Go Back   The Elsmar Cove Forum > Common Quality Assurance Processes and Tools > Nonconformance and Corrective Action
Monitor the Forum
Monitor New Forum Posts
New Threads Feeds
RSS FeedRSS Feed
Sponsor Link
$ Contributor Forum Access
Courtesy Quick Links
Atul's Symphony Technologies
Praxiom Research Group
Quality Digest Portal
Reply
Old 25th January 2003, 09:58 AM
Andrews Andrews is offline
Involved - Posts
Registration Date: Oct 2001
Karma Power: 39
Andrews has less than 100 Karma points so far.
Default corrective action
During our last corrective action team meeting , we found that around 60% of the quality problems were due to the operators not inspecting the parts as per the control plan given to them. What should be done in such cases? Inspite of numerous training programmes and warnings, we found that this situation is not improving. any suggestions?
Sponsored Links
Old 26th January 2003, 02:28 PM
M Greenaway's Avatar
M Greenaway M Greenaway is offline
Courtesy Access
Registration Date: Dec 2001
Thanks Given to Others: 10
Karma Power: 80
M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.M Greenaway is appreciated, and has over 700 Karma points.
Default
I suggest you do a '5 Why' analysis on the inspection process to determine root cause.
If the inspectors are just plain negligent (possible but doubtful) then you would need to take disciplinary action, however I would suspect that you find a problem somewhere with the system.
If on the other hand you actually want to improve quality try to determine the causes of the actual faults and eliminate them, as you cannot inspect quality into the product.
Sponsored Links
Old 13th March 2003, 09:42 AM
Involved - Posts
Karma Power: 39
Default
The quality problems could have been identified if the operator had checked the components at the frequency of 10 pieces / hour as required by the control plan.
In one case the operator had not taken out the end bits that was found in the production batch inspite of us providing a sensor that STOPS the machine if there is not sufficient material to feed the bar to the required length.
Old 13th March 2003, 10:32 AM
Mike S. Mike S. is offline
An Early 'Cover'
Registration Date: Mar 2002
Thanks Given to Others: 24
Karma Power: 103
Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.Mike S. is appreciated, and has over 1700 Karma points.
Default
Andrews,
I don't know enough about the problem to comment in depth, but Martin's idea is a good one. I would also say you could try throwing the problem back at those believed to be "at fault". Tell them the problem, the consequences of the problem to the rest of the process or the customer or money/time lost or whatever, and then ask them how they propose to eliminate this problem. Sometimes this works and you find some solutions you would not have considered and you get more buy-in.
Mike S. ("Gun Nut")
And they ask me why I drink....
Old 13th March 2003, 04:09 PM
gpainter gpainter is offline
Courtesy Access
Registration Date: Sep 2001
Thanks Given to Others: 3
Karma Power: 65
gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.gpainter is appreciated, and has over 500 Karma points.
Default
Are your operators on an ineffective production bonus system.
Old 13th March 2003, 04:27 PM
David Hartman's Avatar
David Hartman David Hartman is offline
Courtesy Access
Registration Date: Feb 2003
Karma Power: 66
David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.David Hartman is appreciated, and has over 1300 Karma points.
Default
Perhaps you need to go back to the operators and explain to them what you have observed, and ask them why they are not performing the inspections according to the control plan.
You may find such system issues as: Unrealistic production quotas that do not allow time for inspection, inefficient inspection methods/tooling, or any number of issues attributable to the system and not the workers.
I continue to believe that a worker will do the right things, if the system allows.
David D. Hartman
Old 13th March 2003, 05:01 PM
Al Dyer's Avatar
Al Dyer Al Dyer is offline
Mod...
Registration Date: Mar 2003
Thanks Given to Others: 4
Karma Power: 46
Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.Al Dyer is appreciated, and has over 300 Karma points.
Send a message via AIM to Al Dyer
Default
Sounds like root cause has not been adequately determined.
How about getting away from the operator for the moment and think about why training, write-ups, discipline have not worked?
Are instructions posted?
Have the instructions been tested for ease of use?
Is the level of supervision on the floor adequate?
Is final quality responsibility with manufacturing or quality?
Are there language or dialect problems?
Are there ongoing tests of operator capabilities?
Does management really care?
Are you using the correct tools to determine process capability?
Is the gage control system robust and proven?
ETC...
Just wanted to get the gist of my view across.
"Para ... Bellum"
Old 13th June 2003, 12:48 PM
Andrei Viorel Andrei Viorel is offline
Involved in Discussions
Registration Date: May 2002
Karma Power: 36
Andrei Viorel is appreciated, and has over 200 Karma points.Andrei Viorel is appreciated, and has over 200 Karma points.Andrei Viorel is appreciated, and has over 200 Karma points.
Default
Did you try to apply The Golden Rules of Gemba KAIZEN?
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
BB code is On
Smilies are On
[IMG] code is On
Forum Jump
Similar Discussion Threads
Corrective Action vs. Failure Analysis - Corrective Action for Every Defect Found? Shawn97701 Nonconformance and Corrective Action 5 6th December 2007 04:48 AM
Tracking Corrective Action - Preventive Action - Simple Product/Documentation Change craig-c Nonconformance and Corrective Action 1 27th November 2006 05:35 PM
8D - proposed corrective action, and then a corrective action implementation Clarence.L Preventive Action and Continuous Improvement 2 26th May 2004 04:04 PM
Corrective Action and Preventive Action clauses - ISO 9001 - Corrective Action Ace Nonconformance and Corrective Action 6 26th November 2001 01:47 AM
Combining Corrective Action / NCP / Customer Complaint Documentation ISO in Baltimore Customer Complaints including ISO 10002 5 3rd August 2001 11:02 AM
The time now is 09:40 AM. All times are GMT -4.
Site courtesy of:
(513) 341-6272
no new posts
