The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Business Systems and Standards Discussion Forums > Medical Devices, Medical Information Technology, Medical Software and Health Informatics > Medical Device Related Standards > IEC 60601 - Medical Electrical Equipment Safety Standards Series
Forum Username
Wooden Line
IEC 60601-1-11 - Medical Electrical Equipment IP (Ingress Protection) Requirements
Elsmar XML RSS Feed
Elsmar Cove Forum RSS Feed
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Atul's
Quality Forum Online
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering
Bob Doering's Blogs and,
Quality Digest
Related LinkedIn Groups
ISO 9001 for Small Businesses
ISO 9001:2015 Revision Discussions
Information Security Community
Medical Devices Group
Quality and Regulatory Network
FDA (Food and Drugs)
AS91XX Series - Tips and Advice
Related Topic Tags
iec 60601 - medical electrical equipment, ingress protection, medical device electronics and electrical equipment
Reply
  Post Number #1
Old 6th March 2013, 01:55 PM
petruchio
Please Help! IEC 60601-1-11 - Medical Electrical Equipment IP (Ingress Protection) Requirements
Hi
Sub-clause 8.3.1 of this standard states that MEE (Medical Electrical Equipment) shall provide protection to at least IP21 but sub-clause 7.2 seems to allow a get-out here by permitting marking the product with the umbrella/raindrops symbol if it fails to meet the water ingress requirements.
Does this get-out only apply to products with a carrying case or is it generally applicable?
petruchio
Sponsored Links
  Post Number #2
Old 7th March 2013, 02:22 AM
Stijloor's Avatar
Stijloor
Re: IEC 60601-1-11 - Medical Electrical Equipment IP (Ingress Protection) Requirement
A Quick Bump!
Can someone help?
Thank you very much!!
Thanks to Stijloor for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 7th March 2013, 05:24 AM
Pads38
My reading of that would suggest that the minimum requirement is IP21, but that may be provided by the enclosure and a carrying case in combination, but only when the device is intended to only be used with the case.
The rationale for 8.3.1 in Annex A is useful.
The requirement for IP21 is, I guess, driven by the higher likelihood of liquid spills and general misuse. There is additional requirements in clause 5 for Accessible Parts (smaller finger used to judge what an accessible part is).
Thanks to Pads38 for your informative Post and/or Attachment!
  Post Number #4
Old 7th March 2013, 06:06 AM
petruchio
Thanks for this. The standard is appallingly worded, the get-out statement in sub-clause 7.2 being an isolated paragraph which makes no reference - implicitly or explicitly - to anything other than the enclosure.
My company has been making light therapy equipment for many years and this standard renders the non-LED products obsolete at a stroke. However, the sub-syndromal variant - Winter Blues - can continue to use these products so long as they are not represented as medical devices. It's an absurd situation. For once I'm thankful of ISO14971 which can apply common sense here.
petruchio
  Post Number #5
Old 8th March 2013, 09:08 AM
Peter Selvey
Yes, the text of 7.2 conflicts with 8.3.1, it's a mistake in the standard that will need to be rectified. There are a number of other cases of outright and provable mistakes in IEC standards (for example, the alarm standard IEC 60601-1-8, and all of the ECG standards like 601-2-25) so it's not completely uncharted territory.
Further, there is a reasonable argument to say that having a minimum requirement of IPX1 is excessive as a general requirement, taking into account the number and nature of electrical devices typically used in the home. That is, if it's required for medical, it should be required for a lot of other electrical devices, and there really is not the market data to support this.
It's also worth to note that a "true" IPX1 rating is not just a matter of wiping the water off and doing a dielectric strength test. Rather, IEC 60529 says the water " ... shall not ... interfere with the correct operation of the equipment ... ".
There is expected to be a range of medical equipment where the water would not cause any problem for basic safety (shock/fire) but could easily interfere normal operation such as sensors or getting into battery compartment or secondary electronics. Even though basic safety is OK, it fails IPX1.
One manufacturer of home use blood pressure meters found that IEC 80601-2-30, which clearly refers to home use equipment, does not specify that IPX1 or better is required. They pointed out that a particular standard (-2-30) overrides the collateral (-1-11), and concluded that the IPX1 test was not applicable. It's a kind of fudge, but gets to a reasonable result.
As always, modern regulation does not require compliance with standards. However, you do need to carefully document and justify any cases where you do not comply with a standard, even if it appears, as in this case, that the standard in fault.
Thank You to Peter Selvey for your informative Post and/or Attachment!
  Post Number #6
Old 6th May 2014, 12:18 AM
flyingfrisbee
To piggyback on this thread,
I was wondering if testing is required to declare an IP rating. If so, what kind of in-house or external testing would be required for say IP53?
Take care,
Friz
  Post Number #7
Old 6th May 2014, 02:57 AM
Marcelo Antunes's Avatar
Marcelo Antunes
You can declare without testing, but if you need to prove it, you need to test it. Tests for IP ratings are defined in IEC 60529.
Some general info can be found for example here: http://www.specfast.com.au/media/dow...ystem_ip53.pdf and here http://www.google.com.br/url?sa=t&rc...,d.cWc&cad=rja
Thanks to Marcelo Antunes for your informative Post and/or Attachment!
  Post Number #8
Old 7th May 2014, 12:40 AM
flyingfrisbee
In what situation would you need to prove an IP rating?
Would CE marking a device be one of those cases?
How about for infant phototherapy equipment located under the patient?
IEC 60601-2-50
"If INFANT PHOTOTHERAPY EQUIPMENT is located under the PATIENT it shall at least comply with
IPX3 specified in IEC 60529."
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Amendment 1 to 60601-1, 3rd Edition Medical Electrical Equipment Standard Pads38 IEC 60601 - Medical Electrical Equipment Safety Standards Series 4 27th August 2012 09:35 AM
Marking (Labeling) Requirements on Medical Equipment per IEC 60601-1 jayanthi IEC 60601 - Medical Electrical Equipment Safety Standards Series 5 6th March 2012 12:39 AM
IEC 60601 Medical electrical equipment - Send declaration and guidance to customers? mwa IEC 60601 - Medical Electrical Equipment Safety Standards Series 1 10th July 2009 12:09 PM
Medical Electrical Equipment / System Peripherals - IEC 60601-1-3 freewind IEC 60601 - Medical Electrical Equipment Safety Standards Series 16 29th September 2008 11:47 AM
IEC60601-1 3rd edition +ve vote - Medical Electrical Equipment Safety Requirements celeo IEC 60601 - Medical Electrical Equipment Safety Standards Series 6 6th October 2006 08:39 PM
The time now is 06:14 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
A Peachfarm LLC Internet Property
