The Cove Business Standards Discussion Forums More Free Files Forum Discussion Thread Post Attachments Listing Cove Discussion Forums Main Page
Go Back   The Elsmar Cove Quality Assurance Discussion Forums > National and International Business System Standards > Aerospace and Aviation Standards and Requirements > AS9100, Nadcap and related Aerospace Standards and Requirements
Forum Username
Wooden Line
Understanding Configuration Management
Monitor the Elsmar Forum
Sponsor Links
Courtesy Quick Links
Links that Cove visitors will find useful in your quest for knowledge:
International Standards Organization - ISO Standards and Information
Howard's
Marcelo Antunes'
SQR Consulting, and
Medical Devices Expert Forum
Bob Doering's
Quality Digest
LinkedIn Groups
ISO 9001 for Small Businesses
Information Security Community
Medical Devices Group
Quality and Regulatory Network
AS91XX Series - Tips and Advice
FDA (Food and Drugs)
Related Topic Tags
configuration management
Reply
Thread Tools Search this Thread Rating: Thread Rating: 1 votes, 5.00 average. Display Modes
  Post Number #1
Old 5th June 2013, 11:36 AM
qarep
Please Help! Understanding Configuration Management
Friends,
I really need help to understand Configuration Management. Can someone help me in a simple way to understand the configuration management and share the necessary forms or templates i can use in my organization.
We are the suppliers for aviation industry. I want to understand who is the owner for configuration management. Is it the R&D or production ?
Appreciate an early response.
Sponsored Links
  Post Number #2
Old 5th June 2013, 11:52 AM
Sidney Vianna's Avatar
Sidney Vianna
Re: Configuration Management
Have you tried the material available at the IAQG Supply Chain Management Handbook, as a starting point?
Attached you will find a presentation which contains guidance on CM, available at the SCMH. More CM material is available at the website referenced above, in Chapter 11.3.
Attached Files: 1. Scan for viruses before using, 2. Please report any 'bad' files by Reporting this post, 3. Use at your Own Risk.
Thanks to Sidney Vianna for your informative Post and/or Attachment!
Sponsored Links
  Post Number #3
Old 5th June 2013, 12:03 PM
Marc's Avatar
Marc
Re: Understanding Configuration Management
In clear terms it is "revision level control". It entails what you need to do to ensure that what you build is what your customer wants, that is that the agreed configuration (revision level) matches the actual configuration (revision level).
Definition: Configuration Management - What is Configuration Management?
And: Configuration Management - Part history - How to record changes
Existing discussion threads: Configuration Management discussions
Also check out: What is meant by "Configuration Management"?
Thank You to Marc for your informative Post and/or Attachment!
  Post Number #4
Old 5th June 2013, 12:17 PM
qarep
Question Re: Understanding Configuration Management
Thanks for those inputs guys.To the second part of my question, typically with whom the responsibility of CM lies,is it R&D or Production ?
  Post Number #5
Old 5th June 2013, 12:27 PM
Sidney Vianna
The CM process ownership can reside in different functions, but for design-responsible organizations, Design Engineering tends to have a critical role.
  Post Number #6
Old 6th June 2013, 08:19 AM
ddunn's Avatar
ddunn
In very simple terms (very very simple) CM is version/revision control. But if you focus on revision control you will miss most of the benefits of CM. I've attached a CM ROLES AND RESPONSIBILITIES document to help you understand all aspects of CM.
I've run CM within Development, Program Management, QA, Production, Marketing and even as a direct report to the CEO. the most important thing is that CM must act autonomous.
Thank You to ddunn for your informative Post and/or Attachment!
  Post Number #7
Old 5th July 2013, 11:21 AM
ewilliam1
No, Configuration Management (CM) is not just version and revision control, and is definitely more then just change control but is within, as configuration control, the change management process.
I just made a presentation and recently provided to a couple of forums that were debating what CM was, if documents were CIs or and if CM was only version and revision control. Do the research, evaluate and appreciate after reading the below information and check out the significant links.
I?m sharing with you information and several links for definition of CM, its origin, and what it means. Past mistakes have left out much of what is CM, what ?configuration? is and therefore what is a configuration item. In 1983, I was also part of national and international committees to address and development (provide input) standards on the following premise to be discussed and evaluated. If anyone does the research on CM, its origin (it did not begin in the IT commercial environment), the fact that it was a discipline to complement system/software engineering development (specify, document/ mirror the product/system through the life cycle), etc., they would have no problem finding the following information.
Definitions
?Configuration Management is a discipline applying technical and administrative direction and surveillance to (a) identify and document the functional and physical characteristics (configuration) of a configuration item (the system/product) (b) control changes to those characteristics and (c) record and report change processing and implementation status ?? DOD-STD-480 ? (also provides another item) ?audit the Configuration Item (CI) to verify conformance to specifications, interface control documents and other contract requirements.? ?DOD-2167 defines it further for CSCIs.?
