not 8.3.
Thanks to snappy for your informative Post and/or Attachment!
17th July 2012, 10:09 AM
Appreciated Information Resource
Registration Date: Feb 2008
Thanks Given to Others: 849
Karma Power: 225
In Reply to Parent Post by snappy
Unless nonconforming product is the result of not following a procedure. For example, not following a procedure for a special process could create a problem that may not be identifiable until it has been in use for some time.
17th July 2012, 11:04 AM
On Holiday
In Reply to Parent Post by Big Jim
It is true that nonconforming product may result from not following a procedure. Are you saying in a case of a special process, for example, that not following the procedure is itself nonconforming product? Not following a procedure is not a product in the first place, thus cannot be nonconforming product.
That's why I stated that not following the procedure ITSELF is not nonconforming product. At least in this case.
18th July 2012, 12:38 AM
Karma Power: 225
So how would you handle that situation? Would you knowingly leave questionable product in use once you discovered that it may have been compromised?
18th July 2012, 01:24 AM
Re: Boundary of Clause 8.3 - Control of Nonconforming Product
Actually my question has two parts:
1) Whether 8.3 clause of standard covers both manufactured and purchased products?
2) We have made one Employee Handbook in which code of conduct are mentioned plus leave taking procedures etc. This handbook is under the HR department. If someone is not following leave procedure then non-conformance should be raised. In our NC form we have to mention ISO standard clause as well. Kindly confirm which clause should be mentioned there? Is this 6.2.1 or something else?
18th July 2012, 04:31 AM
Involved in Discussions
Registration Date: Oct 2010
Location: living shenzhen city guangdong province P.R.C
Karma Power: 48
1. yes, that clause is covered not meet customer or yourself company requirements all products
2. if that worker had trained, this ncn doesn't belong to clause 6.2.1 and is clause 8.3
Forum Posting Settings
