The Elsmar Cove Wiki More Free Files The Elsmar Cove Forums Discussion Thread Index Post Attachments Listing Failure Modes Services and Solutions to Problems Elsmar cove Forums Main Page Elsmar Cove Home Page
Go Back   The Elsmar Cove Forum > ISO (International Organization for Standardization) Standards > ISO 10013 - Quality Management System (QMS) Manuals
Forum Username
Elsmar Cove Forum Sidebar
Custom Search
Monitor the Elsmar Forum
Monitor New Forum Posts
Follow Marc & Elsmar
Elsmar Cove Forum RSS Feed  Marc Smith's Google+ Page  Marc Smith's Linked In Page   Marc Smith's Elsmar Cove YouTube Page  Marc Smith's Facebook Page
Elsmar Cove Groups
Elsmar Cove Google+ Group  Elsmar Cove LinkedIn Group  Elsmar Cove Facebook Group
Sponsor Links
Sponsored Links
Courtesy Quick Links
Howard's
Atul's
Symphony Technologies
Marcelo Antunes'
SQR Consulting
Bob Doering's
Quality Digest Portal
Related Topic Tags
quality system manuals, iso 10013 - quality management system manuals, ts 16949 - automotive quality system standard, forms and templates (general)
Reply
Thread Tools Search this Thread Rating: Thread Rating: 2 votes, 4.50 average. Display Modes
  #41
Old 20th October 2002, 04:34 PM
Barbara
Unregistered Guest
Posts: n/a
Yin Yang TS Manual Template
I too need a TS 16949 template manual and feel there is nothing wrong with wanting a template to get you started. That's why we get audited every 6 months, to insure that we are following our manuals. If all I wanted was a TS manual to shove under a auditor nose, then that auditor is going to know what up by the end of the audit and the company I work for would have wasted alot of money trying to move ahead.
Sponsored Links
  #42
Old 21st October 2002, 09:21 AM
Sam's Avatar
Sam Sam is offline
Registration Date: Sep 1999
Thanks Given to Others: 1
Karma Power: 202
Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.Sam is appreciated, and has over 1100 Karma points.
QM Template: (ref 4.2.2)
the quality manual shall include;
- the scope of the quality management system, including details of and justification for any exclusions(1.2).
* the scope as it will appear on your certificate.
- the documented procedures established for the quality management system, or reference to them,
* there are only seven documented procedures required. list these by number. you may add additional procedures if necessary.
- a description of the interaction between the processes of the quality management system.
* process mapping; depending on the type of process, will include a process flow chart/control plan describing the inputs and outputs.
This information makes up the requirement for a quality manual.
Suggestion:
1- read notes 1,2 & 3 at the end of 4.2.1.
2- in the spec highlight the term "documented procedure(s). should be 7. if you are QS you should already have these procedures.
3- highlight the term "process/processes" and the "shall" that goes with it. Do you have a document that fully describes the process? if so, use it. If not prepare a process map.
4- Highlight the remaining "shalls". Yuo should have existing document that satisfies these requirements. If not, consider using a process map.
Sam Goody
Sponsored Links
  #43
Old 21st October 2002, 09:30 PM
JAN2 JAN2 is offline
Involved in Discussions
Registration Date: Sep 2002
Thanks Given to Others: 3
Karma Power: 45
JAN2 has less than 100 Karma points so far.
Everyone:
I always try to do it ,but always haven't clear proposition,could you tell me particular ;
I think program maybe include scope , nomenclature,responsibility,input,output,work program,inspect,record;
may I?
I think flow chart instead of input,output,work program,inspect may I?
jan2
  #44
Old 22nd October 2002, 04:09 AM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 213
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Jim
TS16949 also mandates procedures for the identification of training needs and achieving competence.
Why ?
Because trainign is probably the single most important thing in the QMS ? Maybe ??
  #45
Old 22nd October 2002, 04:45 AM
Courtesy Access
Karma Power: 213
Training is part of the system is it not ?
Why does it appear in the QMS standards if it is not part of the system ??
A system failure could well be lack of training, or poor training.
So you can knock your bleeding laughing faces on the head wise guy
  #46
Old 22nd October 2002, 05:33 AM
Manoj Mathur Manoj Mathur is offline
Appreciated Member
Registration Date: Jun 2002
Thanks Given to Others: 5
Karma Power: 77
Manoj Mathur is appreciated, and has over 700 Karma points.Manoj Mathur is appreciated, and has over 700 Karma points.Manoj Mathur is appreciated, and has over 700 Karma points.Manoj Mathur is appreciated, and has over 700 Karma points.Manoj Mathur is appreciated, and has over 700 Karma points.Manoj Mathur is appreciated, and has over 700 Karma points.Manoj Mathur is appreciated, and has over 700 Karma points.
Red Face Quality Manual
Hello Everybody!
Please find attached our Quality Manual.
It is in two Zip files.
Pl. give your feedback on it.
  #47
Old 22nd October 2002, 05:45 AM
Appreciated Member
Karma Power: 77
Hello Everybody!
OOPS!
Actually I found that Even the Zip files are 4 MB sizes and I can't send it thro this route since max limit is 80000. Hence I am sending one part of my quality manual wishing it reaches to you. Can you suggest me how can I send it the complete manual.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
  #48
Old 22nd October 2002, 09:34 AM
Sam's Avatar
Sam Sam is offline
Karma Power: 202
Jim,
The same six plus one for training. Para 6.2.2.2
Sam Goody
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
ISO9001:2000 Quality Work Instructions & Forms - Seeking Templates and Examples vattony Documentation Control Systems, Procedures, Forms and Templates 41 17th June 2011 01:09 PM
TS 16949 Document (Procedures, etc.) Format Examples/Templates Chip Houser Documentation Control Systems, Procedures, Forms and Templates 2 28th August 2008 12:49 PM
TS 16949 Process Interactions Map - Examples and a Spirited Discussion Mustang ISO/TS 16949 - International Automotive Quality Systems Standard 19 1st April 2004 06:39 AM
The time now is 04:36 PM. All times are GMT -4.
Marc Timothy Smith - Elsmar.com
8466 LeSourdsville-West Chester Road, West Chester, Ohio 45069-1929
513 341-6272