?CM is not just version and revision control.
The Key reason it is called a configuration item (and began in the hardware/system engineering environments until software/programs became a concern and had to be controlled and managed accordingly by (CSCI) Standard 2167 and other standards and regulations).
Configuration:
The functional (functionality and capability) and physical (design) characteristics of hardware, firmware, software, or a combination thereof as set forth in technical documentation and achieved in a product.
The documentation is out side of the CI ?
A configuration item is an aggregation of hardware and software that satisfies an end use function and capability and is designated by an organization for separate configuration management
A document is not an aggregation of hardware and software?
What it Means
What It Means? (by its original definition). The projects and programs I had the pleasure of managing throughout my career from systems (hardware, software, etc.), software, and application to infrastructure, had the below perspective.
1. Identifies and technically describes (documented in specifications/documents) the functionality or capability and design of a hardware, software, firmware or database system/product (the CI/CSCI)
2. Controls changes to the baseline descriptions and the product during development and production.
3. Provides status of the changes to the baselined descriptions and product
4. Verifies that the product developed or produced functions or has the capability described in the specification(s) and physically reflects its documented design and ?as built? code/drawings, technical documentation, etc.
Criteria to identify and select CIs: (hopefully improved and expanded as required)
The CM activity (discipline) begins during the proposal activity or at contract award because that is where hardware, system, software (or application), firmware, database configurations items are identified. The selection process is based on the following considerations (now improved and expanded):
1. System Allocation (major functions or capability)
2. Software/Application functionality or capability
3. Data/infor. requirements
4. Each processor
5. Criticality/safety
6. Size (source code lines)
7. Cost/Schedule
8. Quality (i.e., reliability, reusability, maintainability, testability, modularity, etc.)
9. Logistics support
10. Maintenance
After selecting a CI or CSCI (product or products), the type of documentation to specify the product is identified based on contract requirements, standards and specifications. CM continues throughout the product and system life cycle.?
I am working on (or hope an international panel can be established) getting a panel together, a series webinar I will be doing and having the ISO and its US member get involved in the future because we all, in collaboration, have to address the issues that have arisen from all this mess, confusion and debates? Based on this article:
Title: IT Project Management?s Missing Link ? Configuration Management, An Improving but Misunderstood Discipline. Itprofessionalfacilitor.com article.
My concern is what all this has come to and how it leads to projects and programs issues and differences when crossing over to different industries and businesses/companies? I?ve am truly blessed and lucky my success/and teams? continued having applied CM in both environments (government/aerospace and IT commercial) but based on the above information. I continue to educate, and be educated?
I am also the author(Eddie R. Williams) of: Software/Firmware Configuration Management, Within the System Development Process; Subtitle: Management Control and Quality
Content within: Definition of CM, what it means, and recommendations for each CM activity (i.e., Configuration Identification, Control, Status Accounting, and Audits).
Itprofessionalfacilitator.com
Title: Is configuration management your IT project's missing link? TechRepublic article
The Role CM
?and provide another like that talk about the role of CM (and QA/QC) including for Requirements Analsis. Techwell.com article
Thanks, and good luck to all.
"Quality, whether top-down or bottom-up, begins with an individual. ERW
Thanks to ewilliam1 for your informative Post and/or Attachment!
  Post Number #8
Old 5th July 2013, 08:57 PM
Big Jim
Is there any way to fix the links?
I would like to understand this better.
Reply
Bookmarks
Search this Thread:
Advanced Forum Search
Rate Thread Content:
Forum Posting Settings
BB code is On
Smilies are On
[IMG] code is On
Similar Discussion Threads
Risk Management and Configuration Management alimary15 ISO 14971 - Medical Device Risk Management 3 3rd December 2014 01:09 PM
Change Management, Configuration Management or Other Process? Notnimdab2009 Manufacturing and Related Processes 9 31st January 2013 06:12 AM
AATT Focus: Configuration Management & Risk Management gardnere AS9100, Nadcap and related Aerospace Standards and Requirements 3 24th January 2012 11:58 PM
Configuration Management - Is Configuration Management a requirement of ISO 9001 Boilerbill ISO 9000, ISO 9001, and ISO 9004 - Questions and Discussions 21 17th April 2010 03:28 PM
Configuration Management - What is Configuration Management? Lexylou Definitions, Acronyms, Abbreviations and Interpretations 5 6th October 2009 10:08 AM
The time now is 10:50 PM. All times are GMT -4.
NOTE: This forum uses "Cookies" -- The Elsmar Cove is *Copyright Free*.
