Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO/TS 16949 - International Automotive Quality Systems Standard > QS-9000 - American Automotive Manufacturers Standard
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 29th January 1999, 10:06 PM
Rose Ann
Unregistered Guest
Posts: n/a
Default 4.1.4 Business Plan preparation
I'm a new Production Manager (4 wks.). I was thrown into this position un-expectantly. Now I'm told I have to write a business plan with short term and long term goals. I've recieved a little advice on how to do this, but I want to do a good job. Can you help? Our audit is in 2 wks.
Sponsored Links
Old 30th January 1999, 10:46 AM
Bryon C Simmons
Unregistered Guest
Posts: n/a
Default
Hi.
Seems kind of unusual for your executive management to delegate the writing of the business plan to a production manager. Typically, this is a senior level management document, to be used by senior management in the planning and execution of future business plans for the future success of your company. While I have no doubt that you are capable of writing it, it seems a bit odd.
I am not sure you will be able to develop a plan in two weeks. best I can tell you would be to look at the requirements that the standard calls out, and try to gather as much information as you can that already exists, and put that into some type of usuable format. Remember, the Business Plan is confidential...the auditors can't look at it, if you dont show it to them. My experiene is, that they will want to see evidence of its existence.....like maybe a table of contents or equivalent, and then in your Level II procedures, state your methods of tracking, updating, revising, etc. Also, you need to control the pan, per 4.5 This is relatively easy to do. COntrol it similar to your Quality manual.
Put together a format.....may be all the time you will have, prior to the audit. If your audit is pre-assessment, you will get a non-compliance perhaps, but that will give you time to develop it better, prior to the registration audit. If this is a registration audit, then your plan should already be in existence somewhere. Ask your senior management if they have any of hie types of data that should be included. THey may have something started already, and just not aware of it.
Hope this helps.
Bryon
Sponsored Links
Old 31st January 1999, 08:27 PM
Rose Ann
Unregistered Guest
Posts: n/a
Default
Let me clarify. I only have to write the portion of the business plan that applies to my position. I have become better informed and what they are really looking for is a strategic plan to show continuous improvement. Not the company business plan. I think I'll go with bench marking where we are at now and where I hope to be in the future. Does that sound like the right direction?
Old 1st February 1999, 02:03 PM
Kevin Mader's Avatar
Kevin Mader Kevin Mader is offline
One of THE Original Covers!
Registration Date: Nov 1998
Thanks Given to Others: 22
Karma Power: 94
Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.Kevin Mader is appreciated, and has over 1300 Karma points.
Send a message via AIM to Kevin Mader
Default
Rose Ann,
Traditionally, strategic plans, as you clarified, are used to develop the senior level business plan. Bryon has given details on the control of the business plan. Your idea to benchmark is a good one (keep in mind that you benchmark against an outside agent, generally a "best pratice" outfit). Your idea to use baseline data for comparative measures is also a good idea. When developing your strategic plans, state your objectives and goals in specific, measurable, and realistic terms. Determine your possible obstacles and solutions for them and bulletize when ever possible (as in an Executive Summary). The simpler the stated terms and benefits are, the better. Only the highlights of your strategic plans will be outlined in the Business Plan anyway. For production, I might include topics such as Labor Variance, Labor Efficiencies, plans to automate, and training. Be sure to have a mix of short term and long term topics. I hope this helps to get you going. Good Luck!
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Linking Quality Plan Objectives to the Business Plan? Buford ISO/TS 16949 - International Automotive Quality Systems Standard 7 28th January 2008 10:02 PM
Step by step methodology in Preparation of Dynamic Control Plan (DCP) bkarthikeyan FMEA and Control Plans 1 12th August 2007 12:31 PM
Business Plan Requirements - 4.1.1.2 Scope of quality objectives in the business plan Dawn ISO/TS 16949 - International Automotive Quality Systems Standard 15 22nd July 2005 03:20 AM
Business plan/ Benchmark - Input of business plan/marketing strategy and benchmarks Martin APQP and PPAP 2 11th May 2000 07:46 AM
Business Plan ISO 9000:2000 - Who are they to say we need a Business Plan? Aaron Lupo ISO 9001 - Quality Management Systems Standard 11 9th May 2000 12:03 PM
The time now is 06:00 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
