The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Medical Devices, Medical Information Technology, Medical Software and Health Informatics > Medical Device Related Standards > ISO 13485 and ISO 14969 - Medical Devices - Quality Management Systems
Forum Username
Wooden Line
Sterile Medical Packaging and Shelf Life Validation Sample size - Page 2
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Related Topic Tags
fda requirements, medical device registration, packaging qualification and validation, sterile packaging, sterility and sterilization techniques, validation testing
Reply
  Post Number #9
Old 12th December 2012, 05:19 AM
Ronen E
Re: Sterile Medical Packaging and Shelf Life Validation Sample size
In Reply to Parent Post by phloQS View Post
First of all, thanks for all the responses. Maybe I described my validation approach a bit too short. We will do several test for seal integritiy as well as packaging integrity. The seal integrity is testted trough peel-test, dye-test and burst-test, each with 5 samples where the peeltest is done on each side of the blister so there are four samples for each blister, 20 in alltogether. It is NOT the sterility testing, just the test for packaging (and seal) integrity. We perfom all the described test in five stages: before sterilisation, after sterilisation, after transport simulation after accelerated aging and the last tests after real time aging. What we want to show is, that sterilisation and transport have no bad influence on the packaging. We already have studies for another system with the same study design. The results on each stage are very similar, so the influence of the sterilisation and the transport seem to be very low. The data overall looks very good. Seal strength is far above the limit suggested in standards (DIN EN 868-5:2009). So again from your point of view: would that studydesign be sufficient for an FDA inspection, although we only use five samples for each test (but in total there are 100 samples, twenty in each stage) and have no statisticsal rationale beyond this?
regards
phloQS
A few remarks:
1. The only thing that statistically counts is repetitions, i.e. the number of test samples from the exact same configuration. The fact that you repeat the process at various stages (or repeat the sampling & testing at different pouch locations) does not add to the statistical rigour, unless you analyse them as one "population" (which will also increase the within-sample variation).
2. From all I've seen from the FDA, "no statistical rationale" is bad practice.
3. When I referred to "sterile barrier validation" I didn't only relate to the "narrow" aspect of sterility tests; I also related to what you call seal testing or seal validation. It has (IMO) the same level of criticality because it directly afects the end result - sterility of the device when put into use.
4. Seal strength (as demonstrated, for example, in peel tests) is important, but it's not the most important factor (understatement) when considering sterile barrier quality / reliability. You could have a perfect, consistent strong "seal" (e.g. weld) which is in fact not properly sealing, i.e. not a sterile barrier. I'd put more emphasis on burst / dye tests. BTW, both these last tests are not trivial in terms of establishing the test methods, analysis and pass/fail criteria.
5. Perhaps instead of sampling all 4 sides of the pouch for peel testing, consider getting validation data / certification from the original pouch manufacturer, for the originally sealed 3 sides, and redirect some of your resources into enlarging the sample size from the side you seal (or other tests you perform).
Cheers,
Ronen.
Sponsored Links
  Post Number #10
Old 12th December 2012, 06:14 AM
phloQS
@Ronen E: I know that I have to perform repititions for statistics. This is why I said "no statistical rationale". But all the data collected shows to me that our packaging system is valid. For the old system i talked about, the process control shows that our assumption for that system was right. We never had any problems or bad data for this process, which is very stable. We perfom dyetest and seal-strength-test (sample-based) and 100% visual inspection.
Our new packaging system is a blister with a sealed tyvek lid on top. So all four seals are made in our process. The sealing process itsself is validated (IQ,OQ with critical parameters, PQ with samples from three batches (n=5)), No test shows any significant variation (burst, dye, peel). The peel strength as the only continous data is very consistent. So this is the baseline for our shelf-life validation.
Regards
phloQS
Sponsored Links
  Post Number #11
Old 12th December 2012, 11:19 AM
Ronen E
Regards
phloQS
If you have solid data to show that an existing system meets the applicable requirements, and a solid justification that a newly launched system is equivalent and poses no new significant risks, then maybe that can suffice.
Adequate visual appearance (as captured via visual inspection) may be an essential prerequisite, but is in my opinion not a significant contributor to confidence regarding sterile barrier quality & reliability.
If all sides of the seal are created in a single process, by a single tool and with the same parameter settings, and you have established consistency of temperatures, pressure, duration etc. for all 4 sides, then I'd say you could statistically pool together all results from all 4 sides.
I'm not sure I got you right, but if you have a separate "packaging validation", "sterile barrier validation" and "shelf-life validation", then in my opinion this is unnecessarily complicated. I reckon all such activities can be combined into a single validation endeavour.
Cheers,
Ronen.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Non-Sterile Class 2 Medical Device Shelf Life Jim H Other Medical Device Related Standards 3 22nd December 2014 10:02 AM
Shelf Life Testing of a Sterile Medical Device mwa Other Medical Device and Orthopedic Related Topics 40 25th July 2013 08:54 AM
Expiry Dates on a Non-Sterile Class 1 Medical Device (5 Year Shelf Life). Quality Priest Other Medical Device and Orthopedic Related Topics 5 16th December 2011 09:23 AM
Reference Standard for Shelf Life Testing of Packaging for Sterilized Medical Device Ethan Loh Other US Medical Device Regulations 3 17th December 2010 09:49 AM
Shelf Life Validation for new Heat Impulse Medical Packaging Sealer JJLit Qualification and Validation (including 21 CFR Part 11) 2 9th September 2010 04:34 AM
The time now is 11:37 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
