The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > APQP and PPAP
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
part family, parts, plating & coatings, ppap (production part approval process)
Reply
Old 1st August 2012, 03:51 PM
vardar3 vardar3 is offline
Involved in Discussions
Registration Date: Sep 2011
Thanks Given to Others: 39
Karma Power: 17
vardar3 has less than 100 Karma points so far.
Please Help! PPAP Requirements for Plating a "Family of Parts"
Our platers plate several parts. If the parts they are plating has the same material callout, could they PPAP all parts with same material and plating as a “family of parts” under one PPAP?
Sponsored Links
Old 1st August 2012, 03:59 PM
Jim Wynne's Avatar
Jim Wynne Jim Wynne is offline
Cross Forum Moderator
Registration Date: Jan 2005
Thanks Given to Others: 1,779
Karma Power: 1445
Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.Jim Wynne is appreciated, and has over 1700 Karma points.
Re: Plating "Family of parts"
In Reply to Parent Post by vardar3 View Post
By "material callout," do you mean that the material specifications and plating specifications are the same for all of the parts? The answer to your question will ultimately have to come from your customer(s). At the least I would expect a separate PSW for each part number, even if everything else is the same. If I were your customer, I would also want to see (and approve) your plater's PFMEA and control plan.
We aim to please. You aim too, please.
Sponsored Links
Old 2nd August 2012, 10:01 AM
iamtroll iamtroll is offline
Registration Date: Apr 2011
Thanks Given to Others: 7
Karma Power: 14
iamtroll is appreciated, and has over 200 Karma points.iamtroll is appreciated, and has over 200 Karma points.iamtroll is appreciated, and has over 200 Karma points.
Re: PPAP Requirements for Plating a "Family of Parts"
Base material and plating material is probably not enough to call a group of parts a family. At a minimum I think that you need to consider part configuration, racking methods, time in tank and amperage since these can vary significanlty in your processing. Some customers, particularly medical customers may limit you to a unique tank and require a validation while aircraft customers could include a frozen process requirement. Other customers may be more lenient but those are just a few of the considerations that could come up in a plating PPAP that could influence the family groupings.
Old 4th August 2012, 11:55 AM
hkrishnan1983 hkrishnan1983 is offline
Registration Date: May 2010
Karma Power: 15
hkrishnan1983 has less than 100 Karma points so far.
Jim,
If you were his customer, what level of PPAP you ask for? Level 2?
if yes, does the level 2 PPAP requires PTR?
Can you pls tell us how to do product & process validation for plating parts?
Pls share your views...
Thanks, Harikrishnan
Old 4th August 2012, 02:00 PM
Jim Wynne's Avatar
Karma Power: 1445
In Reply to Parent Post by hkrishnan1983 View Post
Jim,
The PPAP level would depend on the level of risk involved.
I don't know what you mean by "PTR."
This is too deep a subject for a comprehensive answer here. The first step is to determine the performance requirements of the product. This could involve cosmetic issues, corrosion resistance and a number of other considerations. Once established, the idea would be to design a plating process that will yield the desired results, run the process, and test the parts. The variables in the plating process--things like bath chemistry, temperature, current, agitation---must be identified and controlled such that the desired result is consistently achieved.
Old 4th August 2012, 11:19 PM
Karma Power: 15
PTR is production trial run or run at rate. It is coming in 4th phase of APQP(product and process validation) to quality mfg and quality capability of suppliers.
Old 5th August 2012, 09:21 AM
Jim Wynne's Avatar
Karma Power: 1445
What you describe as "production trial run" is not the same as run at rate. The latter typically takes place after PPAP approval.
Old 5th August 2012, 11:42 AM
Karma Power: 15
pls tell specific difference between PTR & Run @ Rate...
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Plating Supplier PPAP Revalidation Requirements - A-Coat GM 9984132 Plating Process vardar3 APQP and PPAP 1 22nd March 2012 08:22 AM
TS16949 Annual PPAP Submission Requirements for Ford and Chrysler Parts beaser3 ISO/TS 16949 - International Automotive Quality Systems Standard 2 20th October 2011 09:37 AM
Sample Retention - Subcontracted Plating Service - PPAP Requirements Randy Stewart Service Industry Specific Topics 11 3rd March 2004 05:41 PM
Definition of family of parts - PPAP Sec.II - FORD Specific Instructions Micaelah Ash APQP and PPAP 4 20th April 2000 11:52 PM
PPAP Master Parts - Do we have to save the original PPAP parts? Dawn APQP and PPAP 2 27th October 1998 06:36 AM
The time now is 10:05 AM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, Olde West Chester, Ohio 45069-1929
513 341-6272
