Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Capability, Accuracy and Stability - Process, Machine, etc.
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 6th December 2002, 11:47 AM
mike101338's Avatar
mike101338 mike101338 is offline
E-Mails Invalid or Rejected
Registration Date: Dec 2002
Karma Power: 0
mike101338 is appreciated, and has over 100 Karma points.mike101338 is appreciated, and has over 100 Karma points.
Question Attribute Charting - Where does Cp and Cpk come into the equation?
Let me start by saying statistics is something fairly new to me. Let me give some background on how we inspect to make sure I am moving in the right direction.
All inspections we perform is on a pass / fail method. We track our bad product as defective, not defects. Run quantities and sample size quanities are variable.
I am using a p chart to track the data. Once graphed I can show stability. I am struggling with how I demonstrate capability. Is this where Cp and Cpk come into the equation? If so, how?
Defining what the USL and LSL is an unknown to me. I am assuming the LSL is 0, as you can not have less than 0 defects. However when I enter this into the Cpk analysis it shows that I am out of spec on the low side. Not possible as 0 defects is perfect, not out of spec. When I enter the USL, I have chosen 3 percent (not the goal, but anything lower at this time would turn people off to SPC). In order for me to attain a Cpk of 1.33 with 3 percent defect I have to attain a sigma level of greater than 4, with a DPM of 30, which is obvoisly not 3 percent. Have I not entered data correctly somewhere or have I made a mistake somewhere else?
Any advice anyone can give me is greatly appreciated.
Mike
Sponsored Links
Old 6th December 2002, 03:21 PM
ben ben is offline
Registration Date: Sep 2002
Karma Power: 31
ben has less than 100 Karma points so far.
Default
Since there are no specification limits for attirbutes, attribute data cannot be used to calculate a Cpk value.
However, you might try calculating the equivalent Cpk.
For example, say your average fraction nonconforming (p-bar) is .00023 or .023%.
Find .00023 on the Z table, which gives you a Z score of 3.50.
Divide 3.50 by 3 for an equivalent Cpk of 1.16.
To hit an equivalent Cpk of 1.33, you will need a maximum defect rate of around 64 per million.
Sponsored Links
Old 6th December 2002, 04:04 PM
mike101338's Avatar
Karma Power: 0
Default
Thanks for your advice Ben. Can you tell me where I can find a z table. I have one, but it leaves large gaps in the percentages. If I am going to use this with any regularity then I need a chart with greater detail.
Thanks,
Mike
Old 6th December 2002, 04:36 PM
Bill Ryan's Avatar
Bill Ryan Bill Ryan is offline
Dogs rule
Registration Date: Jul 2002
Thanks Given to Others: 15
Karma Power: 69
Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.Bill Ryan is appreciated, and has over 900 Karma points.
Default
Mike,
Welcomr to the cove!
This link has as full a Z-table as I've ever required or it can usually be found in any statistical reference book.
http://www.statsoft.com/textbook/sttable.html
Bill
There is no psychiatrist in the world like a puppy licking your face. - Ben Williams
Old 6th December 2002, 04:40 PM
Bill Ryan's Avatar
Dogs rule
Karma Power: 69
Default
I messed something up posting the link but if you copy the address and paste it in the search line it works.
Sorry,
Bill
Old 6th December 2002, 10:04 PM
Ravi Khare's Avatar
Ravi Khare Ravi Khare is offline
Involved - Posts
Registration Date: Dec 2001
Karma Power: 35
Ravi Khare has less than 100 Karma points so far.
Default Z table
If you have a copy of MS Excel handy, you could get the z score of any value at a fine resolution. There are 3 functions related to Normal Distributions within Excel.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Method to compute Cpk for Attribute Data? reynald Capability, Accuracy and Stability - Process, Machine, etc. 3 29th January 2009 07:10 PM
Cpk for attribute data? Performing SPC on capacitors - Capacitance measurement M Caruso SPC Monitoring and Statistical Analysis Techniques 9 8th March 2006 05:05 PM
Every problem in world has linear regression equation ?!!?? cyberspider SPC Monitoring and Statistical Analysis Techniques 9 19th August 2005 05:09 PM
Attribute capability indices - Cpk and/or Ppk value for an attribute type of feature Bill Ryan Capability, Accuracy and Stability - Process, Machine, etc. 7 11th July 2005 09:53 AM
Help me figure out the Prediction Interval Equation Michel Saad SPC Monitoring and Statistical Analysis Techniques 2 23rd May 2005 04:24 PM
The time now is 04:27 PM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
